Question about Alpine TDA-7547
Backlight on LCD display of Alpine TDA-5747E car radio gone
LCD display works, ie text appears, but it does not illuminate, so cannot read at night. Back light must be broken? All other lighting behind buttons etc work.
Can that be fixed and if so, where would I take it in Melbourne Australia?
  • 3 Answers
Here's the manual:
http://www.alpine.com.au/downloads/web_owners_manuals/cassette_owners_manuals/TDA-7548E_TDA-7547E.pdf
Posted on Sep 16, 2009
How do you open the Delphi SA10034 CD/MP3/FM boom box.
The boom box doesn't work or the XM receiver doesn't work?
Jun 03, 2014 | Delphi Audio Players & Recorders
Hi my display does not come on
If you don't see the Alpine logo while booting up then the florescent bulb for the LCD must be burnt.
Apr 25, 2010 | Alpine CVA-1003 Car Video Player
Display only stays visible at lowest illumination
Sounds like your display's backlight is dying. Your scfreen is in need of replacement. The higher ther brightness setting the faster it quits working.
Sep 25, 2009 | Dell Inspiron 1100 Notebook
HP Pavillion F1503 screen has gone dark...background is very, very faint, barely able to see/read it. What is the problem? If it is a ''backlight'', then what exact is a backlight, what does it do, is it...
Most of the time in this situation, the problem is due to the backlight going out. However, there are some instances where the inverter cable is bad.
The backlight is the part of the LCD which illuminates the screen. Think of an LCD as having multiple layers. One layer has the image itself on a semi-transparent layer and then behind that layer rests the backlight (usually a florescent bulb) which shines through all other layers to make the image glow and illuminate.
More info can be found here:
http://en.wikipedia.org/wiki/Backlight
As far as replacing the backlight, I always replace the whole LCD itself, which includes the backlight.
Otherwise, you risk ordering the backlight and finding out that it was the connection from the backlight to the LCD that was causing the problem (very possible) and then you would have to order the LCD anyway.
Sep 05, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Timex t439s clock display light out
The display on my clock is red as well. I found it that way when I came home from work today. It had lost all of its settings as well. I put everything back to the way it was supposed to be but I can't get the color to change. I guess something just quit.
Dec 12, 2007 | Timex (T439S) Clock Radio
Alpine cda7969r display problem
Hi trinder,
I fixed my Alpine TDA-7563 with the same problem. My display was completely blank everything else worked. After checking that the LCD display is getting power and everything else in the face that I can think of, I thought maybe the rubber LCD contacts were squeezed down or something and not making proper contact, so I just pushed it back onto the board and pressed.
This was at night, so I had an external lamp and noticed to my delight that the display was in fact working, nothing is wrong with it.
I am embarrased to say that as a technician I forgot that an LCD display needs a backlight, duh.
So a simple connectivity test on the 2 lamps shows that they are both blown.
I have to source them at my local electronics store, I measured the power supply to them as 12Volts, so it is just a matter of getting ones with the right dimensions and bright enough.
Hope you have the same problem, then it will be an easy fix for you.
Good luck,
Ramesh
Sep 11, 2007 | Alpine TDA-7563 Cassette Player
Can't reset radio stations, have no manual
go to; http://www.stylestandard.net/oswego/login/alpinelogin you dont need to login, just click continue Type tda into the search box and at the bottom there is the link to the manual for the TDA 7563. By all acounts they are very similar, so should get you started at least. hope this helps :)
Apr 02, 2007 | Alpine TDA-7564
Car Audio & Video Logo
594 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
