Question about Radio Shack VGA PC Camera Webcam
Sometimes when trying to use the webcam - i have to unplug and plug the usb connection. why?
    President:
  • 8,637 Answers
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 31, 2009
I have a Gateway NV55C laptop. I've had it since December 2010 and I've had no problems with it. Then, a few days ago, I was trying to open up my webcam but this message came on the screen;...
This could be connection to webcam is loose or unplugged. Is this a USB webcam connection or onboard? If it is USB, check connection, unplug and plug it back to see if it works. Reboot your laptop might help. If still not workings, you might need to uninstall and reinstall it. Thanks
Jun 12, 2011 | Computers & Internet
My logitech webcam is connected but when i pull up the software it says my webcam is not plugged in
There may be an issue with your USB port.
Try unplugging your camera, Restarting the computer, and then plugging the camera into a *different* USB port. The camera should re-enumerate in your system, and that should fix the problem.
May 22, 2011 | Logitech Webcam
Installed software and connected camera. microsoft webcam program says camera is not connected
If it is connected using a usb cable, make sure the cable is connected properly or else try to plug the cable into a different USB port. If it still doesn't work than uninstall the drivers completely, unplug your webcam >> restart your computer >> install the drivers and connect the camera when it asks for it.
Good Luck!
Sep 06, 2010 | Microsoft LifeCam VX-5500 Webcam
Problem installing a genius VideoCam Messenger
Try restarting the computer with the device unplugged, and then when you are in Windows and everything has loaded, plug your Web Cam into a "different" USB port than you originally had it plugged into.
Now the drivers should install your device.
Jan 26, 2010 | Genius VideoCAM Messenger Webcam
Labtec webcam not working why i did every thing my computer not detecting this ****** i install all the posible drivers already i used window xp. I hate this man.
ok, uninstall all related drivers to this camera,
Now using the supplied disk install the camera software but please do not connect the camera YET, if the camera is already connected,
remove the camera and reboot,
so you installed the camera software now plug the usb camera in, it will now detect the install camera software and work.
Regards
gewiz.
Dec 05, 2009 | Labtec 961307-0914 Webcam
A4tech black or blank screen problem
Test your webcam here, by hitting "allow" in top window and assess your cam in left panel.
If it works there you know the Hardware is ok (webcam/lead/USB etc)
Test it in Yahoo
Re-boot the webcam by unplugging it from the USB and plugging it back in again
Open Messenger - Click (>) Messenger > My webcam > OK
Your webcam should launch - if it fails to do so you have a software problem.
Try updating your driver from the Imaging folder in Device Manager
Expand the folder, right click on your webcam text and select "Update driver" opt for Internet, when prompted.
No luck ?
Uninstall webcam software from Programs.
Restart computer
Go to A4Tech website and download software
http://www.a4tech.com/ennew/support.asp
Once your webcam is working on your computer,you can configure it to Yahoo Messenger.
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it. Mine, I just unplug it from the USB and plug it back in,
INTERNET CONNECTION
Webcam connected
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
TESTING
> Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start. You should be rewarded at this stage with your happy smiling face.
DEFAULT
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK
Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
Aug 27, 2009 | A4tech Xmaster PK-835 Webcam
Cant connect to lifecam
There may be a clash between lifecam and MSN. close MSN and alll other IMs. uninstall lifecam. restart the PC, install webcam SW with the cam unplugged. After installation plug the cam ina USB port and let Windows read the drivers and install the cam, Once that is done, now you can configure the cam in your IMs one by one.
Aug 07, 2009 | Microsoft LifeCam VX-1000 Webcam
Webcam not found - but plugged in to USB
mmmmm
u need to try to connect it to another PC and try to see if the other computer see it or not, if yes then try on ur computer to remove all usb cables and put ur webcam alone and try
Jun 07, 2009 | Logitech QuickCam Fusion Webcam
Pc wont detect camera
Most of those driver CDs only work if you plug the camera in after the CD is done. So since you've already ran the CD, try just unplugging it and plug it back in and wait a sec for Windows to find it. If that doesn't work, try a different USB port (assuming it's USB). I have seen USB ports just go bad, and their neighbor works just fine.
Apr 16, 2009 | Veo Advanced Connect Webcam
Webcam not connected
try unplug it and plug it again.
try another usb cable and see.
if not, uninstall and reinstall the driver for the webcam.
Aug 22, 2008 | Computers & Internet
Radio Shack VGA PC Camera Webcam Logo
15 people viewed this question
Top Radio Shack Computers & Internet Experts
Mark Gough
micky dee
Mike
Are you a Radio Shack Computer and Internet Expert? Answer questions, earn points and help others
