Question about Toys
Anniversary train clock; clock does not work
I need a motor to run the clock for a Lionel anniversary clock. The second hand only jumps in place and does not go around the clock face. The motor measures approx. 2-1/4" long, approx. 1-1/2" tall, and 1/2" wide. The writing on the motor shows HD 1688 Sheng Bang No (0) jewels unadjusted. The back left side has a black turning stick and further left of that is the on/off switch. The front has a large white turning stick and wire hookups. Is it possible to get this piece?
  • 2 more comments
  • Anonymous Jan 17, 2009
    Hi! I'm having the same problem with my lionel train clock. Everything works except there's a click to start the train but nothing happens. I'm presuming that the motor isn't kicking in. If you find a fix for this would you mind contacting me so I can repair the clock? I'll be glad to do the same if you furnish your email address. Mine is jlgordon419@yahoo.com. Thanks!
  • jan888 Jan 17, 2009
    My Lionel clock is having the same problem. The train won't go around the clock and it appears to be the motor. I'd also like to know where to locate a new motor for it. Thanks
  • Anonymous May 18, 2009
    SAME PROBLEM AS LISTED, NEED HELP
    V.J.
  • Caleb Browne May 22, 2018
    My Lionel centennial clock sounds, but the train itself doesn't move nor mechanism that runs around the clock face move or make sound. Looks like all the wires are intact. Also I have used new batteries.
It's not the motor it's the unit in the middel that works the clock it self. I have the same problem. When the clock passes the hour it is supose to send a signal to start the motor. There are two tiny pices metal that are supose to contact each other on the hour and they break off easy.
You have to replace the clock unit and reconect the two black wires.
Try by passing it. The two black wires that come from the clock unit. Cut them and touch them together. Make sure the light sencer on the front is not covered.
Good Luck
Posted on Aug 20, 2010
  • Bruce Reiner
    Bruce Reiner Dec 27, 2017
    Where would you get the clock unit Thanks Bruce
Blinking green light
Check to make certain that the batteries in the remote are good. Make sure that when using the remote, you orient the antenna in an upright position and are within 6 to 8 feet of the locomotive.
If the train has been running successfully and the problem has only just started, clean your wheels and the pick up roller on the locomotive removing any fluff etc. then clean the track. If the loco is still not working contact the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
Jan 08, 2014 | Lionel (31956) Thomas The Train Set
New polar express motor wont engage
It sounds like the gears have worn out or come adrift somehow. You will be able to get replacement gears from any of the Lionel authorised dealers Lionel Authorized Dealers or their replacement parts service Replacement Parts
Dec 28, 2013 | Lionel The Polar Express Train Set
My 1941 Lionel train stops getting enough power to run all the way around the track. Voltmeter says 15 volts around all track and transformer says 15 volts. How do I test engine?
If your sure the loco contacts/wheels are clean and the track is ok then remove the loco bodywork and check the motor. You can apply a 12v supply directly to the motor contacts to test if it's running ok. If it does run ok then suspect and clean the brushes and associated connections. If it does not run try moving the motor armature manually. If it is stuck it is probably time to replace it. If it moves apply a light machine oil and test again.
Dec 16, 2013 | Lionel Trains Classic Freight Train Set
The train keeps jumping off the track
Is the track properly and carefully put together? Is one or more sections damaged take one of the cars and gently push it around watching in those places where the train derails. If it only happens at a track joint look at it more carefully.
Nov 30, 2013 | Lionel Trains The Polar Express O Gauge...
Lionel train wheels are locking
1: clean & lubricate your engine2: if that does not work, the wheels may be out of quarter,check with Lionel Parts & Services.
http://www.lionel.com/ContactUs/
Dec 22, 2012 | Toys
Is lionel 40 watt transformer from toy train enough power to run a dual motor larger train engine it just lites up and sputters
It would depend on what engine you're trying to run. The 40 watt transformer's circuit breaker will trip off if you put too large of an electrical load on it. If the engine light stays on while it sputters, the track or the engine's motor and electrical pick-ups may need cleaning. Older engines that haven't been run for a while can get stiff. Your engine may need some lubrication.
Jan 18, 2011 | Lionel 40 Watt Transformer Train Set Track...
On my Lionel Holiday Tradition Express the handheld remote works yet with the train will not respond. All connections have been cleaned and that is not the problem. I did notice that the wheels on the...
the train does not run in daylight.....when one places the remote over the engine protecting the senor from sun the engine will start 10seconds after the sounds...I was very disappointed that it would not run in daylight. I'm looking for a method to rewire the system to work in daylight....maybe bypassing the control card.
Nov 28, 2010 | Lionel 11000 Holiday Tradition Express...
Toys Logo
2,919 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
