Question about Cobra 18 WX ST II 40-Channels Base CB Radio
'91 Mazda Protege
During cold starts, there's a squealing noise from under the hood. It only lasts until the car warms up. I'm thinking it's the fan belt, but I'm not really sure. Can't fix what I don't know.
  • scott LeBars Jan 22, 2009
    That totally made sense. I will replace the serpentine belt and hopefully that fixes the problem.
  • 328 Answers
It sounds like the serpentine (fan belt) is slipping and causing your squeal. If you haven't replaced it for a while you could be in need of a new one. When they get old the rubber gets hard and stretches.When you hear the squeal the belt is slipping and the friction from this causes heat and warms the belt and makes it stickier and it will then stop slipping. If your battery is being drained while the car is off or if you need to crank it for an extended period of time the extra strain from the alternator bringing the system back to proper voltage can also cause this as well.But replacing the belt is the first place to start.
hope this helps!
Posted on Jan 16, 2009
My mazda protege is having a heating problem. The temp guage will go up to the normal place as the engine warms up but then when I drive down the road the temp guage goes down to below cold and then my car...
I believe the mazda protege has a separate thermoswitch to activate the radiator's fan. Perhaps the fan keeps blowing until the temperature is too low. Try replacing the fan thermoswitch. Just take care to put in tis place a thermoswitch of the same temperature range.
Nov 11, 2013 | Cars & Trucks
Mazda protege 2000 squealing from serpentine belt area check engine light on
it is the belt it is either to tight or not tight enough
Dec 14, 2012 | 2000 Mazda Protege
Squealing at start up
For squealing noise problem,click the link below :----http://technoanswers.blogspot.com/2012/01/squealing-at-start-up-on-car.html
--------This will help.Thanks.
Jan 27, 2012 | 2000 Mazda 626
I own a 98 Chev S10 4X4 4.3L with A/C and the heater fan is making a squealing noise. I live in a cold climate. Would this be the fan or the belt? I am still getting hot air coming out of the vents its the...
You live in the cold so you must use the heat more they normal so i would geuss that the baerings in the fan motor are feeling this. There is no belt but the motor isn't that hard to replace. But i would wait until it gets somewhat warmer if you are getting heat now. Most people never change there antifreeze and its the heater core gets pluged up they think it lasts forever it dosn't. You need to remove the plastic houseings to get at the blower motor its from the outside way easyer then removeing the dashboard from the inside. Keep warm it make some noise but it won't explode.
Dec 31, 2010 | 1997 Chevrolet S-10 Pickup
Bought a used 93 mazda protege.(as is) A/C compressor does not start or engage.. When warmed up and running large primary fan is on. I fouund aux fan fuse removed from fuse box.under hood. I also found aux...
Sounds like u have a bad fan for 1,Im sure who disconnected it may have found an expensive problem they didn't want to deal with (electrical, ac compressor etc) Good luck, have it ckd
Apr 07, 2017 | 1993 Mazda Protege
2000 Mitsubishi Galant 4 cyl ES underhood squeal on right side
Be gentle with my rating. I am a long ways away. It sounds like a fan belt. You should pop the hood next time and see how it sounds when you have the squeeling going on. Fan belts will squeel until the get warmed up and then stop because the heat makes them grab the way they are ment too. Let me know, Raz
Apr 19, 2010 | 2000 Mitsubishi Galant
Timing belt on 1996 mazda protege slips during startup
Hello, this to me sounds like your fan belt slipping (not timing belt). To adjust the fan belt you need to undo your bolt on the alternator, pull it tight onto the fan belt and while holding it tight do the bolt back up tightly. this will stop yoour fan belt from slipping. I hope this helps.
Nov 06, 2009 | 1996 Mazda Protege
2000 Mazda Protege LX AC starts cold, blows "vapor", then warms
Sure take your buddy with you when you go so he can drive you away while they fix it but you do the talking with your buddy standing by ready to leave. Yes low on freon condensate drain stopped up fan belt loose or needes replaced. This is an old car and the mechanics will likly find many things wrong with it make sure they know that you what them to run it awile after it's fixed so that it in with some gas in the tank so they won't worry about running out. Should get alot of repairs done for less than $200
Aug 12, 2009 | 1998 Mazda Protege
Alternator belt squeals under load
check all the pulleys for alignment and wear, Also check the alternator output (make sure it is not always under load) hook up and ammeter on the positive) what
Are you running a large stereo? if so this can cause this especailly if the large stereo is not fused
Feb 06, 2009 | 1997 Mazda Protege
Cobra 18 WX ST II 40-Channels Base CB Radio Logo
57 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
