I have an Acer Aspire 6930 laptop and I do not know how to enable the wireless network. It was working fine several days ago and now it will not pick up the router. I think I have everything set up correctly, but I don't know where to turn on the wireless capability on the laptop. I would appreciate your help. Thanks. Tony
  • kdjdhdhe Mar 11, 2009
    I have an Acer aspire 6930 and the wireless manager is on but the light is not flashing. Someone please help!!!!!!!1
  • DEKR
    DEKR May 11, 2010
    do you have a internet icon in your task bar showing
  • 4,338 Answers
On a 6930 I believe the button is above the keyboard, embedded in the speakers. Look for a button with a radio telescope/satellite dish icon and make sure it is lit/flashing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 16, 2009
My acer aspire 4738 laptop cannot detect wireless connection and tells me that the wireless adapter is broken. . .what is the problem ?
Check if you are connected to network like Home. Also whether wireless router is close by. Join network and try.
Aug 22, 2013 | Acer Aspire 6930-6771 Laptop
I have somehow disabled the wireless capability. do you know the function key combination to enable it?
check on the edges of your laptop, there might be a slide switch to enable wireless connection.
set up a wireless connection by plugging in first the network cable.
select wireless or wlan connection
follow the process
reset your router
restart your computer
enjoy wireless networking
Jan 27, 2011 | Acer Aspire 6930-6771 Laptop
I have a notebook aspire 6930, i've had it just barely over a year, and a couple days ago my internet just wouldn't connect. When i push the touch button to turn the wireless LAN on it does not light up...
1) Make sure Wireless Lan is Enabled by pressing the light button of it
2) Click with right button on the Battery Icon (on the botton bar aside clock)
3) Select Windows Mobility Center (a window will open up)
4) Click on "Turn wireless on" button.
Jun 12, 2010 | Acer Aspire 6930-6455 Notebook PC
How do i turn the wireless capabilty on? my internet was working fine i restarted my laptop and now can not pick up my wirless, its saying that my wireless capability had been turned off, how to i put it...
Look for a WiFi button to ensure it isn't off. If it isn't, then go to the Control Panel and go to Device Manager (Hardware Manager in Vista) and make sure the device disabled. Right click it and choose Enable. Should pick up your wireless.
Jan 14, 2010 | Acer Aspire 6930-6771 Laptop
Acer 6930 wireless adapter failure conflict
Most Acers use a form of Intel IPN2220 Wireless card. If yours does, you use XP and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. Like me you've fallen foul of thinking that keeping your computer up to date using Automated Windows Update will keep everything in good order when in fact it can generate more problems than it solves
Oct 03, 2009 | Acer Aspire 6930-6771 Laptop
Aspire 6930 wireless button not working
Without any wireless networks available, using your computer wirelessly is most pointless. If you want to set up a wireless access point in your home you need a wireless router, connected to Internet.
Sep 18, 2009 | Acer Aspire 6930-6771 Laptop
Acer 6930 wireless won't connect anymore.
Hi acording your describle, you need do
1) please check the bios first, to set wireless to enable
2) check windows right buttom bar is there a wireless icon show there and click to see any detect wireless signal, if nothing to detect
3) check or compare to other laptop wireless configuration, check any incorrect setting.
4) if all sense ok, you need check the wireless card and wireless antenna wire connection, open a samll cover at back of laptop, there is a MINI PCI slot with a wireless card, take out and clean the card pins then put back.
5) still trouble please change another wireless card (same model)
it should be fix.
hope help you to fix it, please take a rating le me know how much helped you, thanks. for any question in any time please !
May 17, 2009 | Acer Aspire 6930-6455 Notebook PC
Where is the wireless connection button on the acer aspire 6930?
The switch for the 6930 is located just above the NumLock key. It actually looks like an LED indicator of a satellite dish, but it's not. It's the button for the WiFi enable/disable. Push it hard...
Thanks, Joe
Apr 06, 2009 | Acer Aspire 6930-6771 Laptop
Wireless network not working
Make sure that it shows the driver in the Device properties and not a yellow triangle. If that is good then try double clicking on the network icon on the bottom right hand corner of your screen and choose connect to a network, then follow the steps. Is you wireless router set as open/unsecure? If it is secure then you will need the key code to add the other computer.
Jan 05, 2009 | Acer Aspire 6930-6771 Laptop
Wireless connection to my laptop
you can't partially wipe your system
do you want to format
open control panel network connections see if network shows then right click then enable if you don't see enable then click repair
check devices see if your wireless still shows maybe needs updated
let me know if you are connected you may need to reinstall driver
i can help
Dec 27, 2008 | Acer Aspire 6930-6771 Laptop
Computers & Internet Logo
184 people viewed this question
David Payne
David Payne
