Question about Maytag SkyBox MBV1976A Beverage Dispenser
Broken door hinges
Hinges on door broken what to do ,tried epoxy but wouldnt hold
  • 3 Answers
I had a similar problem. Aside from buying new hinges, try "Gorilla Glue". It works great. Gust be sure to clamp the parts together and let sit overnight. I did this with mine and it has been working for almost two years.
Posted on Feb 09, 2009
  • 90 Answers
Dont they have a replacement hinge to buy ? look for part at
appliance .com -- they have everything -- just look up item under the model number and unit name
Posted on Feb 06, 2009
  • mike4671 Feb 06, 2009
    appliance pros parts . com
How do I fix or replace a broken Hinge on Dell 500 Laptop
The hinge rarely breaks, the fixings come loose and split the plastic case.
Disassemble the laptop to find out where your problem is,
DELL Vostro 500 PP29L SSD
If the plastic has broken off, I use epoxy resin to repair around the hinge or look on fleabay for a replacement hinge.
Dell Latitude D500 Laptop 14 1 034 Screen Hinges eBay
Feb 06, 2017 | Dell Computers & Internet
Door release buton does not open the door
You can disassemble the microwave oven and check out the release mechanism. You'll find several hooks that hold the door closed and a linkage mechanism to the door opening button. There may be a broken piece of plastic or maybe just a loose or missing screw that holds linkage together. In the case of a broken plastic part, you can fix it with a 2-part epoxy adhesive, but you'll need to permanently splint across the break with a piece of metal or strong plastic that you've scavenged from somewhere. Before epoxying the splint in place, rough up all plastic surfaces where you want the epoxy to stick well.
Good luck.
Mar 16, 2015 | Panasonic Microwave Ovens
Hinges on a metal frame door
You could try to use a 2 part epoxy to reinforce the hinges. This would allow you to paint it afterward.
Oct 03, 2013 | Hardware & Accessories
Broken door hinge on Stoves 900dfa oven
STOVES 900DFa - how can I download the USER MANUAL and the TROUBLESHOOTING and MAINTENANCE MANUALS
Dec 30, 2012 | Stoves 900DFa Dual Fuel (Electric and Gas)...
A part of the outer case my PCG-61411W Sony Vaio laptop is broken at the place of the hinge, how can I replace it ?
See if you can find a bottom case and lcd hinges on ebay.
http://www.ebay.com
Just put in your computer's make and model in the search box.
Example: Sony Vaio PCG-61411W bottom case or Sony Vaio PCG-61411W Lcd Hinges
Jun 02, 2012 | Computers & Internet
Panosonic NN-S525BF Latch Spring Broken
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In most cases, the spring mount on the inner door panel breaks off, and while the ideal way to fix it is to replace that whole panel, the time, cost and labor are considerable.
It's usually easier and cheaper and just as effective to use epoxy and some kind of hardware to fashion a new spring mount.
Or if there is enough material to drill a hole for the spring, do that, install the spring, then add a dab of epoxy to cover the bottom loop of the spring where it goes through the hole you drilled.
Let the epoxy dry overnight before you close the door or use the oven.
Jan 24, 2009 | Panasonic NN-S254BF Microwave Oven
Brother MFC 8440
I fixed my door with Gorilla Glue (any epoxy will do.)  Find the broken piece and splice together.  You CAN do it!
Sep 08, 2008 | Brother MFC-8440 All-In-One Laser Printer
Loose door handle
DON'T remove the cover yourself unless you fully undertand the SAFETY issues involved in working inside a microwave oven. A microwave oven is possibly THE MOST DANGEROUS common consumer product to service. Usually with these doors, the latching parts tend to loosen up at times, thus requiring some re-adjustment and tightening. Sometimes they get a bit warn and require to be replaced. The handle by itself about $40, apparently GE doesn't know how to make a door handle that will hold up for more than a year or so. I just bought a new door off of eBay for $20 + $20 shipping ... a deal compared to the $135 + tax and shipping that most of the web sites want! All you need is a phillips screwdriver and a 5/16" socket. To get to 3 screws that anchor the TOP hinge, simply remove the vent grill (open the door and remove the 2 white screws that hold it in place). To get to the 2 screws that anchor the BOTTOM hinge, simply remove the 6 screws that hold the grey bottom pan of the microwave in place. The pan will swivel down, remaining attached in the back panel. Once you've removed the 5 hinge screws, the door should pull pretty much straight out. Reverse the procedure with the new door, which should come with hinges attached. Could be that the place the spring sits in is a little broken, so theres no stop for the spring. open it up and see if there's anything you can do with it, try some epoxy putty maybe. Good luck
Apr 28, 2006 | GE JVM1330BW/WW Microwave Oven
Maytag SkyBox MBV1976A Beverage Dispenser Logo
132 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
