Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
VDSC365-6B The smaller oven locks closed or goes into self-clean mode when attempting to use bake, or other cooking settings. Only flipping the circuit braker will reset it. Suggestions? Thanks.
  • 35 Answers
A part of your latch assembly is malfunctioning.check this along with your oven sensor.
Posted on Jun 30, 2007
SOURCE:
Has anybody had the problem of the oven door staying locked and won't open after cooking and has cooled down for several hours?
The oven door lock should only lock during self clean only. SHould never lock during normal oven functions. While in self clean because of high temps, the door lock will remain locked for safety reason until the temps drop to about 350 or so then release. Thats how the lock system works. If you select the normal bake mode and your door locks you may need to have the latch adjusted or the unit checked for problems. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 01, 2016 | KitchenAid Kitchen Aid - KERS505XSS...
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
Started to bake an item, so I preheated the oven and started to cook item when all of a sudden an error code came up and stopped the oven from baking any longer. THE CODE( F95 ERR) came up and shut the...
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 23, 2010 | Kenmore 47153 Stainless Steel Dual Fuel...
Self-cleaning overn won't turn on. Clock tells time, but not sure if actually activating the self-clean feature. Oven interior light works. Other oven, cooking functions are ok, including time bake. Door...
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 18, 2010 | GE 30" Self-Cleaning Freestanding Electric...
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
Hi.
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Regards.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Whirlpool Accubake - Can't get out of clean mode
cannot get out of clean mode, although the oven outside is cool, but door is locked and display still says cleaning, door locked and time of 3 hrs 15 min is displayed. NOW WHAT?
Nov 16, 2008 | Kitchen Ranges
When trying to pre-heat my oven, It won't until serveral attempts later (maybe 10 ). Then, after baking and stopping the oven, I get an F1 error! What's going on?
F1 is listed as "Element Relay circuit Failure".
There will be a current switching relay to the oven - which is faulty - hence why you get the error when it realises it's not working.
This should be replaced to solve future problems.
For your reference, the fault codes are -
F0 Touch pad stuck in depressed position
F1 Element relay circuit failure
F2 Oven temp exceeded the clean runaway temp (self clean) -or- runaway temp (cooking modes)
F3 Short circu!t in oven temp sensor
F4 Open circuit in oven temp sensor
F5 - N/A
F6 Failure in the EEPROM check comparison (only time of day and timer will operate)
F7 Failure of Sef-C1ean auto door latch circuit.
F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking Self-Clean mode.
If this resolves the issue, Please rate accordingly. Thank you.
Jun 26, 2008 | Dacor Kitchen Ranges
Self clean
Usually the oven has to be locked closed with a handle on on the front door. This will activate a safety mechanism that will allow the cleaning cycle to start. If the safety switch is malfunctioning or the door is not closed properly, the cleaning cycle won't start.
Apr 20, 2008 | Ovens
F2 error, both ovens stopped working
F2 is a Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only)
Nov 23, 2006 | Dacor ECD230 Epicure Electric Double Oven
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
197 people viewed this question
Top Viking Kitchen Ranges Experts
wrtsjr
Level 1 Expert
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
