Question about Crock Pots & Slow Cookers
High-pressure cooker exploded
My high pressure cooker exploded as the rubber seal wasn't placed properly, after that, I realised that lid shape had changed a little bit, can that be repaired or is it still usable?
  • 267 Answers
Most of the time NO but i would try setting it in place and locking down the lid and do nothing for a day or so , do not heat it ,just leave it . after a day remove the lid and see if the gasket looks normal if not REPLACE IT ......... what do you have to loose , just a little time , but just so you know those gaskets dont last forever , your should get one if you can ,just to have in case
Posted on Jan 16, 2009
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
Why wont my pressure cooker retain any pressure
bad lid seal --lid not put on properly--safety valve not on lid
Dec 07, 2016 | Crock Pots & Slow Cookers
Manual for Mirro pressure cooker Model M- 0536-1
go google and type in -- user manual for mirro pressure cooker model m-0536-1-- and if there is one it will be a pdf version down load
make sure that the lid seal went in without any twists
put something under the seal and go around the lid several time to allow the seal to untwist
Oct 26, 2015 | Crock Pots & Slow Cookers
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process:
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
I can't get my 17quart pressure cooker to seal. I was looking for an online manuel so i could find out why.
Take the rubber ring out of the lid.
Wash it with warm soapy water.
Dry it.
Oil it with vegetable oil.
Now do you see how the rubber ring has a groove around it on the inside? Push your thumb into the groove and work it around the ring, you're trying to spread the rubber V out.
Put it back in the lid and take it for a test run.
In the future store your cooker with the lid upside down on top, keeping it closed will ruin the seal.
If it still won't seal replace the rubber parts, you can get a kit for your cooker from presto.
Aug 08, 2011 | Presto 01282 Aluminum Pressure Cooker Slow...
The rubber seal on the inside of the lid always becomes loose and doesn't allow the cooker to come up to pressure. I always check it and make sure that it seems to be fitted properly, and when I actually...
Replacement parts for the Wolfgang Puck pressure cookers are available here:
If you do not see the part you require or are unsure about the model numbers; suggest you contact their Customer Service at 1-800-275-8273 or via their webform at:
Sorry someone has not responded sooner.
Oct 31, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Displays E2 and E4 (5 qt Wolfgang Puck pressure cooker - silver) what section is problem mechanical or electronic?
I think E2 means open circuit in thermocouple in center of bottom. E4 means no contact on pressure sensing switch at edge of bottom. Mine had E4 error. Took out switch and used fine sandpaper to clean contact points. Now it works fine.
Remove 3 screws in bottom. Remove bottom cover by turning it ~1/4" to clear tabs. Remove switch at edge of bottom with two blue wires going to it. Clean contacts and replace.
Jul 10, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Displays e4 wont work
Removed the 3 screws on the bottom. There is a relay near the circuit board. Kind of looks like an old morse code relay. Just tapped out "E 4" in morse code. Plugged it in and it works fine.
May 13, 2010 | Wolfgang Puck 5-Quart Electronic Pressure...
Need a new rubber seal for the lid of my pressure cooker 6qt
Need to have new rubber installed on my pressure cooker lid, but cannot find anyone to do it. Presto says they do not do the labor but will send me the rubber???? Any suggestions?
Nov 10, 2009 | Wolfgang Puck Electric Pressure Cooker...
Rubber seal,+ cushion plug for old model 16 Namco Pressure Cooker
spare parts available from an exclusive namco website in australia, west coast.
Aug 15, 2009 | Crock Pots & Slow Cookers
Crock Pots & Slow Cookers Logo
116 people viewed this question
Top Crock Pots & Slow Cookers Experts
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
