Question about Sampo PD-70 15" Flat Panel LCD Monitor
Sampo Flat Screen Black unless unplug and plug back in
When I turn on my Sampo flat screen the power button light comes on (green) but no picture shows up, only black screen. There is no screen saver or "No Signal" message either. Just black. If I unplug the power cord and plug it back in then the set turns on normally. If we click on the power button to turn off it does go off but when we click on the power button to go on again we have the same condition of a green light and black screen.
  • Anonymous May 23, 2009
    Have the same problem.Is my monitor Dead?
    Regards
    Kumbah
Did anyone solve the problem of turning on the Sampo and it goes black?? I have 2 of them that do it now.
Posted on Jan 11, 2010
I had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Posted on Jan 16, 2009
No picture on TV
Not sure if you saw Tom's Guide
at Sharp lcd tv power button flashing
(1) 4tinyhearts said:
I unplugged the TV and held the buttons down and it continued to flash. I continued to hold down the two buttons and replugged it in again and it worked. TV back up and working.
(2) lastditcheffort said:
Unplugged it. After looking for a new tv online I decided to try getting it to work. So, plugged it back in and held down the power button, a red light came on, held down the power button again and an orange light came on, held down power button again and green light came on and tv powered on. This was simply a case of trial and success!
(3) Nateinportland said :
unplug, hold power button, plug in. If that doesn't work, unplug all the HDMI cables, unplug the power, hold power button, plug back in.
Jun 04, 2016 | Sharp Aquos Televison & Video
Get a black screen when turned on
Same thing happened to me. Unfortuanatley, I had to get a whole new phone because it was a "manufacturer defect"
Jul 05, 2015 | Televison & Video
The tv came on then the screen went black but there was still sound for a sec. Now the green light keeps blinking and the tv won't turn
Unplug the tv for 5 minutes, then try this. Keep holding the VOL+ and CH- buttons down while you plug the tv cord back into the wall ac outlet till you get sound and picture for a second or two. You should be able to turn the tv on and off with the power button now. Next turn the power button off and unplug the tv for a few seconds and then plug it back in and turn the power button back on. Watch the screen and see if the sound and picture comes on, best to check in a dark room to see better, if sound stays on and picture comes on a few seconds and back off you have a bad CCFL backlight lamp in the LCD panel. This tv hads (10) CCFL lamps part # RLMPLA029WJN1 cost $15.93 at www.partstore.com or $19.49 at www.encompassparts.com in it and if one is burned out it will not let the tv picture be powered on till it is replaced. To check and replace the CCFL lamp you will have to unplug the ac cord from the tv back and remove 10 screws holding the back on. With back removed unplug the wire plug on the power button circuit at top left side of the black LCD screen trim, remove 4 screws holding the top of black trim, lay speakers off it, and release trim clips, (4) at top and (2) at bottom with a flat screw driver, and lower the trim to unclip the LED circuit board at bottom left side on the trim. With trim removed, at top of LCD panel remove the (2) PC ribbon wire clips with thumb nail by lifting up on it to release the flat PC ribbon wire. Lay the tv back on a soft pillow with screen up, and look on the LCD panel front for and remove the (10) silver screws 1/2" long with an arrow mark beside them. Do not remove any gold colored screws or any without marks. The LCD panel screen can now be lifted off, lift the backlight plastic thin sheeting and thick sheet off to see the CCFL lamps. Plug the ac cord back into the power supply inverter circuit board and plug the power button plug wire back in its circuit board on the LCD black trim panel, and power the tv on while looking at the CCFL lamps. If the lamp is dim or burned out, take the (2) white plastic covers off the ends of the lamps with a flat screw driver and unclip the lamp to replace it, Check the lamp socket part # QSOCFA003WJZZ by putting a good lamp in it and if it lights up the sockets are good and the bad lamp was the problem. If all the CCFL lamps do not light up, unclip the top lamps and move them to differant sockets to the center and the center lamps to the top, if the lamps do not light up, then it is a bad power supply inverter circuit board the ac cord plugs into, part # RUNTKA448WJQZ , cost about $160.00 for new one or less if you buy a used one on www.ebay.com , replace it and the tv should work ok then.
Dec 06, 2010 | Sharp LC-32SB23U 32 in. LCD TV
I push my power switch and nothing happens. the
Jun 02, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Power light comes on but no picture. Black screen
if the set appears dead ecept for the power light, unplug the power cord from the back of the set, wait two minutes, then plug it back in and try to turn on the tv. Doing this worked for me.
Jan 27, 2010 | Sanyo DP42746 42 in. Plasma Television
Lost picture. When using main power button, the
Tries unplug,replug the tv an hour later might work.But this a temp.fix,must replaced the backlight video board sooner or later.
Dec 22, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
Just a Black screen
needs a Y-Sustain board, about a 300 dollar part, unless you have a warinty, also try turning the tv on, after you get a green light, unplug the tv, after 15 seconds plug it back in, sometimes will make tv come back on
Jan 09, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Sampo PME-42S6 black screen
I have the exact same problem and sent an e-mail to Sampo in Taiwan today (March 3rd) with a technical explanation and description of the problem you have reported. I included information on the status of the LEDs inside the unit. My suspision is that the power distribution board has developed a fault. I am going to try to find out if a schematic is available to repair the board or if a new board can be purchased. I will provide an update when I have one. Glenn
Feb 08, 2007 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Sampo PD-70 15" Flat Panel LCD Monitor Logo
699 people viewed this question
Top Sampo Computers & Internet Experts
Paul Bade
michael galang
Are you a Sampo Computer and Internet Expert? Answer questions, earn points and help others
