Question about KitchenAid KSSS36QK Side by Side Refrigerator
Kitchen aide side-by-side lights are on, but no refrigeration
A mouse chewed a wire in the electrical circuit which provides current to my refrigerator. The light inside is on (but dim), but I can't get the on/off button, or the cooler/warmer buttons to work. The refrigerator will not turn on.
    President:
  • KitchenAid Master
  • 2,651 Answers
This a $3-4 thousand dollar refrig, think maybe you should leave this for the service man to check out??? wouldnt want to create any more damage
Posted on Jan 16, 2009
Kitchenaid superba ksrg25fkwh01 wire harness
Called Kitchen aid and protested, frig was 4 years old at the time. door was almost $1200 to replace. Kitchen aid paid for new door and installation
Sep 19, 2012 | KitchenAid Superba Architect KSCS25INSS...
I have a kitchen aid electric range kesc307hbs8. we lost electricity one day and when it went back on the stove began to smell burTt. the range heats up but the control panel and touch pad are not working....
Hi.It is advisable to turn off your fuse or appliance when there is a power outage..When the power turns back ,it will produce surge amount of voltage that would eventually damage your appliances.when power comes back it has a very abnormal current flow.it may rise or fall which might beyond the wires capability.meaning it goes beyond what the wire can carry..It might be that when the power supply return it gives high current and short circuit the ground and live wires of your electric range.You better check continuity using an OHMETER.MULTITESTER if there is no short circuit.If the reading of the multitester if set to ohms is too high thats beyond the maximum amount going to the right,then there is a short circuit..
Jun 28, 2011 | KitchenAid KESC307 Electric Kitchen Range
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Problem with KitchenAid Superba KSRG25FK Side/Side Refrigerator
I found you looking for keep en mind kitchen aid is made by whirlpool good luck :) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=504094
Jun 12, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Plastic burning smell coming from bottom front vents.
u may need to unplug it then tip it enough to see under it to see if maybe a mouse chewed on some wires and try to rewire or electic tape on some bare wires
Mar 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Agitator will not work
kitchen aid is hte same as the whirlpool so if you have directions for that one it will work on your current one,, part number 80040
Oct 23, 2008 | KitchenAid Superba Architect KSCS25INSS...
Fridge is tripping fuse box
if this is a new problem that suddenly occurred, then trust the fuse box...the frig has a problem. Most likely a compressor motor that has been electrically damaged...could have been power surges from utility or lightening or unknown. It also could be a wiring problem in the house...mice have been known to chew through wire insulation...they feel the warm wires and are fooled into believing the wire is a live food source and start chewing. A test of this wire problem is to remove the frig and plug in something that will demand close to the same current...(should also contain a motor)...read the frig's label on back of unit.
Jul 29, 2007 | Maytag MSD2351HE Side by Side Refrigerator
KitchenAid KSSS36QK Side by Side Refrigerator Logo
53 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
