Question about Toshiba Satellite M45-S165 Notebook
The fax console is recieving the land line number
I have put in the fax number but the land line number is the one the fax is answering. I have recognfidgered many times. But the land line number is still answered. Help. pearlofgreatprice1@hotmail.com
    Master:
  • 461 Answers
The problem is not in the configuration, but the fax connection. The fax modem port must be connected to the fax jack - not the same jack you connect your phone to.
Posted on Jan 16, 2009
MY X5650 WILL SEND FAXES BUT NOT RECIEVE THEM
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have a lexmark x5650 printer and I can send a fax but I cannot recieve a fax. Can you please help me?
Ensure that the telephone/fax line is plugged into the Line port on the back of Lexmark printer and not in the Phone port.
Jul 26, 2011 | Lexmark X5650 All-in-One InkJet Printer
WE CAN SEND A FAX BUT CANNOT RECIEVE A FAX THE PHONE LINE IS CONNECTED TO LINE AND NOT PHONE PLEASE HELP
try setting the answer mode to auto answer. It may be in manual answer mode. Also try calling your fax number and see if it rings.
Feb 19, 2011 | Canon FAXPHONE L80 Laser
How to recieve messages on my answering machine and still recieve faxes
If your telephone service offers ditictive rng you can order another number and your line will ring differently and you can set you G3 Fax to answer the distinctive ring and you regular call will be picked up by the answering machine.
Sep 17, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Fax and answring machine on same line
I assume you have distinctive ringing since both numbers are on the same line. According to the manufacturer's specs, the fax machine supports distinctive ringing. Set it up for the ring pattern assigned to the fax number and to answer on the first ring. Then it will pick up right away when someone calls the fax machine, and the answering machine will pick up the other number.
Nov 19, 2008 | AT&T (1718B) Digital Answering Machine
Konika minolta bizhub 350 fax no answer
Try altering the maximum nuber of rings until it relays the no answer message.
I am not sure exactly where that is.
ALso, you could try turing on the phone line volume so you can listen to what is heppening.
Sep 20, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
HP 640 Fax...can't recieve faxes
You cannot use a four wire cable to connect the fax to the wall. You must use a two wire cable, like the one that came with the machine.  BTW, that means you can't you the EXT port to connect a two line phone or answering machine.
Sep 04, 2008 | HP 640 Inkjet Fax Machine
Panasonic Panafax UF-585/595
could be a number of causes, most common someone fiddling with settings, secondly adsl internet und unfiltered lines so put filter on fax and any ext. ph. lines also contact your telecomunnications co. (and waste hours of time, be put on hold 25 times, told your account number isnt valid, theyre having a glitch in the system, its not their problem, youll have to ring back later, confirm your adress, D.O.B.- Ph no. -credit card no.- tax file no.- and your third cousins 2nd wifes stepsons- ex girlfriends- brothers 4th grade teachers middle name) and ask to have the line checked
Mar 28, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
I cant recieve an incoming fax
Check receive mode, probably set to manual receive.
Sep 03, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Toshiba Satellite M45-S165 Notebook Logo
197 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
