Question about ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
Bios after post - cemos seting wrong Fatal error System holted. in this time if i press restart switch system run normaly.
  • Samuel Spell
    Samuel Spell May 11, 2010
    I need more info. What OS. XP vista 98? To clear c-mos there is a jumper that must be moved and the battery removed this will reset back to default. Please I need lots more info to help you but can fix the problem. Must know all motherboard info and all add on cards and devices being used. It may be and OS operating system problem or just a driver or bios setting. What type of system bare bones or hp,gateway,other?
    Genius:
  • ASUS Master
  • 1,102 Answers
What were you trying to do
did you recently add new hardware or did you recently format
Posted on Jan 16, 2009
I switch on my pc (window xp) this evening, and my pc auto restart with blue screen pop out. its say some error with name 'fatal system error'. already clean disk, de-fragment in the safe mo
turn on computer,press F* repetedly until screen shows up wth options
safe mode
safe mode with networking etc...
in dat screen select option "most recent good configuration"
and enter..next window select windows xp and enter..thats it.
after u log in.clean whole system with good virus scanner for viruses,malware,trojans all
May 19, 2012 | Computers & Internet
Hi i have i minor problem: my pc reported this issue: chasiss intruded system halted , i restarted my pc and system booted normaly . this is the second time it reported this error, it reported this 5 days...
you need to enter your bios and change the setting for chassis intrusion to disabled
you can enter the bios by pressing del or f2 when you switch the pc on
if this info helped you please vote
Feb 26, 2011 | Computers & Internet
My BIOS setting can't be save. every time i restart my computer the bios setting is lost.. please help me
sir, this problem occurs due to your CEMOS battery in the motherboard is damaged. just replace the CEMOS battery and your problem will be solved.
Jan 01, 2011 | EliteGroup K7SEM Motherboard
I have a problem on this cod c000021a fatal system error i have window when i shut down my computer show blue screen with this cod c000021a fatal system error and computer restarts i need help for solve...
Blue Screen system error. If you've been running windows Xp, please do the following:
1. Insert Windows XP CD in the Pc.
2. Restart the PC and while in Bios, go to Boot Priority and select Boot from CD as your first priority.
3. Save and exit.
4. The PC restarts and follow the instructions on the screen. (Press any key to boot from the CD).
5.After system has finished, such will happen <Enter-To Continue R-Repair ESC-Cancel>.
6. Choose R to repair.
7. A black screen pops up, just read and type 1 and wait for the next step (password).
8. Put in your Admin Password or press "Enter".
9. Then type CHKDSK and press "Enter".
10. the system will repair the errors within the HDD and windows and later restart the PC. Good luck
Jun 21, 2010 | Dell Inspiron 1501 Notebook
The time in my computer always changes every time i turn it on
Please try these troubleshooting steps ,turh the computer off and then when you turn it back on start tapping the f1 key on the keyboard repeatedly till you get a screen that says ADVANCE BIOS then press the f5 key on the keyboard a message will appear that sayd load save defaults press y for yes and then press f10 to safe defaults and exit.Restart the computer and then check the time if it is not set then set it and then restart the computer if the time ghanges then go to the hp website that is www.hp.com/support .On the first screen select united states and then put in the model no where it says for product and on the next screen click on software adn driver downloads.Select the operating system and then download the download the bios update save it on the desktop and then run it.If this also does not reslove the issue the CEMOS battery in your computer need to be changed.
all the best
May 20, 2010 | Computers & Internet
ASUS P5VD2-VM SE MOTHERBOARD
If you purchased this motherboard recently then i would double check your power supply - get a better power supply and try that - think you may need one with two 12 volt rails.
If that does not work then I would get it RMA'd as in return it and get a replacement.
Apr 10, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
It takes too long at start up
run defrag under
"start",
"all programs",
"accessories",
"system tools"
"disc defragmenter"
Jan 28, 2009 | Intel 865G Motherboard
Hi! i have a susu p5gcmx/1333 mother board. The error message is 'after post the- cemos setting wrong fatal error system holted'. but in this time if i press restart switch system rum normaly. what the...
CMOS settings retain data such as system clock, CPU and FSB speeds and so on. That error can come from a bad CMOS battery. This a circle batteries easily found on your mainboard and can purchase at almost any retail store.
Jan 16, 2009 | ASUS P5GC-MX/1333 - Motherboard - micro...
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
74 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
