Question about GE GSL25JFPBS Side by Side Refrigerator
GE GSS25JFPD CC dispenses crushed and whole ice but not water
I have tried;
Checking the water line = Ok
Replacing the water filter=Ok
Checking the door switch=Ok
Checking the water dispenser micro switch for continuity =Ok
What's next
  • jjulson156 May 01, 2009
    Dispenses ice but not water
  • 3 Answers
Mother Board!!
Posted on Apr 30, 2009
Only crushed ice, no cubes
Poor water supply. Is it filtered, and, if so, when did you last change the filter?
Apr 26, 2012 | GE Refrigerators
Have ice but no water. Changed filter and can hear water filling filter. Front control panel operations intermittent at best. Light in dispenser not working.
what is the model number?also try pushing crushed ice or cubes,just worked on a g.e. and the control panel on the door was bad,it kept beeping and if you pressed crushed ice the water would work,had to change out the board on the door,send model number so i can look it up for you,if you can hear the water fillling up in the filter it could be the board or a frozen water tank line,remove the bottom draws and see if you can see the water tank,with a hair dryer heat up the line where it connects to the tank if your model has a tank,send model number
Sep 26, 2010 | GE Refrigerators
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Our GSL25JFPD BS unit was installed 7/5/04 and in early 2009, we experienced water dispenser failure due to water line freeze-up, according to service technician. The freeze-ups resumed in February, 2010...
I found that when I used the crushed ice option, the lines would freeze up. Cubes were ok. Take everything out, including the ice, and turn it off for about 12 hours. Then check to see if it works again. If not, wait a little longer to let it fully defrost. If it still does not work after 24 hours, then you might need service.
Don't use crushed ice function.
Feb 26, 2010 | GE Refrigerators
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
My water dispenser suddenly has stopped working.
Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
Apr 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
No water from dispenser ice works fine
My water outlet was frozen and wouldn't let the water through. Turn the fridge off and let it thaw out if this is the case. Regards, Phil, Brisbane Australia
Jan 14, 2009 | GE Refrigerators
GE GSL25JFPBS Side by Side Refrigerator Logo
344 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
