Question about Gem Sound SUB-650M Speaker
Klipsch ksw subwoofer wont power on
I have completely isolated the sub from the receiver and all other speakers. I will unplug the sub and make sure that it is off. The sub calls for a 1.2 A 250V fuse. I will replace the fuse, plug it back in and turn it on. The power light does not light up. I will then unplug it and check the fuse. The fuse is blown. I have tried multiple power sources from different locations and the problem persists. Any ideas of how to bring the bass bass back?
  • 3 Answers
The problem is Klipsch's problem, and they don't seem to want to face it. My 10" subwoofer blows the fuse before the power light can even come on. It's obvious that the fuse is not strong enough, but there is a delicate area between the fuse and the power supply. Too many amps on a fuse may keep it from blowing, but it may cook the power supply. Kipsch needs to fix this, tell us how to fix it, or replace it...at their expense. This should NOT be happening. Otherwise a great speaker....when it works.
Posted on Dec 14, 2009
  • 56 Answers
The power supply switching transistors are likely fried. Dangerous high voltages involved. I would remove the plate and send it to Klipsch for repair.
Posted on Apr 15, 2009
I have the Klipsch Sub-10 Subwoofer, and it no longer plays music. Now it hums (vibrates constant) and corresponds (louder or softer) with volume control. Light is home but no one home situation. V
Does the subwoofer have the same hum when the input cables have been unplugged? Many input cables use very fine conductors, which often fail. A bad cable will often introduce a hum and prevent a signal from getting through. If the noise is still present without the input cable(s) connected, then repair options are limited. No schematics are available. There's a daughterboard that has been available, but its failure usually causes the system to die (short-circuit). The cost to repair the amplifier may be close to the cost to replace the entire sub.
Sep 14, 2014 | Klipsch Synergy Sub-10 Subwoofer Speaker
Asko repair melbourne
it's more likely the amp, which klipsch provides as a complete unit.
Apr 08, 2014 | Klipsch Audio Players & Recorders
No sound when playing music using klipsch sub
check your receiver settings and make sure subwoofer is enabled during 2 channel playback.
Apr 16, 2013 | Klipsch RW12D Speaker
I have an Onkyo sr-605 receiver and a ksw-10 subwoofer hooked up to the subwoofer pre-out on the receiver. I have the subwoofer on auto so that it will pick up low frequency and turn on. It usually picks...
I have encountered this problem with other subs. The input has to reach a certain level before it abruptly switches on. I found the effect so annoying that I changed to another sub.
Apr 03, 2017 | Audio Players & Recorders
I have a Klipsch Sub-10 It is NOT working. I am not sure what happened. It was just fine last week. It's powered up and everthing but not throwing any bass. It was also detected during the auto setup.
If you're saying the auto setup produced sound then the sub and its amp are fine.
So we need to examine the source electronics for actual playback settings. Give a hint of what that might be.
Feb 19, 2011 | Klipsch Synergy Sub-10 Subwoofer Speaker
Klipsch subwoofer
its all about impedance matching...did you check to see that the new yamahas would drive from the system, before installing them? sounds like you will need to possibly add a matching transformer or other device on this one.
Mar 09, 2008 | Gem Sound SUB-650M Speaker
Klipsch subwoofer
how are you connecting the sub to you amplifier?
Dec 11, 2007 | Gem Sound SUB-650M Speaker
Gem Sound SUB-650M Speaker Logo
2,912 people viewed this question
Top Gem Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
brian williams
Are you a Gem Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
