Question about Electronics - Others
Installed JD light kit, engine stops when light switced on
John Deere 826 Snow thrower, Purchased light kit and installed. Hooked electric wires according to intsructions. This kit has an alternator attached to the outside of the engine with a diver shaft attached to the engine. When engine running, and light is switched on, light does not turn on and the engine slows almost to a stop, switched again and the engine runs normally.
    Problem Solver:
  • 8 Answers
It sounds like the Alternator is not turning to produce the extra current required by your light kit. If your Alternator is turning, you'll need to confirm that it has an output current, which can be done with a Volt-Meter if available.
Posted on Mar 23, 2009
What colour wires go to the coil on a 726 snowblower
OK the wire on a coil is to shut off motor when grounded, so if you don't hook it up it will not shut off when you try. That wire goes to throttle linkage so when you slow engine speed to minimum it shuts engine off. Most snow blowers that have the red safety key in shield have that same wire slit from the throttle so if that malfunctions you still have a safety shut down.
May 22, 2014 | John Deere Tecumseh Snowblower Heater 726...
Wiring harness
look underneath did drive belt snap in two , rear has white plastic fan on top of it that should be rotating with engine running if not yep you broke a belt , don't know about wire could it be from front PTO they are electric so it will need a wire ,one possibility is that drive belt broke slapped front PTO and broke off wire , that musta been some snow your pushin ooh and a reminder never push a hydrostatic drive tractor without pump turning it will dammage it
Feb 08, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
John deere 826 will not go forward or reverse
Can anyone help me with a john deer 826 snow blower that won't engage in forward motion?
Mar 04, 2013 | John Deere Mowers Tillers Snow Blowers...
John deere snowblower 826 will not shift out of drive.
Your drive control spring most likely broke. This will lead to the drive pulley and friction wheel continually being in contact. This will in turn lead to the snow thrower constantly being in drive. The spring should be stocked by the local dealer and is very easy to replace.
Jan 24, 2012 | Garden
Is there a GENERIC Snow thrower for John Deere 110?
Two Stage - Snowblower - Snow thrower - Bercomac All of the Bercomac attachments are interchangeable on the same quick hitch mounting. Bolts on in minutes. What a great idea for people who have more than one tractor or buy a new one. No more having to go and buy all new attachments for the new small tractor, just buy a different model hitch kit if it doesn't use the same one. The resale value is preserved when you can sell your attachments to be used on another size or model lawn and garden tractor.
camcorder-pic.jpg Snowblower video clip
Snowblower-Snowthower Q&A's
If you are ready to buy or want more details give us a call: 1-800-618-8738 or e-mail jim@jimsrepairjimstractors.com
Sep 10, 2009 | Garden
You can't really go forward very far without checking the circuitry and individual components using an independent supply from a battery, a test lamp and a multimeter.
From your description it indicates you have a short circuit somewhere.
I suggest you revisit those fitting instructions to check you haven't made a mistake. After that I would proceed by using a battery to supply the lighting circuit instead of the alternator, just for the purpose of testing and with a fuse in the supply...
Sep 07, 2017 | Agri-Fab Agri - Fab Snow Blower - 42"
Electronics - Others Logo
124 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
