Microsoft Windows 98 for PC Logo
Posted on Jan 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
D3d8. dll file not found
Game not working he ask a required dll file, d3d8.dll was not found
my pc is P3
Nate Phillips
Level 2:
Scholar:
  • Expert 96 Answers
  • Posted on Jan 16, 2009
Nate Phillips
Expert
Level 2:
Scholar:
Answers
96
Questions
Helped
21044
Points
192
Try downloading the latest Directx Runtime software. It can be acquired at this link.
Nate P.
2answers
Missing binkw32.dll
Download binkw32.dll from link and save it to your Hard Drive.
2. Copy binkw32.dll file to C:/windows/system32
3. Overwrite if asking.
4. If you still getting error - copy the dll file also to your software/game folder.
http://www.dll-files.com/dllindex/dll-files.shtml?binkw32
scroll down and click DOWNLOAD ZIP-FILE
3dx11_43.dll is missing
Compare the video requirements to your video card.
8helpful
Unsupported pixel shader version detected. 2.0
3 solutions:
(1) Change your graphics card.
(2) Download and install 3d analzye and check skip pixel shader 2.0 (check other settings if needed)
(3) Download Swiftshader and copy d3d8.dll and d3d9.dll inside the game directory and start the game.
(Beware using 3d analyze and Swiftshader will be very slow.So the wisest thing to do is changing your graphics card.)
How do i fix d3d8.dll when it says is missing from ma pc?.
The d3d8.dll file is a component of DirectX.
Reinstall your DirectX or update it to the latest version.
How it helps.
1helpful
I installed IGI 2 on my pc , now wenever i run it , it says that "file mss32.dll" was not found. what shuld i do plz help.
It's a miles sound system file, get it here and put it in the
windows system32 folder, reboot and the game should run.
http://www.dll-files.com/dllindex/dll-files.shtml?mss32
2answers
I got problem with d3dx9_29dll was not found.anyone could help?
There are quite a few different ways that d3dx9_29.dll errors may show up on your PC. Some of the more common d3dx9_29.dll errors are listed here:
  • "D3DX9_29.DLL Not Found"
  • "File d3dx9_29.dll not found"
  • "Error while starting game executable - couldn't load DLL file d3dx9_29.dll."
  • "D3dx9_29.dll is missing"
  • "D3DX9_29.DLL is missing. Replace D3DX9_29.DLL and try again."
  • "D3dx9_29.dll not found. Reinstalling the application may fix this problem."
  • "Missing component d3dx9_29.dll"
  • "This application failed to start because d3dx9_29.dll was not found!"
D3dx9_29.dll errors usually appear when a software program, most often a game, is started. Occasionally, d3dx9_29.dll errors will display after a game is loaded but right before the game begins. Unlike many other dll errors which can have complicated causes and fixes, d3dx9_29.dll issues are caused in one way or another by a single issue - some kind of problem with Microsoft DirectX. The d3dx9_29.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, d3dx9_29.dll errors usually show up only when using these programs.
Resolution
Important Note: Do not, under any circumstances, download the d3dx9_29.dll DLL file individually from any "DLL download site." There are a number of different reasons that downloading DLLs from these sites are never a good idea.
Note: If you've already downloaded d3dx9_29.dll from one of those DLL download sites, remove it from wherever you put it and continue with the following steps.
1. Restart your computer if you haven't yet done so.
The d3dx9_29.dll error might be a fluke or one-time issue and a simple restart could clear it up completely. It's unlikely this will fix the problem, but restarting is always a good first troubleshooting step.
2. Install the latest version of Microsoft DirectX 9. Chances are, upgrading to the latest version of DirectX 9 will fix the d3dx9_29.dll not found error.
Note: Microsoft often releases updates to DirectX 9 without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: Are you a Windows Vista user with DirectX 10? Your game or program may still need DirectX 9 files to run properly so give the installation a try. Don't worry, both versions of DirectX can be run side by side in Windows Vista.
3. Assuming the latest DirectX version from Microsoft doesn't fix the d3dx9_29.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
4. Uninstall the game or software program and then reinstall it again. Something may have happened to the files in the program that work with d3dx9_29.dll and a reinstall could do the trick.
5. Restore the d3dx9_29.dll file from DirectX 9. If the above standard troubleshooting steps haven't worked to solve your d3dx9_29.dll error, try extracting the d3dx9_29.dll individually from the DirectX 9 package.
6. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
HP computer ----XP solitaire game not working in vista
That is because solitaire is for xp and is not compatible with Vista. There is nothing you can do to make it work, it won't work be design of Microsoft.
Thanks and please take a moment to rate as fixya.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
