Question about SMC2870W 802.11g/b Wireless Bridge
I need help setting up the SMC2870W to my gaming system...
I got the SMC device to connect my xbox game console to the internet without getting the 50 ft long ethernet cable... and i'm completly lost on how to set it up...
  • 691 Answers
You need to run the software provided with the unit. Connect the unit using the provided "crossover" network cable to a PC, this is wired slightly different to a standard network cable so make sure you have the right one - there are many sites that will explain crossover cables and give wiring diagrams.
Go through the setup program and choose the option to use the device as a bridge.
Posted on Feb 02, 2009
  • Daniel Bakewell Feb 02, 2009
    hmmmm. Just had some trouble proving this method because it had been previously used as an access point. It needs a few more steps.
    1. Plug in the smc2870w.
    2. Connect to router using normal network cable
    3. Run software on another computer connected to router & select when option appears, change to bridge mode. The Unit will swap to the bridge firmware, (takes a few minutes) then it will restart and you can go through setup again.
    4. set it up in infrastructure, DCHP mode and enter the SSID of your router. now you are ready to connect it to the device you wish to become wirelessly connected.
    5. Remove the smc2870w from the router and connect it to the device to be bridged using the crossover cable.
    If it doesn't work straight away try powering down the devices and restarting them to allow the network to reset.
Is there an smc2870w driver for Mac os x?
You can access the SMC2870 without a driver, you just need to plug into the Ethernet port.
The default IP address is 192.168.2.25
and the manual is here.
SMC Networks SMC2870W User Manual Network Settings
Mar 07, 2015 | SMC2870W 802.11g/b Wireless Bridge
Is there a driver for the SMC2870W and Mac OS X?
This is a standard wireless ethernet bridge and does not need a special driver for MAC OS. It is a Plug n Play device and should self configure using TCP/IP . Here is the manual : http://www.manualslib.com/manual/154817/Smc-Networks-Smc2870w.html?page=20#manual. Your Mac should see the wireless signal. You could use Safari browser to configure if needed. Apparently the Configuration utility is for older windows systems up to XP. You may need some networking skills to do the configuration without it. Good luck.
Mar 07, 2015 | Office Equipment & Supplies
I have been able to connect to Xbox Live for the past month and a half without any problem... Now it wont connect, but it says that it has internet access. All of our computers and our Wii gaming system is...
I have trouble connecting from time to time, and when I do, I restore the network configuration to the factory settings. To do this, go to My Xbox -> Network Settings -> Wired/Wireless Network (whichever you are using) -> Configure Network. Go to the Additional Settings tab, and then down to Restore to Factory Defaults. Click "Yes, restore to factory defaults." Note that it won't touch any of your game data, only the network settings, so the warning it gives is nothing to be concerned about. This may or may not work for you, but it's definitely worth a shot. If all else fails, just call Xbox (1-800-4-MY-XBOX [US]) and they should be able to sort you out.
Hope this helps!
Sep 13, 2011 | Microsoft Xbox 360 Console
Alright my girlfriend just got an xbox and she has everything set up, but she cant connect to live because a text pops up that says that it requires an update but she said that it has said that 5 times....
The easiest way to update your console software is to connect to Xbox LIVE. To update your console by using Xbox LIVE, all you need is an Internet connection.
  1. Connect your Xbox 360 console to the Internet. To learn how, please see How to connect to Xbox LIVE.
  2. On the console, go to My Xbox, and then select System Settings.
  3. Select Network Settings.
  4. Select Wired Network or the name of your wireless network, if you are prompted to do so.
  5. Select Test Xbox LIVE Connection.
  6. Select Yes if you are prompted to update the console software.
If you receive a connection error, try using the Xbox LIVE Connect Solution.
Console update did not install successfully?
If her system says that she needs an update then likely her connection should be getting to Live. You might need to clear her cache first and then try the steps above. Here is how you will clear your cache:
To clear the system cache
  1. Go to My Xbox, and then select System Settings.
  2. Select Memory.
  3. Highlight any storage device, and then press Y on your controller.
    (It doesn't matter which storage device you select; the cache will be cleared for all storage devices.)
  4. Select Clear System Cache.
  5. When prompted to confirm storage device maintenance, select Yes:
Aug 03, 2011 | Microsoft Xbox 360 Console
My xbox 360 reads my xbox games as dvds. i can play dvds in it, but every time i put in a game the dvd play options pop up instead of game settings. I was wondering if there was a simple setting solution...
This is an uncommon problem with Xbox 360's, but I have heard of it before. I know of a few possible fixes:
  1. Eject the game you're trying to play so your drive is empty.
  2. Turn on your console.
  3. Insert the disc and see what happens.
Xbox 360's do not have the greatest DVD drives on the planet, no doubt. Another thing you could do is to connect your Xbox 360 to the internet and be sure you have the latest firmware update. This might remedy the problem. As soon as your 360 is connected, it will automatically detect if an update is needed and it will tell you it wants to download it without you having to do anything.
If neither of these work, chances are you'll need to contact Microsoft at 1-800-4MY-XBOX for technical support. If you're lucky, you're still under warranty.
Mar 12, 2011 | Microsoft Xbox 360 Console
Not connecting to internet
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jun 07, 2010 | Video Game Consoles & Games
Hello my xbox cant seem to load any online matches (in games such as COD 6 and Gears 2). I have changed the nat type to open and checked the xbox live connect many times and when it does find a match, it...
Hello there!
Well since you managed to find match on game you wanted, connected and experienced lag in game, there is surely not any problem with your console or game settings, there is only one possibility left, and that could be your uplink.
Check your internet settings, cables , their connections, and from my own personal experiences with those similar devices you should have at least 1mbit/sec consistant internet link.
Thats about it.
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Microsoft Xbox 360 Console
Link Your Console to Another Console
Console-to-Console Connection: Wireless Some Xbox games offer console-to-console, or system-link, play, in which two or more players (depending on the game) can wirelessly network their consoles for multiplayer use. Console-to-console wireless networks are also known as ad-hoc networks. In ad-hoc networks, a wireless adapter on one device connects directly to a wireless adapter on another device. An Internet connection isn't shared with this type of network, and the console-to-console connection is typically temporary. For console-to-console play, you need: Two Xbox 360 consoles. Two Xbox 360 Wireless Networking Adapters. An Xbox 360 game that supports system link play. To wirelessly connect your console to another console: Attach an Xbox 360 Wireless Networking Adapter to the back of each console as described in Use Your Xbox 360 Wireless Networking Adapter. On each console, go to the System area to enter your network settings. (They will be the same for each console.) If all settings are correct, exit the System area. The consoles should now be wirelessly connected to each other.
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
SMC2870W 802.11g/b Wireless Bridge Logo
605 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
