Question about Lexmark X7170 All-In-One InkJet Printer
When trying to copy to my computer get arrow message
Help me with my all in one
    President:
  • 2,692 Answers
Download the software driver from the LEXMARK website below and then install or reinstall you printer. A manual is also available  for download on this same website, different page.
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Posted on Jan 16, 2009
How do i forward text message
Hold your finger on the text message you want to forward. A bar will appear above it saying "Copy" and "More...."
Click "More..." and a checkbox will appear next to the message.
At the bottom of the screen you will see a trashcan and an arrow pointing right.
Click the arrow and you'll be able to forward the message.
Alternatively you can always just copy and paste it.
Mar 03, 2015 | Apple Working Black Att Iphone I Phone 3gs...
HP PhotoSmart computer indicates "open door"
Open "Devices and Printers" in start menu.
Right click printer with green arrow - click see whats printing.
Delete all documents.
Restart computer - then restart printer
See if that clears your error messages.
Mar 12, 2014 | HP PhotoSmart C4345 AllInOne InkJet...
How do you copy front and back?
1. First make sure you are in Copy Mode
2. Load document
3. Enter the number of copies you want using the number pad
4. Press Duplex and "up arrow" or "down arrow" to select 1sided>2sided L
5. Press Start to copy the document.
FYI - if you get an Out of Memory message while making duplex copies, you might need to install extra memory.
Mar 01, 2011 | Brother MFC8890DW AllInOne Laser Printer
I have a problem with my canon mp130 it is always showing a message codigo de erro 5b00, I tried to reset it by taking off the battery and living for more than 30 minutes, and then the menu -...
Try this:
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
OR
Reset for mp130
turn on the printer press menu
press scan, copy, scan to enter service mode
use> to get to nvram
set ABS-M level to 0
Set ABS-P level to 0
Press stop to exit..........Done
i hope this help
Oct 26, 2010 | Canon PIXMA MP130 All-In-One InkJet...
"Page Too Complex" message
Press ENTER to clear the message.
Allow the device to finish the job, or press CANCEL to cancel the job.
Lower the USB speed on the product by turning off "High Speed USB". Following are instructions on how to do this from the Secondary Service Menu:
To access the Secondary Service Menu press the Menu button.
Now press the #2 button and use the < arrow to navigate to the High Speed USB selection.
Press Enter and then use the arrow key to go to Off and press Enter again.
Press the Cancel button twice to exit the Secondary Service Menu.
Feb 15, 2010 | HP LaserJet 2840 All-In-One Printer
Trying to copy home videos onto dvd thru dazzle product connected between vhs player and my computer. Can witness video on computer monitor while recording and says copy is complete. But when I check dvd...
Open again your Intant DVD Recorder and then after that do the advance mode. Next on step number 1 click the full down arrowed and then choose your dazzle device. On step number 2 click on the full down arrow and choose your DVD writer. Make sure that you already inserted your DVD blank disc then hit prepared button message comes out just click okay.
Nov 17, 2009 | Pinnacle Dazzle DVD Recorder
Scanner Failure, 'Power off and on' message - therefore, fax will not work
Scanner failure will not let you to make copies nad scan but you will be able to print from computer and receive fax.
Even then try the steps mentioned bellow:
Remove both the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector (If possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing Printing from computer,
If you are able to print from computer you should be able to receive faxes.
Try printing a test fax.
Press Menu/Setup> Then press the right arrow key to locate Tools> Then Press Ok> Again press the right arrow key to locate Run Fax Test> And press OK
Check to see if it prints a Fax test
Good Luck
Aug 29, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Arrows don't work...can't save contacts to SIM
hi,
  your arrow keys have problem, so take it to the service center for repair..now i ll tell you how to access ur phone without arrow keys.. imagine ur menu is like wat i shown below..
       cal log      phonebook      applications
       browser    messages       files
       calendar   camera           settings
now if u want to access "cal log" press 1 ; "phonebook" press 2; " applns" press 3 ; "messages" press 5.....like this as in your keypad...
now select contacts by pressing any suitable number...select options...assume if your options are placed like this
view
create contact
send via
delete
copy to sim
then u can access view by pressing 1, create contact by pressing 2...and copy to sim by pressing 5....do it as it is in ur mobile...
good luck
Jul 03, 2008 | Motorola Mobility RAZR V3
Gateway GT5435E DVD Problems Vista 32-bit
have you tried reinstalling the player through add hardware if the drivers are bad or gone the setup wizard will help you down load them.
Dec 11, 2007 | Computers & Internet
Lexmark X7170 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
