Question about LG HBM 730 Bluetooth Headset Wireless Headset
Keeps beeping How does one get the LG HBM 730 Bluetooth Headset Wireless to stop beeping? I charge it, and it still keeps beeping when I turn it on to use.
SOURCE: I can set up my headset to my new phone
These are from verizon wireless.com. Support Phones & device Choose phone Choose device Help topics How to pair handset to headset
Posted on Jun 22, 2007
  • 242 Answers
SOURCE: Bluetooth HBM-730
just set the bluetooth earpiece to pairing mode and start searching bluetooth devices from your phone.
If you don't have a manual, just post back.
Posted on Apr 07, 2008
rockfixya
  • 679 Answers
SOURCE: How do I set my Bluetooth Headset HBM-730 to discover mode?
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.
2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select HBM-730 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
Posted on Jan 31, 2009
SOURCE: my voice is garbled and the people I call using a LG HBM-770 bluetooth wireless headset can not understand me. Suggestions??
tried pairing with a different phone and turned up the volume button...don't know which change made it work but it worked fine. So I'm guessing it might have been the voume was not set correcttly.
Posted on May 28, 2009
award462
  • 395 Answers
SOURCE: how to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Posted on May 06, 2010
How to make auto answer incoming phone (hand free) with LG HBM 570 bluetooth headset in case driving car
Hi, LG HBM 730 Bluetooth Headset Wireless Headset does have the ability to auto answer a call. But it does that automatically (does not need settings for it).
Also you can set auto answer from your cell phone.I don't know the model of the cell phone you are using at the moment. So you will need to use the manual of the cell phone to know how to auto answer calls.
When you set the cellphones auto answer, then it will auto answer on your LG HBM 730 Bluetooth Headset Wireless Headset..
Have a nice day
Mar 02, 2011 | LG HBM 730 Bluetooth Headset Wireless...
What AC charger can I use with my LG HBM 210 Bluetooth?
It is better to use the recommended charge from LG than to try one which is a universal type as the battery charging specifications are very critical to overcharge.
Sep 24, 2010 | LG HBM 730 Bluetooth Headset Wireless...
HBM 730 Bluetooth Headset Wireless Headset: Headset was given to me a while ago and I have a n...
To put your headset in paring mode, first turn it off. Then, press and hold the PWR/END button until the indicator led is solid lit (some 5 seconds). Now, make your phone's bluetooth software to search for devices. Select 'LG HBM-730' from the list. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
Hope it works for you
Hope it works for you.
Cheers! Carlos
May 05, 2010 | LG HBM 730 Bluetooth Headset Wireless...
How to connect lg hbm-730 bluetooth to dv4 laptop
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Pairing 730 and lg vx 860
To put the LG HBM-730 into pairing mode you must press the MFB for 5-10 seconds from power off. Pairing mode is denoted by the LED glowing solid red. LG has chosen to stick with the default pairing code of '0000'. Using Bluetooth specification 1.2, as is the custom, the HBM-730 supports both headset and handsfree profiles.
I found this on the internet and hope it works for you
Sep 05, 2008 | LG HBM 730 Bluetooth Headset Wireless...
Bluetooth HBM-730
Feb 06, 2008 | LG HBM 730 Bluetooth Headset Wireless...
My phone wont locate my LG bluetooth.
Just because your phones Bluetooth option is turned to on doesn't mean it's searching. I would try going in to your device history and clicking on new device while your Bluetooth is in pairing mode.
Aug 08, 2007 | LG HBM 730 Bluetooth Headset Wireless...
Step 1 - Enable Bluetooth functionality on the Motorola V3m. Note: The Bluetooth power must be set to ON position to pair the device. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Setup, press [Center NavKey]. Scroll to Power XXX, press [Center NavKey]. Scroll to On or OFF, press [Center NavKey]. Step 2 - Put your fully charged Bluetooth headset into pairing mode. Start with your Bluetooth accessory powered off. Hold down the power/end key for 5 seconds. You'll hear a short beep and the LED light turns red. Your Bluetooth accessory is now in pairing mode and ready to be paired with your handset. Step 3 - Pair the Motorola V3m with a Bluetooth Accessory. From the main screen, press Menu [Center NavKey]. Scroll to Settings & Tools. Scroll to Connections, press [Center NavKey]. Scroll to Bluetooth, press [Center NavKey]. Scroll to Handsfree, press [Center NavKey]. Place accessory in pairing mode. See accessory pairing instructions. Scroll to Look For Devices, press [Center NavKey]. Phone displays Scanning. Scroll to XXXAccessory NameXXX, press [Center NavKey]. Phone displays Bond With XXXAccessory NameXXX. Press Yes [Right SoftKey]. Phone displays Enter Passkey. Enter 0000, press [Center NavKey]. (See accessory instructions as passcode may vary.) Phone displays Connected.
Jun 17, 2007 | LG HBM 730 Bluetooth Headset Wireless...
LG HBM 730 Bluetooth Headset Wireless Headset Logo
291 people viewed this question
Top LG Radio Communications Experts
TO Lady
Mohamed Ismail
Mohamed Ismail
Computer Repairing
Computer Repairing
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
