Question about Mitsubishi LT-40133 40 in. LCD HDTV
Vertical lines on my 40 inch lcd mitsubishi hdtv 1080.
Vertical lines are color and are about 12 inches wide, they used to disappear after about 30 minutes but are now constant. The tv is 13 months old.
  • phelony00200 Mar 31, 2009
    Brand new 46 in Mitsubishi dhtv 1080. Blue vertical lines on left side when first turned on. Now afte we hooked up our new HD cable box there is another line on the right. It goes away after about 20-30 min but for the $ we paid I'm worried it's going to get worse.
    Problem Solver:
  • 7 Answers
I assume your Misubishi is not close to anything electrical. However, it sounds like you have had an interference for some time. This will ineviteably cause the HDTV LCD to collapse. LCD's don't respond well close to heat. Is there a vent close? LCD's do well in a properly vented area but with all this said.......they will pick up interference from anything electrical. A few questions to ask ones self........are there any wireless devices or chargers close to the LCD? Might there be an oven, a/c unit or other wiring with 220 volts anywhere close to the LCD such as in the wall?
The Mitsubishi LT is a very reliable, multi component ready set that allows great viewing with surround sound. However, stop and think about this interference. It is not something in the unit. It is an interference. Look hard and when you've discovered it.....you won't believe how crystal clear this set will be.
Let me know what you find...Thanks for using Fixya and add any comments that may help us help you.
Posted on Jan 16, 2009
I have vertical lines on my 42 inch samsung hd tv that are purple at first i turned the tv off for 10 mins and they had gone but now they are back the tv is only 1 month old can you help?
Posted on Jul 12, 2009
3 Suggested Answers
  • 53 Answers
SOURCE: vertical lines on my 40 inch lcd mitsubishi hdtv 1080
Bad/Going Bad/Will go horribly bad TCON board (small circuit board sitting at the top of the panel in the back).
Most likely, the whole panel will need to be replaced in order to rectify the issue.
Posted on Aug 01, 2009
Similar problem with an eleven and a half month old LT-40148. Approx. 1 inch vertical banding line on left side of screen on all inputs. After about two weeks, same problem on the right side of the screen.
Fortunately this occurred two weeks prior to the one year warranty expiring.
Called Mits customer service and they referred me to an authorized service center who I happened to have dealt with before.
They picked up the set. The front panel (LCD screen ) had to be replaced. Set was gone for two weeks as parts were not in stock. There was no charge. I hope this screen last more than a year.
Posted on Nov 21, 2009
Whire vertical band , 3 inches wide with red kine in the middle
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 12, 2014 | Sharp LC60E88UN Aquos 60 inch 1080p LCD...
Samsung lcd 32 inch tv has vertical lines in color about 4 inches wide all over the screen and it has no picture but it has audio
Only boards are sold and no parts- a 32 inch may not have even the boards or be cost effective to repair----suspect main board here.
Aug 26, 2012 | LG 42LC2D 42 in. LCD HDTV
Sony KDL40EX400 has (2) 2 inch wide vertical color bars about 4 inches from the left side of the screen. Purchased July 2010
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 22, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony Bravia KDL-40w4100 vertical line issue
Ok after over a year i figured out it was the tcon board. Good luck getting finding one. The first one i ordered from shopjimmy was faulty, didn't realize until after the warranty so i ate the cost of it (honestly i thought that it was good and there was another thing wrong with the tv) so i said wtf and bought one last week from ebay. Bam! it works great!!!
Jan 10, 2012 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
Mitsubishi 46in. LCD
The TCON board at the top of the panel is causing the issue. You will need to replace the whole panel.
When the set warms up, the TCON behaves. Replace the panel now to avoid what will eventually become a permanent line (if not several)
Jan 19, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Jan 16, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
I have a Mitsubishi DLP 52525 that has a bluish static
the DM and/or FMT boards are bad. the chassis needs to be rebuilt.
check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Mitsubishi LT-40133 40 in. LCD HDTV Logo
1,727 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
