Question about Samsung ML 1210 Laser Printer
Samsung ML1210 printer not reconize since i moved
Power on, usb cable good & pluged in.
In the file titled printers and faxes, (unable to connect)
    Scholar:
  • Samsung Expert
  • 113 Answers
Have you tried to uninstall and reinstall the driver.
if it does not work on the CD.
Download @ www.samsung.com
reinstall the driver again and see it helps.
tips. change another usb cable or port from your system
Hope this Help :)
Samsu Tech
Posted on Apr 17, 2010
    Champion:
  • 220 Answers
Main board of printer faulty
Posted on Jun 24, 2009
Have mx510/512 canon printer/scanner/fax with new windows 10 computer. How do I scan documents or photo into my pc? no scan option when I open canon utility...
Step Connect the all-in-one printer to your computer through the provided USB power cable. Install all drivers that came with the Canon product. Without the drivers the computer is unable to import scanned images to your system.
Step Power on the printer and lift the cover on the top of the scanner bed. Position the image face down on the scanner glass, positioned in the corner when a green arrow points. Close the lid to secure the image.
Step Click the "Start" button, then choose "All Programs," "Accessories" and select "Scanner and Camera Wizard." This is a pre-installed application found on all Windows based computers.
Step Choose the "Scan" option, then select the connected Canon all-in-one printer and click "Scan" again. The image is scanned into your computer with a display of the picture on the screen.
Step Click "File" in the upper left corner of the desktop, followed by "Save." A save window appears on the screen. Title the image, choose a location to save the file to and click "OK." The image file now saves to your computer.
Aug 27, 2017 | Canon Office Equipment & Supplies
I am using Samsung SCX-4521F machine in which I am able to receive fax messages but unable to send fax using this machine. what should I do to get the problem resolved and to use the machine for both...
Please to assure that the cable from your wall connection go into the printer first and then from there with another cable to your phone. Second set up the printer as fax by using the original soft ware cd or download the programm from samsung webside. Make sure the phone and the fax are compatibile!
Apr 18, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Fax wont send or receive? I can here it ringing though wont send???
Try changing the cable from the phone wall outlet to the fax, when a incoming RING signal comes, with a bad phone cable (it is 90 volts AC) so the power to ring the fax can go through but not DATA, try pluging a standard phone in the wall outlet to see if it work's.... if the standard phone don't work than call the phone company's service desk, if the standard phone work's (initiating a call) than concentrate on the printer's trouble shooting guide...
Mar 14, 2011 | Samsung CLX-3160 All-In-One Laser Printer
For the installation of a ML-1740 Samsung Laser Printer, I'm instructed to connect the printer cable to my Dell Inspiron laptop via usb port , turn on power, and continue. I do; it doesn't The printer...
This happens at times with Samsung printers( i had an ML1210 with this same issue). What you do is click on the button that makes you skip this step( either skip/manual install) and proceed to install the driver. restart the pc with the usb cable unplugged and the printer turned on) .
plug in the usb cable(make sure printer is on) and wait for system to detect and install printer.
Now go to control panel > printers/faxes etc and you MAY see your printer listed twice. If it is it's most likely the one that says Copy of Samsung ML1740 or Samsung ML1740(copy 1) will be the default.
Delete the other one and set the one that says copy of ... as default by right clicking it and selecting "set as default printer"
You can also right click the printer and rename it(delete the extra copy of ...) for aesthetic reasons.
Mar 05, 2011 | Samsung ML1740 Laser Printer
I am unable to use my fax when it worked before, say's busy/no signal. The last time I was able to use it was in January 2010
Verify the connectivity (phone line) first by pluging a working telephone in the wall jack, than test the cable from the wall jack to the fax, you could install a Y to plug a working telephone with the fax on the same line to spy on what is happening when the fax is engaging a connection.
Cheers!
Jan 05, 2011 | Canon PIXMA MP530 All-In-One InkJet...
I have a samsung printer ML1210.I have installed the driver that came with it but every time i reboot the computer or switch the printer on a bubble pops up in the corner saying new hardware detected it...
you may want to try switch to a next usb port or replace the usb cable. it just seems more like your pc is not getting the correct reading from the usb connection.
try to reinstall the driver again once you swap the usb cable to other port.
test by switching your printer on and off again to see if the same error pop up saying new hardware detected. if it does happen again. uninstall the driver & download it from www.samsung.com
May 19, 2010 | Samsung ML 1210 Laser Printer
My computer is not reconizing my printer.
Check your cable to be certain it is snug.
If still a problem:
Delete the printer icon in Printers and Faxes.
Disconnect the printer's cable.
Restart your workstation.
Reconnect the printer cable.
Install the driver.
If you computer does not see your printer, your cable or USB port may be faulty.
Hope this helps.
Sep 12, 2009 | HP Office Equipment & Supplies
Bought Nikkai USB to Parralel convertor for Samsung ML1210
if the cable have usb connector and the other end a ordenary centronics print connector then it wil works on xp and vista
have also try to connect a othe printer to connect ??
http://www.alternate.nl/html/summaryListing.html?searchCriteria=usb+to+printer&cat1=012&cat2=000&cat3=018
this cables always work
Aug 19, 2009 | Office Equipment & Supplies
Gavran
Please visit http://www.samsung.com/us/support/search/supportSearchResult.do?group=printersmultifunction&group_cd=&type=printersmultifunction&type_cd=06010000&subtype=monochromelaserprinters&subtype_cd=06010400&model_nm=ML-1210&dType=D&vType=&mType=&model_cd=&menu=%2Fsupport%2Fsearch%2FsupportSearchResult.do&prd_ia_cd=06010400&acc_ia_fl=N&disp_nm=ML-1210&isEqualsY=
If you need to search Samsung.com for the printer drivers, type in "ML-1210" under the model number.
Hope this helps!
Oct 18, 2008 | Samsung ML 1210 Laser Printer
Fax
There are two sockets on the machine for telphone cable connection. one is for tyhe machine to be connected to exchange and other is for a phone set to mbe connected to machine. connect the line from exchange to the plug marked with "LINE". also check if your telephone company atually support fax communication. some comanies do not support sending of fax on there network. There is no software to be installed for fax. Good Luck,
Jagpal
Jun 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung ML 1210 Laser Printer Logo
114 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
