Question about Dell Inspiron 1200 Notebook
Can not connect to internet using wireless
I have a Dell Inspiron 1200 and now connect to the internet via an ethernet cable attached to a Gateway 2 wire router, provided by AT&T. I cannot connect to the internet wirelessly and the router provider is less than helpful. My computer has a Dell PC card. I was told that the Dell wireless program is overriding AT&T this has since been disabled still no luck.
Any suggestions??
  • Anonymous Mar 17, 2014
    computer says card ok computer shows my router, yet unable to connect to internet
  • 51 Answers
Did you input the WEP key? I will assume you are using Windows XP. So go to control panel, network connections and then go to the wireless connection and then select view wireless connections double click on the one with the highest strength, which should be your 2wire. When it asks for the network security key type in the numbers that are located on the sticker on the bottom of your router between the [########] brackets.
Posted on Jan 16, 2009
    Sergeant:
  • 366 Answers
To have an overview try this Tip
Dell Wlan program is supposed to manage the PC WLAN card.
An eventually installed ATT program is supposed to be used ONLY to configure ONCE your ATT router.
If you have an ATT router control program is can be to dialog and config Router NOT to configure your Dell WLAN card.
  1. Configure your router in Wireless section: remove security to check your WLAN. Set a new Wlan name (= SSID) to be able to find your network between other neiborghs networks.
  2. Be sure to use same standard both for router and PC card (A, B, G, N)
  3. Confi gure your PC WLAN card: if you have to use a proprietary driver disable Zero wireless configuration set in WLan Properties and launch wlan card associated program.leave your network open
  4. View Wireless network using your PC card monitor SW and find your network (SSIC) connect
  5. If you can connect to open wlan you can proceed to configure router for an encrypted and protected network.
  6. use WPA-PSK security protocol
  7. replicate same settings on PC WLAN card and recheck connection.
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
Dell inspiron 1525 not connecting to internet
I am one of the Dell Certified System Expert.
For internet connection, there are two ways to connect to the internet. One is through wired connection (connecting LAN cable) and connecting to wireless connection (through wireless router or through wireless Modem WLAN).
For wireless check the switch located on the left side of the portable after switching check the status light located at the front left of the computer.
check the driver if it is properly installed meaning no bang(!) or question mark(?) for both ethernet (LAN port) and Wireless Device.
To check the driver go to control panel then device manager. Check the network and you should be seeing the ethernet and wireless device. If not installed use the driver cd that came with the computer.
How to check the internet connection.
For Wired connection:
First check the cable, check the LAN port in the computer there should be blinking lights, if none try to reseat the cable. Check the ipaddress of the computer and the default gateway.
This is the instruction to get the IP address and default gateway.
For windows xp
1. Click start, then choose run then on the box type CMD then click ok.
2. on the black screen type ipconfig. get the ip address and default gateway.
3. normally it will give you 192.168.XXX.XXX
4. try to type ping 192.168.XXX.XXX (this should be the gateway)
5. If you receive replies, then you are connected to the router/modem
6. then try to ping www.yahoo.com
7. if still reply then you are connected to the internet already, might be your issue is browser or security on the computer.
For vista and Windows 7
click windows then in the start search type cmd, you should be seeing cmd on the top, right click then choose run as administrator. then follow steps 2-7 above.
For wireless connection
Check the switch, and the status light, if all are checked checked the ip address and default gateway as well, the instruction is the same above.
For more information about setting up your system please refer to the link.
http://support.dell.com/support/edocs/systems/ins1525/en/SG/Y465HA01MR.pdf
Hope this will help you a lot.
Thank you for choosing fixya
Mar 01, 2011 | Dell Inspiron 1525 Notebook
Gateway not pinging from dwl 3200 ap . AP=192.168.4.250/24 in the same subnet, gateway=192.168.4.1 , gateway assign also on wireless adapter , wireless adapter address also in the same subnet with right...
Remove the cables from the gateway router to the switch to leave only the uplink cable or connection to your telephone socket.
Test connectivity by plugging your laptop or computer directly in to the gateway router and test web access using an Ethernet cable.
