Question about Canon Sure Shot 150U 35mm Point and Shoot Camera
Canon 150u not working
When I try to use my new camera it has an "H" flashing on the screen and won't work. It worked fine a couple of days ago. Any help?
3 Suggested Answers
  • 2785 Answers
SOURCE: canon eos 500 not working
have you tried with another film
Posted on Apr 28, 2008
SOURCE: camera flash not working
Take it in
Posted on Jul 24, 2008
  • 3006 Answers
SOURCE: My Canon AE-1 was working
That fault is typical of the AE1 and closely related models such as the AT1.
First, try seeing if the camera works without the lens attached. If so, then the lens needs attention.
Otherwise, your camera is around thirty to forty years old and needs a thorough CLA service (Clean, Lubricate, Adjust). The internal lubricant films have dried-out and gummed up the workings. Also the foam light seals and mirror buffer will have either decayed to a sticky corrosive goo or will have gone further and dried out completely, falling away as black powder or gluing some parts together.
A professional CLA and a one-off foam replacement (modern material does not decay) isn't particularly cheap and far exceeds the residual value of the camera. But once it's done the camera should be good for many more years and there are huge numbers of high quality dirt-cheap lenses for it. Shoot on film or slide and scan the images and you have results which will still give any full frame dSLR a run for it's money.
Try to use a Canon specialist as they'll have scrap examples of your camera to cannibalise if spare parts are needed, but that model is really well made and unless you're unlucky then you should get away with a CLA and new foam.
Alternatively, unrestored examples are commonplace and cheap/free, so it's not a bad model to gain your own experience on if you're confident with electro-mechanical devices (the simpler AT1 is a better model to start learning on though as it has far less electronic parts). If you ruin it in the process then you gain experience and spare parts for the next attempt.
Good luck.
Posted on Aug 15, 2011
0 characters
1 Points
The camera has barely been used since purchased some years ago, and it seems that I can't get it to do anything at all. Batteries are new, worked fine for a while then nothing. What could be wrong? Camera...
It almost certainly needs servicing.
These cameras are especially prone to jamming up due to dried out lubricant films if they are not regularly used.
Get the seals replaced at the same time as they must be replaced at least annually.
Jul 09, 2010 | Sea and Sea MX-5 35mm Point and Shoot...
35mm film, preferably ISO 200 or 400, although on bright days you can easily use ISO 100 as well. You can choose between 12 (scarce and not worth it), 24 or 36 exposures and check that the film has not passed it's expiry date as it can result in poor colours and contrast.
Users have their own brand preferences, Fuji and Kodak tend to have brighter and more vivid colours, Agfa tends to be more earthy and natural in tone, and most store own brands will tend to resemble Agfa. You won't go far wrong with any of them. If you prefer you can also use monochrome (a.k.a. black and white) film, but unless it says on the side of the box that it's "C41 compatible" then you'll need to use a processing lab which specialises in monochrome. C41 is the name of the processing system used for colour film and so C41 monochrome can be processed by a regular High St or drug-store minilab.
Jan 21, 2010 | Canon Sure Shot 150U 35mm Point and Shoot...
Canon Sure Shot 105 ZOOM ~TOTALLY LOST ~need any instructions I can get.
The flashing H means hat the camera has detected a hardware fault on starting up. It can also mean that the film has mis-loaded. Try removing the film & then the battery to reset it. Put the battery back & switch on. If it's still doing it then I'm afraid it's got the 'flashing "H" of Doom'. Although this is repairable, it's usually not economically viable.
Jan 11, 2008 | Canon Sure Shot 105 Zoom 35mm Point and...
Try changing the battery and reloading the film. You can try emailing fuji as well. If these don't work take it to your local camera store to send away for repair, or a new digital camera.
Sep 14, 2007 | Fuji Zoom Date 60 35mm Point and Shoot...
How do you set the time on the Canon sure shot 80u
1. With power off, press the MODE button to select the DATE mode.
2. Press the zoom out (three trees) button for more than two seconds to enter the date/time set mode.
3. Press the zoom out (three trees) button to select year, month, day, hour, or minute (selected number will flash).
4. Use the zoom in (one tree) button to advance the number.
5. Repeat steps 3. and 4. to set each value.
6. Press the zoom out (three trees) button until the colon (in the hours:minutes) is flashing. When the colon stops flashing, date and time setting is completed.
7. Press the MODE button and the power will switch off.
Sep 10, 2007 | Canon Sure Shot 80U 35mm Point and Shoot...
Canon sure shot 90u
Take the battery out then push some buttons - the zoom buttons or the release button - til the LCD goes blank. This sometimes resets the circuit if there is really no problem. Then reinsert the battery and try again. If the H reappears, there is a problem with your zoom. It'll have to go to a repair shop.
Nov 30, 2006 | Canon Sure Shot 90U 35mm Point and Shoot...
No picture
it seems that the flex ribbion cable from the camera body to the lense assembly is damaged. A good repairer can replace it.
Oct 28, 2006 | Samsung Maxima 120Ti 35mm Point and Shoot...
U4--what does this mean?
U1-U9: these are technician codes indicating that there is a malfunction in the zoom mechanism of your camera, most likely electronic in nature - a defective IC chip and/or bad circuit board. Repair cost would easily exceed the value of the camera. You should be aware that, just as with today's small digital cameras, both mechanics and electronics of smaller point-and-shoot 35mm cameras consist for the most part of light-duty plastic and fragile electronics. If they last a couple of years they're doing well.
Dec 14, 2005 | Pentax Espio 115G QD 35mm Point and Shoot...
Canon Sure Shot 150U 35mm Point and Shoot Camera Logo
Top Canon Point and Shoot Film Cameras Experts
old marine
old marine
David Payne
David Payne
Are you a Canon Point and Shoot Film Camera Expert? Answer questions, earn points and help others
