Question about Sharp Viewcam VL-Z1 Mini DV Digital Camcorder
Dew liht comes on and camcorder shuts off
Everything was ok when suddenly the dew light appeared and the camcorder just shut off. Suggestions as to what to do will be appreciated. Thanks
  • 2 more comments
  • Manuel Rodas Aug 23, 2007
    Hello and please any body shed some light as to why would the cassete holder door will not close. It was ok, and suddenly I got the ?ject tape"warning. I took the cassete out but I saw there was some loose tape. After that it does not close.f
    Thanks everyone.d
    Thanks everyone.
    Thanks everyone.
  • Fdoucet49 May 01, 2008
    hi  Iam Frank from Canada and have problem with my Sharp Camcorder.
     i would like to know where is the back up battery on a Sharp camcorder? cause i have problem with dew light? can someone help me , I will be greatful,
See the information reported here: http://www.techlore.com/forum/thread/12209/
Regards.
Posted on May 15, 2008
    Problem Solver:
Hello and please any body shed some light as to why would the cassete door will not close. It was ok, and suddenly I got the ?ject tape"warning. I took the cassete out but I saw there was some loos tape. After that it does not close. Thanks everyone.
Posted on Aug 17, 2007
  • 1 more comment
  • Manuel Gutierrez Aug 20, 2007
    Thanks everyone.
    Cassette holder does not want tpo close. Camcorder was working ok when suddenly it showed that I must eject tape. I did and then there was some loose tape, I fixed it, tried putting the tape back in again and that is when the problem occurred. I can not get to close the casette holder door.
    \Thanks kindly
  • Manuel Gutierrez Aug 21, 2007
    posted on Aug 20, 2007
    Thanks everyone.
Try to extract the backup battery for reset the "DEW" memory.
Posted on Aug 08, 2007
I had the same problem with a VL-Z3U, there was no home fix, the dew sensor needed replacing costing $130 CAD
Posted on Jul 31, 2007
Dew light
Dew is likely to form in the following circumstances: ?When moving the camcorder from a cold place to a warm place. ?When placing the camcorder in a cold room which is then heated rapidly. ?When moving the camcorder outdoors from an air conditioned room or car. ?When placing the camcorder in the direct path of air blowing from an air conditioner. ?When placing the camcorder in a humid room. Dew will gradually form on the head drum of your camcorder and make the video tape stick to the head. This causes damage both to the head and the tape. When dew forms, recording and playback may not function properly. When ?DEW? flashes, remove the cassette,leave the cassette compartment open,and wait for a few hours to allow the camcorder to acclimatise to the surrounding temperature. To use the camcorder again, turn on the power after waiting for a few hours. Be sure that ?DEW? has disappeared. Do not insert a cassette while ?DEW? is flashing; this may result in damage to the tape.
Aug 03, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Bypassing dew sensor on a Sharp VL-Z7 mini DV
- the solder joints to the DEW Sensor were "cold joints" which means that the solder joint is defective - is not a sound joint. This means that with temperature variation, the solder joint can intermittently separate and break the circuit, causing the DEW Indicator to come on and completely shut down the camera. The first problem I had with the camera was on a cold day, so it seemed to make sense.
Here is a picture from the perspective of the tape cover being at the top of the picture and the rest of the camera at the bottom. The dew sensor will be on your left.
go to:
http://omlets.tripod.com/sharpdew.jpg
Then, get a real slim soldering iron with a fine point. Open the tape cover and take the tape out. Get a strong light to shine down into the mechanism.
If your camera is like mine was, you may see a brownish material on or around the solder joint - this is flux used in soldering which was applied too heavily, and not heated long enough to burn off. The joint therefore doesn't quite connect the dew sensor to the terminal post - depending upon heat/cold ambient conditions, sometimes it makes contact and sometimes it doesn't .
Heat up the soldering iron - make certain the point is tinned (has a thin film of solder on it). Carefully just touch each solder joint for a couple of seconds - just enough for it to melt, and then quickly remove the soldering iron. You don't want to leave the iron in contact with the solder too long or it may melt other insulation around the terminal. This all probably sounds more complicated than it really is - but it really is just a 5 minute operation. If you've not done much soldering, and feel uncomfortable about trying it, you may want to take it to a radio, tv or computer repair shop and ask them to do it for you.
Jan 25, 2009 | Sharp Viewcam VL-Z7U Mini DV Digital...
Shut down "dew"
This happens when you take camera from cold(er) environment to warmer environment, dew forms on the recording head, so as a precaution the unit locks up. The solutions is to leave the unit switched on and wait till the dew incator goes out( can take up to an hour) I found this out when on holiday, i would go from an air conditioned room to bright sunshine and it happened all the time.
Sep 28, 2008 | JVC Everio GZ-MG30 Camcorder
Warning Dew Detected
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
May 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
DEW indicator / battery
In your owners manual on page 52 you will find a list of authorized service centers. Give the one in your area a call. Give them the brand name and model number of the camcorder. Tell them you are having a problem with the dew warning coming on while using the camera with the battery. They should be able to help find a answer to this problem.You can also call the panasonic customer support telephone number at 1-800-211-7262 between the hours of 9am-7pm EST. Give them the brand name and model number of the camcorder and ask them for help with the problem of dew indicator coming on while in use with the battery. I hope this information helps you with your camcorder problem.
Nov 20, 2007 | Quasar VM-L450 Camcorder
Closing itself down DEW
camcorder when turned on flashes in red DEW and closes it self down. i have taken all the batteries out and replaced sometimes after a few days the camcorder will work then DEW will rea ppear and shut itself down
Nov 02, 2007 | Sony HDR-HC1 Mini DV Digital Camcorder
Dew liht comes on and camcorder shuts off Everything was ok when suddenly the dew light appeared and the camcorder just shut off. Suggestions as to what to do... Do you think if I tried resolving the...
Tools needed. Zip lock bag. Sillica packs from shoe boxes or find somewhere to buy more... SImply seal with the camera and wait a couple days. This will suck the dew out. :) DO NOT USE HEAT like from a hair dryer or anything like that. Too hot for a cam to handle.
HELP, my panasonic keeps shutting off. Dew? condensation?
Put it in a very dry place, and let it sit for a few days. How is it getting either dew or condensation? Once dried out, keep it in an airtight plastic bag.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Sharp Viewcam VL-Z1 Mini DV Digital Camcorder Logo
543 people viewed this question
Top Sharp Video Cameras Experts
Marvin
Marvin
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
