Question about Kenmore HE2 Plus Front Load Washer
F 21 flashes
My washing machine does everything until i believe it is ready to drain and spin and it stops and flashes F21
We have the exact same washing machine, and the same problem. we will need to lift the front of your washer up and undo the bolts to the front cover. you will see a white round turn nob, this is the filter unscrew it (you kight plug your nose) and empty all contents, replace, screw the front plate back on and you are good to go!
Posted on Jan 31, 2009
  • 5,911 Answers
"F21" is a Long Drain error code. The following link explains what you need to do to troubleshoot and correct this problem:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Please read through the link thoroughly. In the majority of the cases, this turns out to be a clogged drain pump. Keep in mind, these small drain pumps can become damaged to point where they no longer work, or no longer pump the required volume of water. If the error code reappears after cleaning, it is recommended that you replace the drain pump.
If you have questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Jan 16, 2009
  • majirish Dec 18, 2010
    wow you just saved me a service call ,who knew all that money could have been in there it was completely clogged with coins and such,and i didnt even know there was a filter on this machine
    thanks a bunch
Error code F-21
F21 relates to a motor or control board fault.
Sep 27, 2016 | Kenmore Elite 45986 Front Load Washer
My Bosch classixx 6 is flashing 21 what does it mean
I have tried to do 6 clock position then 7o clock and hold on spin button for 5 seconds then let go .. Turn back 12o clock .. Then turn on programme .. It's worked .. Washing some clothes then start again f21 came on after wash.. Spin won't go on .. .???
Apr 25, 2015 | Bosch Washing Machines
My front loading Crosley washing machine is showing error code 21. What does that code mean?
Can't remember the exact error code, but my crosley front loader would not spin. I found out this was because all the water was not being pumped out. I wash a lot of dog blankets and found out the drain basket was completely blocked. I was able to remove and clean from the back and this fixed my problem. I guess it could be the pump but check this basket first. The way I did it from the back was hard so I suspect there is a better way to access the basket.
Jun 23, 2014 | Crosley CW5000 Front Load Washer
What does it mean if the washer is not draining and has a flashing f where the time shows?
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 07, 2011 | Kenmore HE2 Plus Front Load Washer
F-21 code several times. We clean the pump. Start again the rinse/drain and spin cicle, and now present sd code and later f-21 code. What we need to do.
Joe
Sep 04, 2011 | Kenmore HE2 Plus Front Load Washer
F21 is flashing,... what is this
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the "Sd" error will be displayed, then
4 minutes later the "F/21" error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
F21 washer drain time exceeded
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Feb 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer will wash and run until it gets to the drain and rinse part. then it stops and the F-21 flashes
"F21" is a Long Drain error code. The following link explains:
In MOST cases, this simply means you have something clogged in the drain pump and the pump requires cleaning. However, if the pump becomes damaged and no longer pumps at the correct volume, the error code will reappear. In this case, the drain pump will require replacement.
If you perform these steps and can't get the error code to clear, please post back and let me know. I hope this helps you.
Aug 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The F21 signal keeps flashing.
f21 is long drain, failed to drain in 8 mins. f27 is overfill, overfill contacts on pressure sw closed. If unit did actually successfully drain normally then pressure sw is likely the problem.
1. did pump come on? if no replace pump
2. is unit draining at normal rate? no then clean pump.
if yes on both replace pressure sw.
to second poster if getting suds error when using HE then you likely are using to much detergent. If avail run a clean washer cycle.
or normal cycle with bleach or fabric softner, no clothes
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore washer stopped with F21 error code
REPL/ YOUR PUMP F 21 LONG DRAIN .. MAYBE JUST NEEDS TO CLEANED OUT
Nov 29, 2008 | Washing Machines
Kenmore HE2plus wont spin...F-21 error
Apparantly the F21 error means there is a drain problem...I removed the drain hose from the output in the wall and held it down at ground level and let it drain into a pot...I ran the rinse, drain and spin cycle while I did this but before I hit the start button I hit the 2nd rinse button to turn off the rinse portion of the cycle. It seems to be draining fine now.
Jul 01, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
674 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
