Question about Kodak EASYSHARE 5100 All-In-One Printer
Where is the printhead located? - Kodak EASYSHARE 5100 All-In-One Printer
  • Kodak Master
  • 4,338 Answers
Link from Kodak:
Shows where and how to replace it
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 16, 2009
HP designjet 1055cm plus: Installed new toner, printheads and printhead cleaner packs and the black one is failing? Said, alignment so reinstalled. Still failing. Help!
hello,
Try to reconfigure your printer setting and then run diagnostic on your printer to know the status of your printer if it still supports the new toner , printer heads you install.
Thanks
Jul 31, 2009 | HP DesignJet 1050c InkJet Printer
I replaced my black cartridge on my injet 2230 but it keeps telling me that i need to replace black printhead. I've tried two so i know it isn't a problem with the cartridge
The cartridge does not have a printhead included as part of it.
The printhead is a separate thing normally located behind the cartridges.
You need to replace the printhead, not the cartridge.
Jul 13, 2009 | HP Inkjet 1200dn Printer
Error msg says "COLD PRINT HEAD"
1. The Printhead/Controller
cable assembly is
disconnected.
2. The environment is too cold
for the printhead to sustain
operating temperature.
1. Make sure the printhead/
controller cable assembly is
connected to J401 at the
printhead and J6 on the
controller PCBA.
2. Move the printer to a
warmer location.
If none of this works you might have a bad printhead. The thermistor on the printhead has gone bad and needs to be replaced.
Please contact me if a printhead is needed or if you have any other questions. I am also an ASR for Printronix meaning I can supply you with new and used parts and printers.
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
May 16, 2009 | Printronix T5000 Thermal Printer
How do I remove the cartridges and printhead
Simply squeeze the tab on the front of the cartridges and lift. The printhead, depending on how old it is will be released one of two ways. A button located top left corner of the printhead, kind of upside down or a white tab dead center.
Apr 13, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I remove a Kodak 5300 All-in-one printer heade?
there are 2 release tab located on the gap between the printhead wall and the carriage, one is located on the upper left hand corner of the printhead wall and the other one is located right at the top center of the printhead wall. All you have to do is to press any of these tabs to unlock the printhead and to release the printhead from the carriage.
Mar 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Installation of printhead
Installation instructions for printhead for Kodak 5300 All-In-One printer
Do you CHARGE for information which should have been provided FREE with the printhead? Included with the printhead was an internet number for prodiving instructions, but they were not provided at this number.
Most fortunately, I located some old instructions which I already had!
Winnie Bauman
wobauman@gmail.com
Jan 20, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP L7590 cannot locate printhead latch...don't think there is one
Ok...
The printheads are located in the internals of the printer. To get to them you need to gently lift the control panel up and you'll find this hinges up showing the inside of the printer.
You should then see on the printers LED that you can press and hold the OK button for 5 seconds to change the printheads. Do this until you see the printhead carriage moving out of the parking bay over towards the left.
IMPORTANT: Let the printhead carriage get over to the left and sit for at least 10 seconds before you do anything else as sometimes the printer opts to move the thing after a couple of seconds. Annoying but it can cause damage.. So wait a few.
Once the printhead is all the way over to the left, lift the blue plastic latch/cover from the front and this will reveal the two printheads.
You can now change and/or install your printheads before closing the blue plastic latch/cover and closing the printer lid.
Hope that helps.
Jan 11, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Phaser 8550 error 19,004.40
The printhead was installed in another machine and the codes do not match. You need to manually sync them. Here is the procedure:
Manually synchronize the Printhead and Electronics Module codes.
NOTE: The Printhead and Electronics Module codes should synchronize automatically when a new printhead is installed. If a 19,004.40 error occurs, it is possible that the replacement printhead was previously installed in a different printer. After manually synchronizing the Printhead and Electronics Module codes, be sure to test the new printhead for print quality defects.
To manually synchronize the codes;
1). Power OFF the printer.
2). Disconnect the printer from external devices (A/C power can remain connected).
3). Locate the "Factory Only" port on the electronics module (located between the PS and PE lights (Figure 1).
4). Use a Hard Disk Drive (HDD) jumper (Figure 2) to short the top two pins.
NOTE - If a HDD jumper is not available, use another conductive item, such as a screwdriver, to short the pins. Use caution to avoid contacting the surrounding frame, as this may permanently damage the Electronics Module.
5). With pins shorted, power ON the printer.
6). When printer reaches the mechanical initialization stage of the power on sequence, power the machine back OFF.
7). Remove the HDD jumper.
8). Code should now be synchronized. Power ON machine and verify the 19,004.40 error does not re-occur.
NOTE - If error persists after this procedure, attempt the procedure again, and be sure to allow the printer to complete its BIST and POST test before powering OFF in step 6.
Jun 29, 2008 | Xerox Phaser 8500/DN Printer
Lexmark C752 108 Printhead error
They mean the respective printheads have lost the HSynch.  The first thing the we do (and have had great success with) is to clean the laser lenses.  Then check the head wiring.  The following codes apply:
106 & 110 CYAN 107 & 111 MAGENTA 108 & 112 YELLOW 109 & 113 BLACK
Jan 10, 2008 | Lexmark C752 Printer
Kodak EASYSHARE 5100 All-In-One Printer Logo
22 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
