What is the lowest term fraction for 7/9?? - Office Equipment & Supplies
  • Anonymous May 20, 2009
    I'm in third grade and i cant find out the simplest form out for 4/6 and 2/3.
    Problem Solver:
  • 15 Answers
7/9 is the lowest
Posted on Jan 17, 2009
How do I get the TI-85 to convert an improper fraction to a mixed number?
To do this on any calculator, enter the numerator and denominator of your mixed fraction, with a divide in between. I get 1.4. Next, take the decimal into a fraction and reduce it to lowest terms. In this case, 0.4 converts to 4/10 which reduces to 2/5. Putting the two pieces together, we get 1 and 2/5.
Good luck.
Paul
Jun 24, 2015 | Office Equipment & Supplies
What is the lowest terms for 711/22
To convert a fraction to lowest terms, we must divide the numerator (the top number) and the denominator (the bottom number) by a common number until we can't reduce it any more. A method for doing this is to factor the numerator and denominator by their common factors.
So let's factor 711 and 22.
1 x 711
9 x 79
3 x 3 x 79
I don't think I can factor 79. We should check the numbers from 2 up to the square root of 79, or approximately 9.
Factoring 22,
1 x 22
2 x 11
Unfortunately, none of the factors of 711 are common with the factors of 22, so it is already in its lowest terms, and cannot be reduced.
Good luck,
Paul
Apr 09, 2015 | Office Equipment & Supplies
Reduce this tothe lowest terms 711over 22
The fraction 711/22 is an improper fraction (the numerator is greater than the denominator).
While there is nothing incorrect about this, an improper fraction is typically simplified further into a mixed number.
The whole number part of the mixed number is found by dividing the 711 by the 22. In this case we get 32.
The fractional part of the mixed number is found by using the remainder of the division, which in this case is 7 (711 divided by 22 is 32 remainder 7).
The final answer is: 32 7/22
Changing 80% to a fraction in the lowest term
You have to be careful. 80% is in fact 0.8.
Turn the calculator ON.
Enter the number 0.8
If your calculator is set to Write-View you will see the number displayed as a stacked fraction 4/5. If it is already in this form, press the key marked change with two arrows. The display should show a fraction.
If your calculator is set to LINE, you will see 4r5, where 4 is the numerator and 5 is the denominator.
The key marked change allows you to change displayed result from decimal to fraction and from fraction to decimal. When a number is converted to a fraction, it will always be a fraction reduced to its simplest terms.
Jan 14, 2012 | Sharp ELW535 Calculator
Write as a fraction and as a percentage 45 out of 90
As a fraction, 45/90. In lowest terms, 1/2. As a percentage, 50 or 50%.
Feb 09, 2011 | Office Equipment & Supplies
4 1/3 ÷ 1 2/3
(4 1/3) / (1 2/3) = (make the two numbers proper fractions)
(13 / 3) / (5 / 3) = (the "/ 3" on the left and right cancel out each others)
13 / 5 = (go to lowest term)
2 3/5
Jan 06, 2011 | Office Equipment & Supplies
61/82 as a fraction how to reduced to lowest fraction 1/?
61/82 is already reduced to lowest terms since 61 and 82 have no factors in common (other than 1). In fact 61 is a prime number so it has no factors other than 1 and 61.
Nov 13, 2010 | The Learning Company Achieve! Math &...
Convert
Transforming 0.175 to fraction:
= 175/1,000
Reduce to lowest term (divide by 5 both the numerator and the denominator):
= 35/200
Reduce further by dividing both by 5:
= 7/40
This is the lowest terms now that it can't be reduced further.
The "Other" way round, Bottom number into ONE and multiply it by the Top. EG: 3/4 == 1 divided by 4 = 0.25, now we multiply, .25 by the Top number or in this case 3, that equals 0.75. 1/4 =0.25 x 3 = .75. 3/4 is the same as 0.75.
Feb 22, 2010 | Texas Instruments TI-30XA Calculator
Write the ratio as a fraction in lowest terms. 7
multiply each by 5 to get whole numbers. your ratio will be 35:26
Feb 18, 2010 | Core Learning Fractions Step-By-Step...
70 people viewed this question
jasbo
jasbo