Your laptop /computer may need to be rebooted for new ip. If ok reattach the unmanaged switch a retry by attaching the Ethernet cable to one of the ports on the switch. If ok, this limits the problem to the access point.
The main problem is that you have two layer 3 devices connected together by a layer 2 switch.
The solution would be to retain the configuration on the gateway if all ok. Change the access point to a different sub net and SSID to the gateway router.
If you can shut down the broadcasting from the gateway as all WLAN will be done through the access point.
Ensure that DHCP and DNS is switched on, on the gateway router.
All computers should be configured to use the gateway router address as this will allow the gateway to provide routing across the network.
Jun 30, 2010 | D-Link Computers & Internet
How can I add internet in my laptop ?
After subscribing to an Internet Service Provider, you can connect via modem with the Ethernet cable, USB cable or wireless if the modem support this. Check with you ISP to find out which is recommended for your modem.
Good Luck
C2S
Jun 28, 2010 | Dell Inspiron 6000 Notebook
How do you connect to the internet ?
what u can try is that install the lynksis cd on the computer and then open the network connection and then right click on the wireless network connection and then click on the view available network and then connect to ur network connection and it should work or else the best way u can do is that u can call up dell technical support and they will be definately able to help u to connect to internet cause i really cannot explain all the details here cause it need to be done troubleshooting on ur computer practically by connecting the router with the laptop with the ethernet cable and when u connect the internet with the ethernet cable then the dell guys can take the remote session in ur computer so that they can help u to connect to internet wirelessly.
follow 4 steps to connect to lynksis:-
In order to follow thesen four steps all u need to do is that just follow this link very caarefully and u will definate;y be able to connect to internet wirelessly with the lynksis..
http://www.microsoft.com/athome/moredone/wirelesssetup.mspx#step1
Jan 27, 2009 | Dell Inspiron 1501 Notebook
Connecting a cpi to the internet ?
1) You can use a PCMCIA card (for example a Dell Fast Ethernet 10/100 Base-TX by 3Com) with a 'dongle' to connect to the ethernet cable via an existing card slot on the left side.
2) You can get a docking station set-up (i.e. Latitude 'C/Dock') which comes with the ethernet cable connection. ...pretty affordable used on the 'net.
3) If you has a wireless router you could hook a wireless USB adapter tp connect wireless to yout router.
jmjrfeller
Dec 28, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Intel 82562V-2 10/100 ethernet adapter does not turn back on from vista sleep mode
If you're using your system as the Host for the other systems, turn off your sleep mode. The Host should be active at ALL times.
Dec 09, 2008 | Intel Ethernet 10/100 Network Adapter
Network problems connecting to internet
Hi. If Dell is correct, then yes, it would be expensive. Your other alternative is to buy a PCMCIA Ethernet Card. They range from about $20 to $40. Or, you could go with what you suggested and do wireless via a wireless router.
May 21, 2008 | Dell Inspiron E1505 Notebook
Internet connection
It appears you will need a checklist to determine what
is the right solution to your friend problem.
1. Does she has an active account with ISP provider?
2. Check to see if the Linksys1 router is functional.
Suggestion to connect the Gateway Desktop or the Dell notebook
network port to the router via Ethernet cable and see if it has access to the Internet.
3. Operating System?
There are different wireless solution but it depends on the version ands service pack level of the operating systems.
4. Keyboard Problem
Suggestion
Wireless Keyboard - Install fresh batteries
Wire Keyboard - Check the wire or clean
the keyboard.
If you can address the above...it is start...
William
Feb 14, 2008 | Computers & Internet
HELP PLEASE ASAP
OK well I think it is better to set it up like this... Connect the Modem to the Phone Line, Connect the Modem to the Router with an Ethernet Cable, Use a CABLE connection from the Main PC to the Router. (Ya gonna ditch the USB WiFi) Set that Main PC connection up to connect to the internet from the Main PC, thru Router thru Modem.... Then from Slave, install the USB adapter in this PC, and use this to connect DIRECTLY to the WiFi Router... and thus to the internet. This way will give the best transfer rates, and reliability
Sep 15, 2007 | Actiontec GT704WG Wireless Router...
Dell Inspiron 1200 Notebook Logo
700 people viewed this question
Alun Cox
