Question about Linksys (R) RT41P2-AT 4-Port Wired Router With 2 Phone Ports, Voice Over IP Terminal Adapter, ATT Ca... (RT41P2AT)
I need help with ipod touch how do i get wi-fi
  • 55 Answers
Just set up the router on another computer then u can use ur tutch
Posted on Jan 16, 2009
Tip
How do I connect my iPod to My Network
<p>The iPod Touch is the only device in Apple's line of portable music devices with embedded networking capabilities. When you enable WiFi on your iPod Touch, the device scans the area for available networks and displays a list of results. From there you can connect your home network or Wi-Fi and use the Internet to email, instant messaging, Web browsing and other applications. <br /> <p> <br /> <p>1. Touch the "Settings" icon on the home screen of the iPod Touch. <br /> <p><br /> <p>2. Select "Wi-Fi" menu item. <br /> <p><br /> <p>3. Move the slider at the top of the window of the "Off" to "On" position. The phone will scan for nearby Wi-Fi networks.<br /> <p> <br /> <p>4. Tap the name of the network you connect to your iPod Touch. <br /> <p><br /> <p>5. Enter the password for the Wi-Fi network you selected with the keyboard on the screen. <br /> <p><br /> <p>6. Tap "Done" to connect to Wi-Fi network using the password you entered. When the Wi-Fi icon appears on the top screen of the iPod Touch, you'll know the connection is successful. <br />
on Aug 09, 2011 | Apple iPod touch
How do i find the wifi password for my ipod touch
Step 1:
The wifi password is on your wifi router, hopefully someone wrote it down and taped it to your router, if not you need to loginto your router to find out what it is.
Once you have the password:
Step 2:
On your ipod touch
Verify Wi-Fi is enabled and that you are connected to a Wi-Fi network.
Tap Settings > Wi-Fi. If Wi-Fi is off, turn it on by tapping the on/off icon.
Available Wi-Fi networks appears under "Choose a Network..."
Locate and tap the Wi-Fi network you want to join then enter your password
Jan 29, 2013 | Arris Comcast/xfinity Tm502g/tm722g, 702g...
Ipod wi fi conection
Wi-Fi Functionality
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon (307189_1.jpg) next to them.
  3. Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon (307189_2.jpg) in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
  1. Turn Wi-Fi on or off.
    Choose Settings > Wi-Fi and turn Wi-Fi on or off.
  2. Set iPod touch to ask if you want to join a new Wi-Fi network.
    When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon (307189_1.jpg).
    If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
    Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
  3. Join a Wi-Fi network manually.
    Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
  4. Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow (307189_3.jpg) next to a network you've joined before. Then tap "Forget this Network."
  5. Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks).
    Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
  6. Adjust settings to connect to a Wi-Fi network
    Choose Wi-Fi, then tap the arrow (307189_3.jpg) next to a network.
Dec 27, 2010 | Cisco Linksys Wirelessn Router Black...
Tip
How can I go on Wi-Fi on my iPod Touch without a computer?
<p>Apple iPod touch Wi-Fi reception without using a computer. The device has a built-in 802.11 Wi-Fi receiver, which means that access to the Internet via a WiFi router that is in range. When connected to a WiFi signal on your iPod touch, you may be prompted for a password if you must know the password or ask the Wi-Fi to the administrator. Unsecured Wi-Fi does not require a password. <br /> <p><br /> <p>1. Press the "Home" button of your iPod touch and move the cursor to the right on the device. Enter the unlock code if you have programmed. <br /> <p><br /> <p>2. Touch the "Settings" icon on the home screen of the iPod touch Settings menu. <br /> <p><br /> <p>3. Play the "Wi-Fi" Network access to the names of all upcoming Wi-Fi to see. <br /> <p><br /> <p>4. Tap the name of a Wi-Fi to connect. If the network requires a password, you will be prompted to enter the password. <br /> <p><br /> <p>5. Touch "Join" to complete the connection. Now you can use any Internet-related programs on your iPod touch. <br />
on Aug 05, 2011 | Apple iPod touch
Tip
How to manually enable Wi-Fi on an iPod Touch
<p>IPod touch not only offers a music library on the road. It also has Internet capabilities. The iPod touch can connect to wireless internet connection available and browse the web using the Safari browser included on the device. Typically, Wi-Fi capabilities automatically. But if your iPod touch wi-fi is off, or if you activate it, you can do it using the Settings window. <br /> <p><br /> <p>1. Touch the "Settings" icon on the main screen of the iPod touch. <br /> <p><br /> <p>2. Touch the option marked "Wi-Fi." <br /> <p><br /> <p>3. Touch the "On" next to the setting marked "Wi-Fi." <br /> <p><br /> <p>4. Tap a wireless network list to connect. <br />
on Aug 05, 2011 | Computers & Internet
Internet connection ( wi fi )
how do you connect the internet to ipod touch?
