Question about LG VX6000
LGLL6000 My phone just shut off earlier, I thought maybe the battery so I put it on the charger now it just powers up then turns off, any ideas
  • 44 Answers
M8 try a new charger could be that theres not enuff voltage goin to the fone.i would use a travel charger because it has a light on the back witch turns red when the phone is charging but if it doesent get any feed back from ther phone it or it has a problem i anway then it turns green also water damage can cause this to happen so only put the battery in the phone an put it on charge if you are sure there is no water in it u will be amazed how easy it is to get water in your fone. if you not sure or you want an expert to have a look at it try these guys http://www.mobilephoneservicecentre.co.uk/ they good,cheap and very good
Posted on Jun 27, 2007
Phone was working fine, switched it off earlier, wont power back on.
Take the Battery out and leave it out for 2 minutes and put it back in and try turning it back on. If they fails connect the charger and see if it turns on.
Sep 28, 2014 | Nokia E71 Smartphone
Incredible 2 phone won't turn on
your phone is not supported 32gb memory card that's why your phone is totally hang so if u want to fix it you have to update your software and go to a service station
Jul 09, 2017 | HTC Droid Incredible 2
Samsung admire shuts off on its own reads 0% when its fully charged
try to buy original battery and original charger, then try again, if problem persist show some oficial repairer maybe it is a charging ic problem due to waterdamage.for further help post comments.
Jun 28, 2012 | Samsung Admire SCH
Dont really know if its a real problem, but i got up in the middle of night for the toilet and noticed that on my desk my laptop was flashing orange from the charging port, i thought i must not have shut...
try to do a hard reset and check if it works..
shut down the pc, take out the charger, take out the battery, press and hold down the power button for 20-30 secs. then put back everything in their place and turn it on.. see if it works.
Apr 29, 2010 | HP Compaq 6735s Notebook
IPAQ hx 2110
You may need to purchase a new internal battery
Feb 04, 2009 | HP iPAQ H2200 Pocket PC
HTC S710 - Battery issue
it could be either battery or charger, If the charger isn't supplying enough power it will fool the phone..
some 3rd party batteries and cheapo chargers can cause all sorts of problems like this.
best way to test is charge your phone by usb, it takes longer but will give you some idea of weather its the battery or charger.
Make sure that the box at the bottom of the power management window (dont charge by usb) is set to off. Also for best results remove any other usb devices from the computer this will leave more power for the phone.
Best of luck
Jun 05, 2008 | HTC S710 Smartphone
Sansung d900 wont work
Take The Battery Out,Give It A Wipe Inside,Take The SIM Out And The Put It All In A Again And See If It Works.
Otherwise See If It Can Be Repaired By Warrenty?
Good Luck :)
Regards,
Sophiee.
Mar 02, 2008 | Samsung SGH-D900 Cellular Phone
Not Charging
well its a needle in the haystack problem, ha ha First thing I would do is take the battery out and put back in, to maybe insure the connection was there. Maybe U know someone with a electrical meter that can check your charger out, for output charge and the battery. Last but not least take it back.
Jan 04, 2008 | LG KG800 Cellular Phone
Lg vx8100 error message on screen: use genuine battery. power off 10 sec cuts off
Not exactly a solution. I tried leaving it off overnight and tried it several times after removing and inserting the batteries. I also cleaned the contacts with contact cleaner and a Q tip. It did not fix it. But I just left it off for 2 days meaning to go to the Verizon store and get it fixed or replaced. But I turned it on now and it fixed itself! Model VX8300. Maybe the contact cleaning did it but it had to dry more. You can use a Q Tip dipped in a cup of water with a teaspoon of Mr.Clean. But then rinse it with a water wet Q tip and then dry it with a paper towel. I used contact cleaner.
Dec 06, 2006 | LG VX6000
Open Questions:
LG VX6000 Logo
77 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
