Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Its a reddy heat multi fuel forced air heater, has diesel fuel in it. when turning it on it runs for two minutes and then turns off and spits out smoke. we repeat the process and the same results occur.
My reddy heat did the same thing and i fixed mine and i might be able to help you fix yours cheaply my email is ronniepack@cox.net. i hope ill be of some assisstance
Posted on Jan 22, 2009
  • 3 Answers
I think you might need to clean the filter - an easy task. Check the owner's manual to see how. If you don't have the manual, be brave and pop it apart - I think there are only a few screws holding it together. They're really a pretty smiple machine. To clean the filter, just rinse it off with gasoline.
Posted on Jan 16, 2009
Reddy Heater not firing
Take air preassure from an air hose to turn the fan blades to loosen everything up. Time for afull service, like change the vanes in the pump, 3- filters fuel--2 air.
Dec 15, 2009 | Reddy HEATER RH125T 125,000-BTU...
After 10 minutes of running in uninsulated garage air becomes dif
I need more details... what is it doing, what is your supply, etc....and why do you think it is the very unlikely improper air gas mixture?
David Lawrence the Propane Fuel Dude
Dec 08, 2009 | Reddy Heater RLP100 Portable Forced Air...
What will happen if I burn a diesel/ gas mix in a reddy heater 55000 multi fuel heater?
Hi, If the heater recommends kerosene or diesel only, and you mix gas into the situation, you will get an explosion and fire loosing not only the heater but most everything else.Unless the spec's say you can since it will use other fuels, gas would be one I would not use, mixed or not, like I say only if it says you can. At 70,000 B.T.U.s, as it says above, this Reddy heater burns hot anyway, and I don't want to put you in a dangerous situation by saying yes, go right ahead? So please check first, I would say no way. Good Luck, and Sincerely, Shastalaker7
Nov 21, 2009 | Reddy Heater R70 Portable Forced Air Space...
I have an older 100,000 btu Reddy unit that was pulsing. Put new diesel in and problem went away for awhile. Now pulsing again.
might have a clogged fuel filter. try to drain and replace. run fresh fuel. the pulse also could come from too much fuel causing a burst in the main heat exchanger. if this heater is older than ten years i would trash it and buy a new one so you dont blow up
Sep 12, 2009 | Reddy Portable Forced Air Propane Heater...
Sears forced air kero heater wont start, spitting fuel out front
sounds like the ignitor is bad, mine would try to light and do the same thing. I noticed one night that it was arcing out the entire length of the wires to the plug. If you have a good spark then i would suggest a CAD flame sensor, very cheap.
Jan 22, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
115000 btu ready heater/ about 3 years old from home depot/multi fuel
I would try cleaning the flame sensor, use a Qtip slightly moist with ispropyl alcohol. it's a rubber boot about 2in. long faceing the combustion chamber with two wires.
Jan 15, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Propane forced air heater
Need to make sure you are supplying a minimum tank supply of 100lb cyclinder. If smaller,you are producing co due to low gas flow
Nov 02, 2008 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
83 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
