Question about Lexmark X3470 All-In-One InkJet Printer
Cover open I just changed my cartridge and I'm trying to print my new sample page but the printer is giving me a "Cover Open" problem. The cover is clearly closed on the printer but I still cannot print. Does anyone have any solutions?
OK here is the solution there is a switch inside u need to lift the Scanner upward and detach it from the printer there are two sets of wires one is white set and the other is red and black set connected on the pcb ( printed circuit board ) detach them from there then u gonna see the switch it should be uncovered u need to find the cover for the swtich in the printer shake the printer it will be inside the printer and it oftens fall inside then use ur brains and cover that swtich with that plastic jack or cover then attach White and black red set of cables to pcb u are done ;)
Posted on Jan 19, 2009
    Genius:
  • 2,035 Answers
This is the problem the cover switch in the printer you need to replace the switch this switch is very difficult to find in the printer is usually hidden ,you need to check the cover there will be a projection in the cover which will go into a slot thats where the switch is located...
Good luck...
Posted on Jan 16, 2009
Hey,I am a big problem.When I want to print...something, I can't print because I have an error. Look here what "the printer" sais:"An ink cartridge is not installed properly.Open the...
this like your cartridge has problem with connection
open printer cover/door
then disconnect your printer cartridge, both the color and black, then connect the cartridge again
close the printer cover/door
try to print again, if message still appear, it mean you need to change your cartridge with new one
Mar 17, 2011 | Canon PIXMA iP1300 Printer
I have an HP LaserJet1020 printer. When I try to print a document a 2 inch wide area the full length of the page on the right side of the page) will not print. If I change to landscape printing, the same...
Run the 1/2 print test.
Print a few pages that have failed previously and as the printer is printing open the cartridge cover(top cover).
Pull out the cartridge and look at the paper down below. If the page looks good, you probably need a new fuser. If the page is messed up you could have a bad transfer roller or another bad toner cartridge.
Dec 19, 2010 | HP Office Equipment & Supplies
With my HP C4150 I keep getting the error "remove and check print cartridge on the right" I have replaced the cartridge and its still messed up. Any clues?
Sometimes get that statement if your using generic cartridges. Also when changing an hp cartridge usually it will require you to align the page after changing the cartridge. Could try alligning maybe that will remove the error message.
Jan 03, 2010 | HP Photosmart C4150 All-In-One InkJet...
Printing with double lines and blurry on left side of the page
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | HP DeskJet 1220c InkJet Printer
I just changed my black ink cartridge. Now, after
Print cartridge
Aug 18, 2009 | Office Equipment & Supplies
Error message "Cover Open"
try to put back the old cartridge if the message disappear ,means the new cartridge have problem. may be you buy a remanufacture one.
Dec 10, 2008 | Office Equipment & Supplies
Printer cover open....error...
find the cover switch, must be lever is broken or switch gone bad.
Oct 31, 2008 | Lexmark Office Equipment & Supplies
Lexmark X3470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
