Venta Airwasher VS 207 3.7 Gallon Humidifier
Problem for Venta Airwasher VS 207 3.7 Gallon Humidifier
Cleaned my Venta VS207 now it won't work. Only flashes.
By jgordon996 on Jan 16, 2009
I cleaned my Venta VS207 for first time. Used attached brush and plain water. Now it flashes but does not work. Maybe got water in some part? It's less than a year old. Any advice?
Same Problem
Mar 26, 2009
-   Same problem as everyone else, the digital screen just flashes. I tried cleaning the unit, still the same problem. I waited 30 minutes for the water level to adjust, turned the unit on, still the same probem. This unit only worked for about 1 week, then the flashing started.-   Frust 8 ed
Feb 22, 2009
-   humidifer just blinks on and off...bought a new one and it does the same thing!!!..any thoughts??-   pgoetz80
Feb 15, 2009
-   My unit clicks on and off every few seconds, and then the light starts blinking, even when the unit has been carefully cleaned, refilled, and hours (more than 8) have elapsed. -   Guest
Solution #1
posted on Jan 27, 2009
Somewhat Helpful)
JustNickG
Rank: Apprentice
Rating: 75%, 3 votes
I experienced the same thing. It seems to take time for the water level to get to a high enough point in the base after going though the filter. After placing the water tank back on the machine, let the water "find its level" for about 5 or 10 minutes. You will hear the bubbles comeing out of the filter during this time. Then turn the machine on. This is what worked for me.
Was this helpful?
Yes
No
Solution #2
posted on Feb 22, 2009
Not Rated)
trimshop08
Rank: Apprentice
Rating: 0%, 0 votes
Was this helpful?
Yes
No
Popular Solutions for Venta Airwasher VS 207 3.7
Questions and Unsolved Problems for Venta Airwasher VS 207 3.7
Do you recommend Venta Airwasher VS 207 3.7 Gallon Humidifier?
Answer
Answer
I have a venta 205. A half hour after I start it the light begins to flash and it stops giving... (More)
Answer
Venta-sonic VS 207 humidifier. Turns on but the display just flashes lights. I had it stored all... (More)
Answer
I turn the machine on and the light flashes red and nothing happens, I don't have a manual to... (More)
Answer
Venta-sonic VS207 humidifier display blinks and no controls work. Have tried to clean as instructed.... (More)
Answer
I have had my Venta 207 humidifier for two years but it has been humidifying very little recently. ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Venta Airwasher VS 207 3.7...:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
