Question about Linksys Wireless-G WRT54G Router
Cant see my wireless network on my laptop - Linksys Wireless-G WRT54G Router
  • 62 Answers
You need to start by checking two things:
1. Is the wireless nic on the laptop turned on? Sometimes there is a switch or button on the laptop casing that turns the wireless nic on and off. Also you can sometimes turn the wireless nic on and off via a key combination on the keyboard. If you're sure it's turned on, take it to a wireless hot spot to verify that it is in fact picking up wireless networks in the area.
2. Did you connect to the wireless router using an ethernet cable, log into the routers configuration interface, and verify that the wireless access point is in fact turned on?
If the above does not lead you to a solution please answer the questions in this thread so that we can continue.
Posted on Jan 16, 2009
Cant connect to 2wire dsl cant see network wirelessnot switched ?
firstly does it have a wireless indicator somewhere on the laptop?
most of the indicators located next to bluetooth switch and other indicates. once you identify the indicated then you can solve this problem.
check you wireless network settings. if not the device is disabled or drivers not installed.
if your device is ok, then you check the software for the wireless network. most computers do not indicate that the wireless device is working, try to install a wireless application driver for your laptop and try connecting it a wireless device to see if there is any connectivity.
thank you
colticz
Apr 23, 2010 | Dell Inspiron 6000 Notebook
Please my laptop can not detect any wireless network and i have downloaded the latest drivers and its still not working. i was told it might be the wireless network adapter, please how can i solve this...
Check wether your laptop is genuine OS have install proper drivers. If yes, then contact to dealer and get it chek, may have the wireless network adapter issue.
Nov 22, 2009 | HP WLAN MultiPort W200 802.11b Wireless...
Cant get wireless router to work on laptop
First, try to connect your laptop hardwired to the router, if it works fine, its just the wireless configuration. Make sure you are using the correct wireless network key to connect to your wireless network. Go to the Control Panel > Network Connections > Right-click Wireless Network Connection > Properties > Wireless Networks Tab and delete all the names listed under Preferred Networks box. Click Ok. Right-click on Wireless Network Connection again > View Available Wireless Network > Choose your own network and click Connect. If it asks you to type the network key, type in your WEP or Wireless Network Key and press connect. That should do it.
Oct 06, 2009 | Computers & Internet
Wireless card works. says cant find wireless
There's a little switch on the right hand side below the keyboard...
Regards.
Aug 06, 2009 | Acer Aspire One PC Notebook
I cant access internet exp. from my laptop even with good signal
Access the preferred network settings (if you are using the Windows wireless setup - right click on the wireless icon + view available wireless networks + preferred networks) for your machine and edit the listing for your wireless network, you'll need to uncheck the box that says something to the effect of "an authentication key is provided for me" and enter your security key in the boxes provided.
If it still fails - you may want to remove your network from the preferred listing and add it manually, making sure that the authentication is turned off as described and with your security key entered twice.
Feb 23, 2009 | IBM ThinkPad R50e Notebook
Cant connect 2 laptops through linsky wrt54g is this possible
are you connecting the laptop hard wired or wirelessly?
for wired connection, just plug the ethernet cable from the router to the laptop and it should work fine.
for the wireless connection, check on the wireless network connection. for xp, click on start> control panel> network connections> right click wireless network connection> then click on view available wireless network> then select your network.. for secure wireless connection, type the security key then click connect. :-)
Dec 13, 2008 | Linksys Wireless-G WRT54G Router
TURN ON WIRELESS ON LAPTOP
check your wireless working fine
go to my network places.then view your wireless network if any network u see then connect.
also if your router is setup in security mode u have to add your wireless mac addresses in allow list in your router,
type in run "ipconfig /all" then u see mac adreses.
Nov 26, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Setting up wireless connection
First check to see if your windows can see the wireless router. Does it see the router? Click view wirelss networks to see a list of available networks. If you cant see any make sure your wireless network is switched on.
Also which manage s your wireless network, the windows or the wireless cards own software?
Aug 14, 2008 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
133 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
