Hi. i have a lexmark 5400 printer/scanner/fax/copier and it doesn't want to print. It keeps beeping. the only way it stops beeping is when i unplug it. i have tried to uninstall and installing again and now i cant install it. Also i can't turn it off unless i unplug it
  • laura3355 Jan 16, 2009
    sorry, i dont have the manual and i can't find anything on beep codes on-line.
  • Thomas F. Schneider May 11, 2010
    I have read that their are beep codes in you users manual that tell you what is wrong.
  • 4,338 Answers
Here is the user guide, although I did not see flashing lights fix, It gives the control panel errors and it also shows you how to reset the printer on page 123:
http://images.lexmark.com/publications/pdfs/2007/5400/v3421438_en.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 16, 2009
2 Suggested Answers
  • 684 Answers
SOURCE: my printer wont stop beeping
Clear NV RAM.....
Unplug the Power Supply from the Printer....
Press and Hold the #5 button on the Printer and plug in the Power Supply.......
Don Release the #5 button till the Printer turns on completely....
After releasing the #5 button........
Press the Menu button once Keep on Pressing the Right Navigation Key till u find an option saying Maintanence goto maintanenece and go to manufacturing and click on clear NV RAM.....
Now as soon as the Printer is Restarted.......
Use it will work..........
Good Luck
Posted on Jan 22, 2009
Lexmark X3470 All-In-one Scanner keep on saying it Busy
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Should you still need assistance, please leave a comment to my response and I'll get back to you.
Oct 15, 2011 | Lexmark X3470 All-In-One InkJet Printer
I have a Lexmark 5400 printer with a scanner combined. The printer works fine, but when it comes to scanning it tells me cannot retrieve application list, is there anything I can do to get it to working...
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to scan a document again to verify that the problem is fixed.
Sep 20, 2011 | Lexmark X5470 All-In-One InkJet Printer
Hi, my lex1270 scanner is not working. printer and copy is fine. when i want to scan i get an error code!!! please help.
What is the error code displayed on the screen?
2. Unplug and re-plug the printer into the power source to reset it.
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aKlcOJ. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X1270 All-In-One InkJet Printer
Lexmark Scanner - "cannot retrieve application list" Won't Scan - HELP please!
delete the norton internet security as its blocking the scanner files of your printer software .or try reloading the printer drivers again but if reloading the printer drivers does not helps then removing the norton software is compulsary as the files of printer are getting blocked so scanner is not working.
Mar 07, 2009 | Lexmark X3350 All-In-One InkJet Printer
My printer wont stop beeping
Clear NV RAM.....
Good Luck
Jan 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 5400 wont print
-uninstall the software and reinstall it again and dont forget to put chek in the boxes of additional softwares., because those are the software for your scanner.
Nov 13, 2008 | Lexmark X5470 All-In-One InkJet Printer
Microsoft Paint ----> 'File' ------> 'From scanner or camera' (when in scan mode on printer). Just tried this and it really works.
Oct 19, 2008 | Lexmark X5470 All-In-One InkJet Printer
Receive blank faxes
Is it able to print when you are using it as a printer?
Jun 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 5400 incoming fax job wont print
from the Lexmark website:
This issue occurs when the user sends a fax using the flatbed scanner. After the first page is scanned, a message is displayed asking if another page needs to be scanned. The user options are YES or NO.
  • If the user chooses YES or NO and the fax starts to dial, they can safely press CANCEL without inducing the problem.
  • If the user presses the CANCEL button instead of answering the question, all future received faxes will go to memory instead of printing out. NOTE: There is no direct means of recovering a lost fax, but unplugging the machine and reseating the power supply will restore normal operation. An error report will be printed and provide information about the lost fax, which may allow the user to contact the sender and request that the fax be sent again.
Jan 28, 2008 | HP PSC 2210 All-In-One InkJet Printer
235 people viewed this question
jasbo
jasbo
