Olympus Camedia C-4000 Zoom Digital Camera Logo
Rick Thompson Posted on Jun 18, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blurry and Bright white on subject face
When I take a Picture it comes out Blurry.. I have tried numerious settings but it still is Blurry. Also some of my pictures have bright white (on the face) which looks like someone has a bright light shinning on the subject. Thanks
Anonymous
Level 3:
Genius:
  • Master 2,985 Answers
  • Posted on Aug 21, 2007
Anonymous
Master
Level 3:
Genius:
Answers
2985
Questions
0
Helped
1028330
Points
5636
This could be a CCD fault or possibly Lens damage. Not I would think something amenable to a sensible repair price- check Olympus first though.
1helpful
Pictures come out blurry if any movement
The most likely culprit is a slow shutter speed. If the subject moves while the picture is being taken, you'll see it blur. If non-moving objects show up sharp while the moving objects are blurred, then this is definitely it.
Another possibility is camera movement. Try putting the camera on a tripod or a table or other steady support, then use the self-timer to take a picture. If everything in the picture is blurry, then this is probably the reason.
The third possibility is that the camera isn't focused on the subject. Try taking a picture of the subject when it isn't moving and see what happens.
Picture comes out blurry
There are three main reasons for blurry pictures.
Pictures may come out blurry if they're not focused properly. If some objects are sharp and others are not, this may indicate focusing on the wrong subject. This is usually not a major problem with compact point&shoot cameras since they have such a wide field of focus that almost everything will be in focus anyway.
Subject motion. If moving objects blur while stationary objects remain sharp then the shutter speed is too slow to freeze the motion. Try switching to the sports mode, and/or add more light.
Camera motion. This is the most common cause. Set your camera on a table or other stable surface and use the self-timer to take a picture. Take another one while holding the camera. Compare the two on your computer.
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
2answers
Why is my Acer 3738G webcam is too grainy and no function to adjust the settings
Grainy images indicate a lack of good lighting. Low quality CMOS imaging devices often require a lot of light to give reasonable results. Try sitting facing a window with plenty of daylight coming through, or shine a bright light on the subject.
I love my camera, but most of my pictures turn out blurry in places, unless the subject is standing perfectly still.
Hi. When parts of the subject are moving it is normal for the subject to tend to be be blurred in those places. Blurring is minimised if you take pictures in bright light because the 'exposure' (the time needed for the sensor to collect enough light to take the picture) is less. Also the 'sensitivity' of the sensor can be increased by reducing the ISO setting in the menu so that the sensor needs less time to take the picture. However ISO settings higher than 200 tend to more and more make the image a bit blotchy. The 'aperture' is also relevant and F2 (wide open) lets in more light than say F5.6 (narrower), so helps to reduce blurring too. Mainly you rely on bright light to minimise blurring if the subject moves, but there is also a 'sports' scene mode which might help. Indoors, you more often need to use Flash to get a good picture by providing more light, but flash does not usually reach far enough to have much effect out of doors, unless the subject is close by. In 'auto' mode the settings look after themselves but have a good look at the Instruction Manual and experiment with 'manual' settings to find out how the camera works and read a few beginner's aricles to make things more interesting. Most of all have fun! Regards
Why are my pictures coming out blurry?
Pictures may come out blurry if they're not focused properly. If some objects are sharp and others are not, this may indicate focusing on the wrong subject. This is usually not a major problem with compact point&shoot cameras since they have such a wide field of focus that almost everything will be in focus anyway. However, make sure the macro/far switch is set to the appropriate position for your picture.
1helpful
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Why are my pictures so blurry.. HELP PLEASE!!
Hi Lindsay Davi,
First, make sure you have the file size set to the highest size and highest quality. Small file size and low quality settings produce small files with pixelization.
Second, no camera performs as well in low light as it does in bright light. It sounds like you are new to photography, so you should start out by shooting in bright light - outdoors in the sun. Once you know how to take good photos in the sun, then you can try taking photos when it is overcast, or in bright shade (on a sunny day but outside of the direct sunlight). As you develop more experience in taking photos you can try more difficult lighting situations such as indoors.
Flash lighting is difficult because the light "falls off" quickly as the distance from the flash to the subject increases. The camera's flash tries to put out enough light to illuminate both the subject closest to the camera and to also try to light the background, but this is often impossible. So the subject is too bright, and the background remains dark. If your subject is further away, the lighting evens out some. If your subject is close to the background (e.g. standing in front of a light colored wall) the camera will get the flash exposure set to a better value and the photos will come out better.
It would also help to get a book on basic photography.
Purple tint
check out your scene and macro settings. If you are in macro mode (an icon that looks like a tulip), you should be no more than 2 feet away from your subject. Also if you are in the wrong mode (night mode in daylight, or bright mode indoors, for example), your colors may appear off.
Also check to see if your digital zoom is on. If it is, and you are too far from the subject, your picture can be quite grainy. This is a great effect if you want your picture to appear as if it were an impressionist painting, but not for a crisp picture or portrait.
2answers
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
