Question about Mitsubishi WD-65731 65" HDTV
I need to change the bulb in my WD65731 dlp tv. I have taken the cartridge out. How do I get to the bulb.
My best suggestion is to take the entire box to a place that services TVs. They will open the box and replace the bulb for around $150-200. Cheaper than purchasing the bulb online and more reliable as they usually offer a 1 year warranty.
If that's not what you want to do, there's ONE screw that opens the casing and it's located on the top of the box. One screw that holds the lamp. BE SURE not to touch the lamp with your bare hands. Unplug the old bulb, plug in the new one. Be sure that the top is securely fastened to the casing. We had problems with ours.
Good Luck ;)
Posted on Jun 24, 2009
I have the same exact tv mitsubishi offers a one year warranty from the date of purchase the website is mitsubishi.com and if you don't have anymore warranty you have to pay $250.00 for the bulb. I didn't have the warranty anymore so I went to a website bluestar-online.com and I paid $129.00 for a WD65731 bulb and free shipping 2-3 days. Hope this helps.
jmebmarin@yahoo.com
Posted on Feb 09, 2009
How to tell if ballast is bad on samsung dlp tv
It is a common practice that the ballast to repalce along with new bulb. There is no way to check the internal winding short of ballast. Repalce both at the same time. If ballast has any damage, it will surely ruin the bulb too.
Jun 04, 2012 | Samsung HL50A650 50 in. TV
Hi I have a jvc dlp hdtv that uses a Bulb jvc CL110u11AA. I understand that if the Tv is going dark that I should replace the Bulb. My Tv is also going Green most images are greener that normal. Is this...
It not the bulb,it still good.Ur tv have a problems known as convergence,"have colors shadows,colors misalinement,picture look like 3D" it dead.This convergence problems it happen to all DLP TVS sooner or later. The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts in the convergence board must be change to fix this.The shop will cost u $300-350 for parts and labors.
May 21, 2010 | JVC HD-52G786 52" Rear Projection HDTV
50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Turned on tv, no picture, only sound
the problem is likely the projection lamp .. you can replace that yourself if you are handy .. you must unplug the set and make sure everything is cool ...avoid getting finger prints on the new lamp ...here are a few places where you can get a new lamp ... you can also see what it looks like on this site ...
http://www.bluestar-online.com/Mitsubishi_Model_WD_65731_Replacement_DLP_Lamp_p/wd-65731.htm?gclid=CLb9k4zf-6ACFdk55QodwT3dxw
the lamp is likely in a cubby in the back of the set (where you used to see the bright light) ...
the lamp is mounted in a cage ... you can get the lamp already mounted in a new cage from here ...
http://purelandsupply.com/WD65731-Mitsubishi-DLP-TV-Bulbs.html
......it costs more mounted but its easier to change and you will need a new cage if yours is damaged .. from the site above you can see what the cage looks like with the lamp already mounted ..
your lamp is a model 915p049010 ... that is available thru amazon at a good price here:.(includes cage)........
http://www.amazon.com/Mitsubishi-915P049010-Lamp-DLP-TV/dp/B001AJ8RAA/ref=dp_cp_ob_e_title_0
Apr 10, 2010 | Mitsubishi WD-65731 65" HDTV
Changing DLP bulb
there is not true schmatic to change a Dlp bulb. It should slide or twist right out of its balast and you should be able to put a new one in the same way.
Thanks
Jul 19, 2009 | Televison & Video
I need to change the bulb in my WD65731 dlp tv. I have taken the cartridge out. How do I get to the bulb. I repleced my lamp and still have no picture. Am still getting a "blinking" lamp light on front...
The blinking lamp light refers to the lamp door not being closed. There is a little lever behind the main panel and if that's not shut, the lever won't be pressed in and therefore the light blinks. If it's a failed lamp, the lamp indicator light will be a solid, not blinking.
May 31, 2009 | Mitsubishi WD-65731 65" HDTV
Samsung dlp hl-p4663w
you need to find out what mage it blow to get the tv to work again
Oct 23, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp tv: was indicating need a new bulb change. changed bulb and now will not work.
u sure it pluged in all way unplug tv take bulb out look at bulb not broken in side is it re set it in then reset lamp life on tv
Oct 06, 2008 | Televison & Video
DLP Lamp Replacement
yes it is in a cartridge and it is plug and play. and if 1 year old still under wtty. The dimness could also be your fluids??
Apr 01, 2008 | Mitsubishi WD-52631 52" Projection HDTV
in the rear their is a section were you can uncrew and replace the lamp. be sure that its unplug from the ac outlet and you wear a glove so you wont touch the lamp.
Apr 01, 2008 | Televison & Video
Mitsubishi WD-65731 65" HDTV Logo
126 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
