Question about Logitech G9 Laser Gaming Mouse
G9 Laser Mouse Scrolling Problem
I can't seem to scroll good on my mouse.
It has worked great for about a month now without problems
now when i scroll it doesn't work. it takes about 5-6 clicks to start scrolling down and i can't scroll up at all.
it only works when i tilt the scroller to the right and then scroll up and down but i can't work correctly by having to tilt it every time.
has anyone had the same problem ?
i have tried connecting it to another usb port, installing drivers, i even did a system restore to check if it was an automatic update that usually screws up something. i have no ideas left
  • sn4ke_reinha Jan 16, 2009
    get your facts straight before you answer ?
    g9 is a wired laser mouse
    and i did check the settings but there is nothing that solves it
    could it be that the scroller broke ?
    clean it how ?
    i thought of opening it up but i'm afraid that would void the warranty i have on it if i can't fix it
Thx for helping dude, logitechexpert my ***... now check that...i was so pissed because of such stupid advice that i hit my mouse on the corner of my desk...yep i really did.  ...and then it worked! it SCROLLS!
my theory: the logitech has a quite complicated mechanical clockwork-like gear switch for their scrollwheel. they are so proud of it, that they even have pictures of it on the box when you buy a g9. well, i guess when you make things more complicated they arent that reliable anymore...like the gear switch at your bycicle which gets messed up sometimes, because its small mechanical parts just get stucked.  so my mechanical solution: turn your g9 around hold it and knock three times(not too soft: imagine the money you paid for this mouse and release your anger) just around the area where the mechanism is located...i had exactly the same problems like you and now it works perfectly! ...i guess i dont need to buy batteries.
Posted on May 29, 2009
(Just sigh a new macro.)
Use your G-9 software, go to buttons and click on the scroll tab.
Chose Macro.
Then record what you want done in other words
open your browser and move the bar up and down with your mouse and make sure you save it.
then try it and i bet it works.
Keep your button on macro
G-9 Mouse
Posted on Jul 13, 2009
    Genius:
  • Logitech Master
  • 1,102 Answers
I BELIEVE YOUR TALKING ABOUT A CORDLESS MOUSE
Regardless your mouse may just need cleaned
you also may need to change batteries if it is cordless
you can also check your mouse settings through control panel
Posted on Jan 16, 2009
  • DEKR
    DEKR Jan 16, 2009
    When you said usb port made me think cordless maybe
    if you tryed cleaning it and still does'nt work
    then it probably is broken
Wow, Someoneangry. I was having this same problem and I didn't even have my G9 for a month and it started behaving this way .. I gave it one good knock and it starts working, lmao! Thanks to your serendipitous moment, I might have RMA'd this p.o.s. Bravo!
Posted on Oct 10, 2012
Mouse pad scroll sony vaio laptop pcg 3c2l
HI
IS THAT THE MOUSE PAD WORKING BEFORE
I THINK IS THAT PROBLEME COME FROM YOUR LAPTOP
TRY TO RESTOR YOUR YTEM
Feb 28, 2012 | Sony Vaio PCG-71318L
Scroll pad not working on hp laptop mouse still works though
Need to enable Scroll function on the notebook.
Scrolling function is not working:
  1. The scroll function may stop working if the scrolling feature is disabled in Mouse Properties. To enable the scroll function, follow the steps below.
  1. Click Start , Control Panel . Select Classic View from the left side of the Control Panel window.
  1. Double-click Mouse in Control Panel, and then select the Device Settings tab in the Mouse Properties window.
  1. Click Settings , Virtual Scrolling . Select the boxes labeled Enable vertical scrolling and Enable horizontal scrolling .
  1. Click OK to save and exit the Mouse Properties window.
  1. After changing these settings, the scroll function on the touchpad will be enabled.
Jul 24, 2010 | HP Pavilion dv5000t Notebook
When i'm trying to use the scrolling wheel it just
go control panel --click on mouse right click to get properties
check compatibility tab
adjust scroll speed to suit
Dec 17, 2017 | Saitek GM3200 Mouse
Laser mouse scrolls off screen
try the mouse without any logitech software installed for it if it keeps scrolling out of control check your mouse settings in control panel. go scroll and select the scroll to lines 5 or less. see if that changes anything.
Jul 14, 2009 | Logitech MX1000 Laser Cordless...
Expert Mouse scrolling problem
I have the same problem running under win7 64 bit, I have just pulled apart my expert mouse\trackball to clean it and found that the scroll ring works by using a little infrared diode ... so no cleaning required ...
the screws for the base are located under the little rubber feet.
So I think the problem may be more related to drivers\software...
at the moment I cant find a win 64bit driver or mouse works application anywhere
Feb 05, 2009 | Kensington Expert Mouse Trackball
Scroller goes up when scrolling down
This works for all mice.
click the scroll button and movie it up and down for a while and it will work just fine.
i had the same problem with my acer mouse but when i looked at a forum for the mac os x mouse someone said this tip and it worked
Oct 27, 2008 | Dell U0636 Mouse
Scroll Function Doesn't Work
Scrolling is integrated into the operating system. Try a restore point to a time you recall it working properly. If this doesn't work try a repair from your recovery disc or an operating system repair with your op system disc.
Jun 13, 2008 | Lenovo ThinkPad T61 Notebook
Inverted vertical scrolling
did u download latest driver form website maker site dont use cd
Jan 28, 2008 | Microsoft Wireless Laser Desktop 4000...
Scrolling problem?
Unplug usb, reinstall driver ,plug usb back. Or restart computer. I have the same annoying problem. It's the only solution i found.
It's nice having that kind of problem when clients are next to you, and you have to crawl under your desk to unplug the usb, and re-install everything. Makes it totally solvable.!
Hope they fix that problem with new drivers!!
Oct 19, 2007 | Wacom Intuos3 6x11 Tablet PC
Logitech G9 Laser Gaming Mouse Logo
2,434 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
