Question about Brother FAX-575 Plain Paper Thermal
How to set auto recieve fax
Machine is on manual. will not pick up fax. how do set for auto recieve fax.
  • 186 Answers
I am not entirely familiar with the keyboard layout of that model but there should be a button tht is marked auto/tad/ft with a light next to one of the 3 settings. push the button until the light next to auto turns on. If there is not a button then this setting will have to be set in the menu/fax setup.
Posted on Jun 26, 2007
SOURCE:
I cant receive fax
Is there a dial tone if you pick up the reciever ? Can you send faxes or use the machine to make a phone call ? If you can make calls or send faxes the machine probably needs to be set to the auto recieve mode so that it automatically answers when a fax is being recieved. If no dial tone you may have a loose connection to your phone jack.
Oct 15, 2010 | Kodak 6150 AllInOne InkJet Printer
How do I recieve a fax
This question is pretty vague but I will do my best to answer your question.
  • Make sure the fax is plugged into a working phone jack (cable goes to line port on fax if multiple jacks are on fax machine)
  • Set the mode on the fax to auto (if you want fax to automatically answer fax)
  • Set the mode on the fax to manual (if you want to manually tell the fax to pick up the line)
  • Set the mode on the fax to A.M. (if you are using an answer machine, you will need to reference your operators manual for this as each manufacturer uses different settings)
After doing this call you fax line with your cell phone and see if your fax rings then answers (for auto).
Oct 14, 2009 | Office Equipment & Supplies
I can send fax but cant recieve fax
You have not told us which model fax you have but most machines have a receive mode selection. Your machine may be set to 'manual' receive. It will only receive if you pick up the phone and hit the start buton. The phone has to be connected to the machine. Look on your machine for the receive button. It may be marked as 'auto receive' and 'manual receive'. Select 'auto' so the machine will answer. It may be marked as 'fax mode' and 'tel mode' if so select 'fax mode''. It may also have a selection 'ans mode' you don't want this as it assumes that you have an answer phone connected to your machine and it waits until the machine answers before it detects incoming fax. Good Luck
Jul 07, 2009 | Brother IntelliFax-4100e Fax
Fax machine won't receive without pick up phone receiver.
on the front display you will see a recieve button and you need to press this and you will see on the display it say either fax...fax/tel.. auto press the button until fax shows thsi means it is only being used as a fax so the line will auto pick up... if you set it to auto it will ring check the line and if it finds its a fax it will put it through as one if not it will ring you phone.. good luck
Jun 26, 2009 | Brother IntelliFax-4100e Fax
My machine stopped recieving faxs.
Not familiar with the procedure to set your machine, so refer to your manual if need be, but somehow you machine has been chnged from "automatic receiv" to "manual receive", or "telephone mode".. Setting obviously needs to be "auto" for the machine to pick up on it's own.
Often times, this is a button right on the operation panel that you can toggle between the different settings.
Feb 24, 2009 | Brother Office Equipment & Supplies
Fax machine
You need to set the machine up to AutoAnswer as follows per HP:
Receiving faxes automatically If the Auto Answer option is set to On , the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. Press Auto Answer to turn on the Auto Answer option. 1: Setting the Auto Answer option
  1. 1 - Auto Answer button
    NOTE: The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Dec 30, 2008 | HP Officejet 6310 All-In-One InkJet...
You have to answer the hone to recieve the fax
Try unplugging the power cord for 10 seconds to reset the machine.
Scroll through the menus and set your machine to AUTO or AUTO RECEIVE.
Nov 25, 2008 | Brother MFC-8220 Fax
Still can't get fax not to pick up when answering machine is connected.
if you have the fax-575 there should be a TAD setting.
This is the setting you would use if you're using an answering machine on the same phone line as your fax machine.
To set the Recieve Mode :
Press Recieve Mode. The LCD display shows your current selection.
Continue to press Recieve Mode until your new selection appears. After 2 seconds the screen returns to the date and time display, along with your new Recieve Mode setting.
The 4 Recieve modes are Fax Only, Fax/Tel, TAD:Answering Machine, Manual.
Hope this helps!!!
Jan 30, 2008 | Brother FAX-575 Plain Paper Thermal
I AM ABLE TO SEND FAXES BUT NOT RECIEVE
Can you pick up the receiver on the phone and hear the fax tone when receiving? If so, can you then press the start button and begen receiving? If that works, then the fax auto settings are not set properly. Do you have the owners manual? Read the receiving fax section.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jul 30, 2007 | Sharp UX P200 Plain Paper Thermal transfer...
Brother FAX-575 Plain Paper Thermal Logo
115 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
