Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Remote control range
Toshiba 42 inch regza remote range cut in half suddenly
  • bluesat50 Jan 16, 2009
    I did all of this and it worked, thanks. However, the remote for my dvr also did not work at the same time, therefore it must have been the tv sensor and not the remotes.
  • 362 Answers
Hi bluesat50, I will be happy to help. Make sure you have fresh batteries in the remote. Very carefully clean the IR window on the tv and the remote. Let me know if this helps and please rate this solution. Lone99star
Posted on Jan 16, 2009
  • 3 Answers
It could be due to a few reasons, but we'll start with the easiest and the obvious. First I would check your batteries. Change them with some new ones. If that's not the problem, I would clean the IR transmitter on the remote and the IR receiver on the tv. Anything past that may require purchasing a replacement remote.
  • brandonnash Jan 16, 2009
    If that's the case then if it's a rental dvr from your local cable or satellite provider I would ask for an exchange. You'll lose your shows, so I'd have a weekend in front of the tv catching up on your recorded shows!! Not at all a bad thing getting to spend time watching your favorite shows.
Code for Toshiba Regza 32XV555D handset please
PDF]BT Vision remote control TV code list A - BT.com
www.bt.com/help/codes
BT GroupBT Vision remote control TV code list ... If your make of TV isn't in the list, pleaselook for the code you need in the installation manual of your TV. 888 ...... Toshiba. 0011 0688 0002 0009 0005 0000 0049 0642 0646 0190 0727 0748 0006 0018 ...
Remote control code for Toshiba Regza 42rv530u - Verizon Forums
https://forums.verizon.com/...Programming/Remote-control-code-for-To...
Apr 12, 2010 - Remote control code for Toshiba Regza 42rv530u. Options. Mark as New ... to find a working code. Please write back if I can assist you further.
I need help finding remote control program codes for Toshiba Reg
Dec 14, 2015 | Toshiba Televison & Video
Toshiba regza
Look for any jammed buttons on remote or on control panel.
Aug 02, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
The picture onmy screen is showing up liek a 27 inch buti have a 42 inch tv
Hello nadine hensl,
there should be a picture size on your toshiba remote. Click on it and go to natural mode or any other mode. Play around with it to see which you like best. Hope this helps, good luck.
- Joe
Aug 30, 2011 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
We just pruchased a toshiba regza..we noticed a
Well for the $$ I expected ya paid for it.... well yes. The thing ya see is a "Stuck Pixel" ... really shouldn't be acceptable..
Jan 27, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Best picture settings for toshiba regza 42RV500e
Go to menu on your remote control and select picture setting and try selecting "default" setting to seeif you like the color, if not adjust contrast to about two thirds of the way and brightness to your liking and color to about the middle.
Jan 17, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Toshiba regza all but the hdmi input on my 42 inch toshiba regza
In most cases the HDMI issues are the source itself. Try another item like a DVD player or BluRay player. If they work then its a compatibility issue. If they don't then the HDMI receiver board in the TV is bad. Please take a moment to rate my answer. Thanks...
Nov 20, 2009 | Toshiba 42HL167 42 in. LCD Television
The *audio cuts out occasionally on my 42 INCH Toshiba flat screen TV Model # 42RV530U. Unit purchased from COSTCO on August 21, 2008. * Audio 'dead spots' (missing several words) in conversations every...
Try using the Audio line out RCA jacks feeding a PC powered speakers to see if it does the same thing, If it is OK, then the problem will be in the power amp sections that drive the speakers.
Oct 30, 2009 | Toshiba REGZA 42RV530U 42 in. LCD HDTV
How do you get stand off tosh regza 42 inch
How do you remove stand to a Toshiba Regza 42 inch
Jul 11, 2009 | Toshiba 42HL167 42 in. LCD Television
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
132 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
