Question about Goodman CKL49AR49 Air Conditioner
Brand new goodman 2 and half ton package unit runing all the time
Also it is blowing cool air and you have to trun up the thermostat for it to blow warm runs day and night
    President:
  • 2,559 Answers
Sounds like the Thermostat or board is wired incorrectly(being new)
have the installer come back and rewire it.
Please rate this solution.
Posted on Jan 16, 2009
3a fuse blowing on the blower motor board
The 3 amp fuse blowing indicates some control function is either grounding out (probably a worn insulation on control wire) or one or more of the solenoid controls is pulling more wattage than it is designed to draw. The solenoids for the main contactor and reversing valves should only draw about 0.1 to 0.25 amp. Any more than this the solenoid overheats and causes the control fuse to blow. I have actually had to replace the thermostat wire on some units because the control that was pulling more than designed caused the entire length of thermostat wire to overheat and break down the insulation, causing the control wire to short to the common wire or others and cause more than required operations to occur simultaniosly. One unit had a short and emergy heat was coming on the same time cooling was on.
Feb 23, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Blower on heat pump blowing with no demand
There is a contact in the blower control card that can stick on. There is also a possibility that the green wire which starts the blower motor could be shorting out with the red wire somewhere inside the thermostat wire. If that is the problem, either pull new thermostat wire, (the rest of the insulation is probably breaking down) or there is some new red link controllers from Honeywell that will completely eliminate wire because the controls are all wireless.
Feb 05, 2014 | Goodman Manufacturing Goodman GPH1348H41...
Goodman GS9 blowing air but not getting hot
Does furnace fire up ,if not you have a issue with your furnace and not thermostat
Feb 12, 2018 | Goodman GMS90703BXA Heater
I have a 5 ton goodmsn heat pump it only blows cold air the heat doesnt come on have a new heat strip in it but still blows cod air
Heat pumps require a reversing valve for heat operation on the outdoor section, a control signal to a "O" terminal or orange wire is required for heating and cooling depending on the thermostat and out door unit requirements. The thermostat also has to be heat pump type for the system to operate heat for electric system with heat strip, two stage electric heating.
Jan 31, 2011 | Goodman CKL60AR60 Air Conditioner
I have a goodman CKJ42-1B air cond. unit. It keep tripping my AC breaker although continues to blow air - just not cool air. Once I turn OFF then ON the breaker the AC works fine for about a day. Then...
try cleani ng the unit outside with your garden hose first .sounds like its kinda dirty .the dirty er the coil is the higher the amp draw is when it is running .what size is the breaker in the box .thats a 3 an a half ton condensor
Aug 06, 2010 | Goodman CKL36AR36 Air Conditioner
Its 28 degrees out side and my goodman 3.5 ton heat pump package unit is blowing cold air out of all my regesters
Sounds like the heat pump is not running. Check outside to see if the fan is spinning.
Try moving the thermostat to emergency heat and see if that gives you any heat. If it does, then you have heat until you can get a service technician to locate the problem with the heat pump. It could be a wide range if issues from bad thermostat to bad wiring to bad capacitor.
Jan 07, 2010 | Goodman Heating & Cooling
I HAVE A GOODMAN 2 AND HALF TON UNIT THAT IS NOT REALLY BLOWING THAT COOL. i CLEANED THE COIL AND CHECKED TO MAKE SURE THE DRIP PAN WASN'T CLOGGED. THE UNIT IS NOT FREEZING UP EITHER.
In order to freeze, some refrigerant must be present. The outdoor units compressor overhats and will cut out, the fan stays on, if poor refigernat charge is the problem. This overload will not reset for 1-3 hours, just enough time to defrost and refail again.
Jun 24, 2009 | Goodman Heating & Cooling
Unit blowing cool air and runing all the time dont shut off
Bad blower relay, goodman has a sequential delay blower relay
Jan 16, 2009 | Goodman PHKJ048-1 Air Conditioner
1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Goodman CKL49AR49 Air Conditioner Logo
99 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