Dec 27, 2008 | Apple iPod touch
Tip
How to install a Wi-Fi in iPod Touch
<p>The iPod Touch is a portable media player, game console and personal information manager developed by Apple. The first generation iPod Touch was released in 2007, the fourth current generation was launched in 2010 at the time of publication. Among other hardware features, the factory setting of the iPod touch already has a wireless adapter 802.11b/g/n standards for all. The operating system runs on the iPod touch is set at the factory to take full advantage of this hardware. You can sign up for free Wi-Fi with iPod touch. <br /> <p><br /> <p>1. Tap "Settings," then "Wi-Fi." Push the "Wi-Fi" control "ON". <br /> <p><br /> <p>2. Push the "Request for new connection" control "ON". <br /> <p><br /> <p>3. Enter the radio band - usually at least 100 meters - the Wi-Fi is connecting. IPod touch displays a message asking if your network that detects the radio signal to connect. Answer "Yes". After a few seconds, you will see the Wi-Fi icon in the status bar of the iPod touch; iPod touch will be ready for the wireless network connection. <br />
Tip
How do I delete the Wi-Fi from my iPod?
<p>IPod is a line of various models of media players made by Apple. The flagship of this line, the iPod Touch, includes the ability to connect to computer networks wireless 802.11b/g/n following international standards. Also, remember the iPod Touch Wi-Fi networks are members in the past, allowing the user to save the trouble of having to re-enter network keys and other authentication tokens. However, sometimes a user may need a specific Wi-Fi memory to remove the iPod Touch - for example, when the network configuration has changed. <br /> <p><br /> <p>1. Play your iPod icon "Settings" and then "Wi-Fi." <br /> <p><br /> <p>2. Research on Wi-Fi network that you want to delete the list of networks remembered for iPod Touch. <br /> <p><br /> <p>3. Tap the blue arrow beside the network name and tap "Forget this Network." At that time, the iPod touch loses any memory connected to that network and configuration parameters of the past. <br />
Tip
How to find a wireless password for my iPod Touch
<p>If you try to access the Internet to your iPod Touch, Wi-Fi hotspot and only that will detect the device is marked with a padlock, which means you need a password to use Join the network type. Ipod touch internet access via Wi-Fi, allowing you to browse websites with the Safari application, check your e-mail and free video calls with Face Time app. You need someone for the password if you want a Wi-Fi closed. <br /> <p><br /> <p>1. Ask your department manager of the company computer network password for the Wi-Fi when you use your iPod Touch to access the Internet while at work. <br /> <p><br /> <p>2. Check the password for a printed receipt to a Wi-Fi closed after making a purchase of a restaurant that offers Wi-Fi service to paying customers. <br /> <p><br /> <p>3. Ask your neighbor for permission to your WiFi signal, if you want to access the Internet via Wi-Fi network from your computer. If you are on friendly terms, she would give him the password. <br /> <p><br /> <p>4. Go to decree or in a mall and ask for the password to block Wi-Fi, so you can access the Internet while you shop. <br />
on Jul 21, 2011 | Computers & Internet
Tip
How can I permanently delete a Wi-Fi from iPod?
<p>Include network interface, the iPod Touch is equipped with a wireless adapter that allows hardware to join Wi-Fi networks by default, an iPod Touch love all Wi-Fi was never confirmed, this feature saves users the reenter the work of key network authentication and other parameters. However, in some cases, a user can have a Wi-Fi network to remove the memory of the iPod touch - for example, when the network configuration has changed. You can also prevent applications such as Safari Internet access. <br /> <p><br /> <p>1. Tap "Settings," then "Wi-Fi." <br /> <p><br /> <p>2. Research on Wi-Fi network that you want to delete the list of networks remembered for iPod Touch. <br /> <p><br /> <p>3. Tap the blue arrow beside the network name and tap "Forget this Network." At that moment, the iPod Touch lost all memory you have connected to that network - past and configuration parameters. <br />
Linksys (R) RT41P2-AT 4-Port Wired Router With 2 Phone Ports, Voice Over IP Terminal Adapter, ATT Ca... (RT41P2AT) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
