Question about RCA RS2663 Shelf System
I am looking for a manual for the rca 5 cd audio syatem bi amplified model number rs3520 Serial no. o32300015
  • 135 Answers
I'm looking for the part number for the power supply for the RCA RS22162 5 disc CD player
I haven't been able to find much about this particular model. I take it that you don't have the original power adapter, because it's usually labeled on the black box what the voltage should be. My only other suggestion is to look on the back of the amplifier. there is usually a label next to there the plug goes into the amp that will say what the input voltage should be.
Best of luck
May 18, 2016 | RCA New-RS22162 5-Disc CD Audio System...
I need to know how to hook up Sony amplifier ta-ax 295,Sony tuner st-jx 295, sony cassette tc-w295 with a RCA 5 disc CD player and a Samsung DVD/ video CD/CD player in stereo. It always worked when my...
There are a number of amplifiers in the TA series, but the connections are basically the same.
In your system, the amplifier serves as master control. How do you know? Look for the component that offers input selection -tuner, cassette, CD, video, phono and probably auxiliary. Every other component plugs into and is controlled by the integrated amplifier. For example, plug the tuner wires from the tuner output to the amplifier input marked "Tuner." To use the tuner, just select that input from the front panel. Same with all the other components.
On the back of that unit will a bunch of RCA jacks for left and right channels. Take the hook-up wires, usually RCA cables with colored plugs on each end, and connect the OUTPUT jacks on each separate component to the INPUT jacks on the amp. Power may also be controlled from the amp. On audio plugs, red is right and white is left. Keep the polarity constant as you connect each component. Connect the speaker wires to the speaker outputs, usually spring clips or screw terminals on the amplifier end and the same on each speaker. The DVD video cable will have three wires: Yellow, red and white. Yellow is always video. It may also have a little round video connector for S-VHS which provides a much better picture when using DVD.
Select your desired input and enjoy the show. Service Manual free download schematics datasheets eeprom bins pcb...
Jul 13, 2014 | Audio Players & Recorders
How to hook up my speaker wires
Just follow the color code of where the wire suppose to go, it's like a puzzle, but it's that your following the Bi-Amp wiring on the back of the unit of your amplifier output
Mar 30, 2013 | RCA RS2652 Shelf System
Y cd player model CD 4000 serial No HM-23174204 will not play CDs that I have burnt on my pc using Nero. But will play pre-recorded ones. Can you help me please
Have you looked at the manual?
If NERO didn't create and finalize the disc in CDA format it might not play on a normal CD audio player. Some also require the disc to have been created in a single session.
"CD 4000" is not unique. The serial number is a useless piece of data. Google it.
Name the MAKE and model first, then we'll look for the manual. Then (maybe) find a solution. You might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Google search: "(product) manual"
May 20, 2011 | Audio Players & Recorders
How to connect speakers to RCA model #RP-8070D
This unit is just a 5 disc CD player and cannot drive large speakers all by itself. Normally it is hooked up to a stereo receiver / amplifier which is what provides the power to drive the speakers which are wired to the back of the stereo amplifier.
If you have a home stereo, then just run the cables from the 2 AUDIO OUT connectors on the back of your CD player to the CD IN connectors on the back of your stereo.
Then turn your stereo on and select CD on your stereo input mode selector and you should be able to play the cds on your RCA and hear them through the stereo speakers.
If you do not have a stereo amplifier with speakers to connect it to, then you can always listen to it through headphones connected to the headphone jack.
Or if you have a set of self powered amplified speakers, like the kind you hook up to a computer, then you can run the AUDIO OUT cable from your cd player into those as well.
Good luck.
Apr 14, 2011 | RCA Audio Players & Recorders
I purchased a Philips 32 inch television Serial number DS1A1025102340 Model number 32PFL4505D F7 last week. Please tell me how I can connect ear phones. How can I connect additional speakers (the current...
Unfortunately I can't locate any connector for your headphones at the official manual. You can use the connection for Digital home theater amplifier, described at page 31 from this manual, in order to connect your TV with the Digital home theater amplifier and use the headphones and the FM Stereo Transmitter that you want, connecting them at the amplifier. In case you don't have a digital home theater amplifier but an analog one you can use the analog output jacks marked as #8 on page 28 at the same manual (using an pair of RCA to RCA cable). In case of further details needed, post me back the way you're going to connect the devices or your amlifier's brand / model to give you the details you are looking for.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Nov 10, 2010 | Computers & Internet
Would like to find replacement cables for old Sony Amplifier and CD player. I have model numbers, but when I search for parts I can't find pictures to be sure I am ordering an external cablel. Where can I...
The cables you requirea re not special in any way, they are just standard dual RCA cables. I assume that you are trying to connect hte output of hte CD player to either the CD or AUX input of the receiver, yes?
If not, please further describe what you are looking for. Neither service manual is available electronically, only on paper.
Thanks,
Dan
Dec 13, 2009 | Sony Audio Players & Recorders
How do I hook it to The tv
you may have an "intelligent" tv that only turns audio on when video is also present. if your tv is older, then go thru the menu options and look for option that turns back panel inputs to "on"...or it may be as simple as finding that option on the remote control.
May 27, 2007 | KLH DA1302 5-Disc CD Changer
RCA CD Player RP8065
You can just remove the screws and take the top off to get your CD's out
May 29, 2007 | RCA RP8065 5-Disc CD Changer
RCA RS2663 Shelf System Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
