GE 46GW945 46 in. Rear Projection Television
Problem for GE 46GW945 46 in. Rear Projection Television
TV acts like a timer is controling the power...comes on only at night
By Dale Ray on Jun 18, 2007
I work shift work. One morning when I got home my two girls had a slummber party and all the girls had been watching movies all night on our GE Big screen tv Model # 46GW945. The next couple of days I would try to watch tv and the tv controls would not allow me to turn the tv on until 8 PM that night...once the TV was on I started looking for a timer of some sort to see if the girls had messed with this...no luck but I did turn the lock for the front panel to OFF....then the next day it happened again.....now it is everyday and I don't know what to do....it's been going on now for a week....I can't find a reset button to try to reset the tv so what do I do now...I have read in several forums that if you unplug the TV for thirty minutes this might do the trick....I don't know what to do and there is no TV repair shops in my area...the closest one is about 100 miles away...kinda hard to load this tv in the back of the truck and take it to them...any suggestions to try...I'm at my last straw!
Solution #1
posted on Jul 06, 2007
Not Rated)
leslake
Rank: Wiz
Rating: 83%, 156 votes
How old is this set? If any age, might be time for a replacement, you can get a 50" for under $1000 now. Dont know about your issue, I have never heard of one not turning on because of a timer, suspect you may have a micro issue, the power cord unplug would be advisable, but sounds like you tried it, have you tried the buttons on the front? Do you clean the screen with something liquid? Some of these the buttons go bad and confuse the micro if you use liquids on the screen and let some dribble down the frame. Might pull the speaker grill off and there should be 2 1/4" screws on 2 brackets loosen and the brackets will drop, the screen can come out and there is a long connector that goes from the front to just behind the middle tube and if you unplug it it will kill the buttons on the front and if it is your problem will allow the remote to function, reassemble reverse of disassembly.
Was this helpful?
Yes
No
Popular Solutions for GE 46GW945 46 in. Rear
Questions and Unsolved Problems for GE 46GW945 46 in. Rear
Do you recommend GE 46GW945 46 in. Rear Projection Television?
Answer
Answer
Hi! the picture has dropped about 6 inches and the green control does not go up also the picture... (More)
Answer
GE 46gw945 52" Just moved from one house to another, tv was wrped in blankets and wraped in... (More)
Answer
I have Dish network and after they readjusted my dish the universal remote did not control the GE... (More)
Answer
the picture is distorted. the color is splitting from the image. red, green blue yellow is... (More)
Answer
posted by luckey777 on Apr 16, 2009 i have this model GE 46" projection tv that does not power... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE 46GW945 46 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
