Sony KP-41T15 Ok I will let you know what changing the picos does for me. Does the service manual show you how to navigate in the service mode and service codes also?
  • Joe1974 Mar 09, 2009
    I tried changing the pico's but nothing changed. I learned more about the TV and I found the only way to fix that convergence is through the service menu and it seems to be really difficult. I already made a mess out of it. I really don't know what convergence items to change, If you have any suggestions I'm open to them. I put off working on it for a while but it is still here.
    Thanks
  • 8,617 Answers
It should as Sony usually have very thorough service manuals
Posted on Jan 16, 2009
How to go in service mode for tv sony kp-46wt500.i did change the stk ic,the convergence is good in the midle but bad on the side
Did you replace the pico fuses on the G board there are two and usually one will blow when the old ICs fail and just replaceing the two ICs on the D board will usually not fix the issue untill the two pico fuses are checked and the blown one is replaced.
Mar 20, 2012 | Sony KP-46WT500 46" Rear Projection...
Replaced convergance chips adjusted red but blue will not adjust in any direction pico fuse is good Sony KP-57WS500
You can try to adjust in service mode but it sounds like you did not do this repair correctly. I would suggest getting instructions from sites such as www.TvRepairKits.com
Feb 12, 2012 | Sony KP-57WS500 57" Rear Projection...
Replacing STK392-560 on sony KP-51HW40
If they are open replace them. Do you have an OHM meter?
Nov 22, 2009 | Televison & Video
Massive Convergence problems even after replacing IC's.
See a pico fuse HERE and find PS8001 to PS8006 on D board of TV
Mar 18, 2009 | Sony KP-65WS500 65" Rear Projection...
RGB out of alignment
Replace BOTH STK ICs and CK PICO fuses they are green or yellow.
Jan 17, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP-41T15
I just called over there to speak with sonnt who said check the following fusible resistors on the D Board R1643,R1644,R1645, R1646,R1647,and R1648. They blow fastr when you have a convergence issue. There are all 0.1 ohm 1/6 watt resistors.
Also he mentioned they do have the manual its just not listed, but if you email them they will list it for you.
Jan 16, 2009 | Televison & Video
Convergence Problem
most likely cause is one of the 3.5 amp picos have blown when the old Ics failed. You can get replacement picos at the following link, and they also have the service manual which will explain how to adjust the colors through the service manual. Here is the link.
http://servicemanuals.vstore.ca/
Jan 15, 2009 | Sony KP-41T65 41" Rear Projection...
KP-41T15
On the pcb labeled (G) board look for location RY602
the replacment sony part number is # 1-755-018-11
this is the repair for stand by light blinking.
Thi is the repair for Power light blinging.
Q601, Q602 parts number(2sc4843)
r606 0.1ohm 1/2w also replace c604 and c605.
hope this helps,
regards,
daniel.
Jan 03, 2009 | Sony KP-41T25 41" TV
Sony KP 51WS510 convergence problem
You should get service manual and new ohm meter to check parts.
If tools are no good, results will not be good in any case.
I do not compromise on tools quality.
D board replacement is so early decision. As I told you, +22 and -22 should be available in D board. If such voltages are not there, how can convergence ICs carry out the job?
Please have service manual on any online manual store and check power supply area, why +22 and -22 are not being supplied.
Pico fuses should be checked out of board or at least one pin should be unsold to test fuse.
In circuit test of fuse is not good idea and can misguide you with wrong results.
Dec 22, 2008 | Sony KP-51WS510 51" Rear Projection...
Service mode for convergence
You enter the service menu by using the remote. Press DISPLAY, 5, VOL+, POWER in rapid succession. Once the screen appears, you should notice green letters and numbers at the top of the screen. Your remote acts as a navigation tool to allow you to select and change values. Keys 1 and 4 change the Item, keys 2 and 5 change the Category, and keys 3 and 6 change the Value. MUTE enters the write function, and ENTER executes it. Power exits the service menu. Keep in mind that while in the convergence mode, the keys have different functions, which we'll get to in due time. The service manual will also have this information.
http://tv.groups.yahoo.com/group/Ws500/
Feb 16, 2008 | Sony KP-51HW40 51" Rear Projection...
Televison & Video Logo
113 people viewed this question
Top Televison & Video Experts
Electro Med Services...
