Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire LTF2940ES3 Erro 21
How do i fix this. Can't get the front panel off? Help
  • 640 Answers
Ok take the bottom panel off theres two screws,,almost to each corner,,,always unplug first...ok check your pump its on the left and has two black hose,,clean and,,reverse to put together...onthejob..the top panel with door cant be removed
Posted on Jan 17, 2009
How to reset a Frigidaire front load washer Model LTF2940ES3
Empty the machine. Turn off. Close door. Try pushing simultaneously 2 buttons at a time while powering up. This would reset the machine.
Jan 12, 2014 | Washing Machines
My fridgidaire model #LTF2940ES3 is giving me an error code E47 what is this
Very likely the problem is a bad door lock. It is very common problem with Frigidaire front loaders. You have to measure the resistance of the wax motor in the door lock assembly (the orange piece on the right side of the picture). I don't know why Frigidaire call it PTC. Very confusing. The normal reading should very close to 1500 Ohms. Otherwise verify all wires from the door lock assembly to the control board and, if everything is fine, replace the control board.
showpartimage.aspx?forumimg=ap4455026
If the door switch is bad, replace with this part.
If the control board is bad, replace with this part.
Oct 15, 2012 | Frigidaire ATF6000ES Front Load Washer
Change control board on Frigidaire washer LTF2940ES3
This is typically not a DIY type of job since the entire front, top, panel where the settings are needs to be taken apart to reach the control board and wiring harnesses.
Jul 19, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a frigidaire LTF2940ES3 front load washer. I tried washing a down comforter. It has shut off with the water still in it. I tried shifting the load and have now removed the comforter, but it acts...
There is no reset for this unit. Do you get any lights illuminated on the control panel at all?The lights should flash in a sequence to determine a error code. Here is the complete service manual for your machine. Your model is considered the "good model" in this manual which cover two different models. Look at page 61 of the manual to determine the error code and post it back to me. If you don't get any lights on the machine at all and you know you have power to the unit, then the control unit will need to be replaced. Here is the link to the service manual. I will be waiting on your results.
Regards,Richard
Jan 03, 2012 | Frigidaire GLTF1670A Front Load Washer
F 21 error code
F21 Long drain Possible cause: Clogged filter, clogged/failed pump. Get the bottom panels screws out and remove it. Tech sheet with erro codes and diagnostics are behind the white motor control box to the left.17faa85.jpg379e38c.jpgccf409c.jpg
May 08, 2010 | Kenmore HE2 Plus Front Load Washer
Frigidaire Front Loader LTF2940ES3 does not fill.
I had to call a service man and he said that it was the Speed Motor that had to be replaced.
Jun 22, 2009 | Frigidaire Washing Machines
Front load model LTF2940ES3 won't spin
I have the same washer and it will wash and drain but not spin. I replaced the door switch and the problem was solved.
May 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
282 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
