Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Clothes come out soaked
When it goes through the spin cycle, my clothes still come out wet, not damp wet, but soaked with water so I have to squeeze it out by hand. Does anyone know who to solve this problem?
  • 1 more comment
  • Roger Rath Sep 17, 2007
    Not really, I tried finding the filter but I have no idea where it is. I took the whole thing apart and everything. But it sorta works better when there's less clothes in there.
  • Anonymous Apr 30, 2008
    My Whirlpool Ultimate Care II lsq9549lw clothes are coming out wet.
    It appears to go through all the cycles but the clothes are coming out wet.
    It appears to spin okay and I do wathch water pump out when running.
  • Anonymous Mar 16, 2014
    clothes coming out soaking wet
Transmission bad or clutch. I have seen transmissions start to leak oil, that will drip onto the clutch brake and cause it to slip with med. to large loads, and spin ok with small loads.
Posted on Dec 24, 2008
I have the same problem, but in my case it pumps all the water out fine. It just adds a couple of "rinse" bursts of water while spinning so the clothes come out soaked sometimes. Have you found a solution?
Posted on Sep 15, 2007
    President:
  • 1,294 Answers
You water is not being pumped out when the spin is on; this is due to the outlet filter being blocked. Find out where this is from your users'manual and clean it out. This is to be done periodically according to your usage.
Posted on Jun 18, 2007
Clothes are wet after spin cycle
U need a technician for that... there is a problem with the "flow valve" sorry can't help u out much with that... but maybe u can visit this site and hit the like button... www.facebook.com/muktidayasewa
Jan 13, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Manf# MAV5000AWW My toploading washing machine goes through all cycles but the last spin cycle the clothes are still soaked and i have to sring the excess water out by hand
If the machine is not pumping out completely, it could mean a blocked drain hose or a faulty/blocked pump. This would explain wet clothes However if the mache is not actually spinning it will leave the clothes wet,as well. Check and ascertain which function is not working.........Nomess
Apr 17, 2010 | Washing Machines
Clothes soaking wet after washer is done
There is either a problem with the drain or spin cycle. Before the spin cycly starts, ensure that the water drains fully. If it does, then it may either be the belt slipping or the timer malfunctioning. If there is water in the tub when it starts spinning, then you have a blockage in the drain line.
Feb 11, 2010 | Whirlpool Washing Machines
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Clothes are soaking wet after the entire wash cycle.
The motor controller is likely bad - not getting to the HIGH spin.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 07, 2009 | Washing Machines
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
610 people viewed this question
Dan Webster
Dan Webster
Sal De
