Question about Sony Ericsson Walkman W810i Cellular Phone
Cant connect to internet
When i try to connect it shows Conn. failure Check settings if problems persists contact operator for support i need all the settings for my phone Sony Ericsson Walkman W810i
You must contact the operator to solve that problem
Posted on Jan 16, 2009
Connection Failure. Check Settings. If Problem Persists Contact Your Operator" Help Me Please :)
Get your data Activated by your nearby Recharge shop...!!! or call your customer care to get data settings..!!!
Mar 23, 2012 | Sony Ericsson Cell Phones
Connection failure, check settings. If problem persist, contact your operator.
Then, contact your operator. Maybe it's a problem on your network and not on the phone itself.
Mar 22, 2011 | Sony Ericsson Walkman W205 Cell Phone
I have sony ericsson mobile w550i my problem is that i cant use the Internet sevices it gives me amessage conn failure check the setting
Ask your Service provider for proper INTERNET or GPRS settings and they will send u have to save and select as default and then click on web it will work :)
Jan 15, 2011 | Sony Ericsson W550i Cellular Phone
I install the settings for GPRS that my mobile operator sends me, but it reads a "connection failure. Check settings. If problem persists please contact your operator for support" error... I have a SE...
Check that the internet settings that were sent are actually ticked in internet settings. I had exactly same problem, and turned out i just had to select and save correct setting.
Sep 07, 2010 | Sony Ericsson W890i Cellular Phone
How to connect vb with ms access
se Adodc OR Even better.. ADODB. for this you need to get MDAC fromMicrosoft free download.(check under project_References- Microsoft DataActiveX objects.. the current no is 2.8. if it is not there download invb directory.
next, you can learn about creating a DSN from control panel, ODBC. onceyou learn this, connection becomes a piece of cake. get some free vbtutoriasl from WWW.
then
you need to use DAO or ADO to connect to the database. better study both but since ADO is current, i am showing that code.
under Menu Project_References, put a check mark on Microsoft ActiveXData Objects latest version (though it works for all, currently 2.8with sp pack 1 ).
at the general declarations:
dim conn as adodb.connection, rec as adodb.recordset, esql as string,esql1 as string
Private Function connect()
Set rec = New ADODB.Recordset
Set conn = New ADODB.Connection
esql = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & "D:VBDesigndhana2.mdb" & ";Persist Security Info=False"
'here you put the correct path of your mdb file. and check if you have jet 4.0
conn.Open (esql), , , 0
End Function
private sub form_Load()
connect
end sub
and for adding records:
say let us say you have 3 fields. then have 3 textboxes and 1 command button on the form.
private command1_click()
esql1="select * from Yourtablename"
rec.open(esql1),conn,, adOpenDynamic, adLockOptimistic
rec.AddNew
rec.Fields(0) = text1.Text
rec.Fields(1) = Text2.text
rec.Fields(2) = text3.text
' you need to check if in your access table design you have Allowed Zero length .. set it to Yes for all text fields.
rec.update
if not rec.eof then rec.movenext
rec.close
conn.close
set conn to nothing
end sub
this will add new records to access table from VB.
' for picture store the full path of the path and the picture file nameint the text field. and in the picturebox of VB form for viewingrecords again you need ADO or ADODC and here you code:picture1.picture=Loadpicture(rec.fields(3) ' depending on where thepicture field is located. you need to make a few trials.
End Function
connect
end sub
and for accessing records:
esql1="select * from Yourtablename where id =" & val(text1) ' for integers
esql1="select * from Yourtablename where name=" & "'" & text1 & "'" ' for string
rec.open(esql1),conn, adOpenstatic, adLockreadonly
label1.caption =rec.Fields(0)
label2.caption= rec.Fields(1)
label3.caption= rec.Fields(2)
rec.close
conn.close
set conn to nothing
end sub
' similarly there are routines to ADD, Delete, Edit, View etc.
Feb 26, 2009 | Computers & Internet
Internet connection to my w810i mobile
Shravs hello,
It seems that the mobile internet settings for your cellphone aren't configured correctly.
Please call your service provider, and ask them to send you via SMS (that is possible) the correct settings.
Palkin - go to the sony ericsson website, and to the downloads section, where you will find the mobile software for your phone. It is needed for the PC first, not your mobile phone:
http://www.sonyericsson.com/cws/support/softwaredownloads?cc=us&lc=en
Oct 30, 2008 | Sony Ericsson Walkman W810i Cellular Phone
No internet access
You can contact your mobile service provider and have them assist you with this problem
Sep 08, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Internet
u have noy mentioned the connection name. whether it is BSNL, AIRTEL,IDEA,HUTCH . if your balance amount falls under Rs 250 the message comes for BSNL
Jul 15, 2008 | Sony Ericsson K550i Cellular Phone
Can u help?
Are you sure that you have internet access activated by your mobile operator? It needs to be activated on their end for you to be able to access the internet.
Apr 12, 2008 | Sony Ericsson K800i Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
199 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
