Question about Poulan PP4218AV 18" Chain Saw
No bar oil coming out since new !!!!!!!!! is there a setting screw somewhere??????
    Problem Solver:
  • 11 Answers
I would remove chain and bar reinstall cover (For safety). start and run. oil should feed out into bar area, If nothing at all, return it for a new one, If you have oil check to make sure the bar has a matching hole where the oil feeds out. Newer saws dont oil much at all due to EPA standards it would be nice to have an old manual pump on some but I just carry a squirt bottle for the very large cuts I do and when I run into water.
Most have removed the adjustment screw that used to be on the bottom or clutch side of saw.
look for a trace amount on a smooth surface not alot like 10 years ago.
Good luck.
Posted on Jan 17, 2009
How to stop the bar chain oil leak
There should be an adjusting screw around the bar somewhere. Turn it anti clockwise until it stops and then just crack it one turn. If it still leaks too much then turn it down slightly.also try and store the saw on its side to stop the oil just coming out.
Apr 20, 2017 | Garden
Tip
Chainsaw Bar Oiling
Keeping your chainsaw bar oiling during use is the life of not only your bar but your saw. If the bar is not oiling, you will over power the engine on the saw thus depleting it's service life. <br /><br />On most saws there is a oil set screw on the bottom of the saw next to the bar; it has three settings. One way to see if your bar is oiling is to start the saw and put a piece of cardboard, old shirt or board in front of the saw while it is running. Rev the engine up with the bar in front of the piece of material and you should see a vertical line appear. If you can see a vertical line, your saw is oiling properly. If you see a vertical line with a lot of spray, then it is oiling to much. Adjust the set screw accordingly. <br /><br />Another thing to keep in mind is to make sure your oil line running from you oil fill tank is not clogged with debris keeping the bar from getting sufficient oil. <br /><br />Also, if you have a bar where the tip can be lubed, make sure you grease it. The tip of the bar gets extremely hot and keeping the tip properly greased will allow the bearings in the tip to last longer. Here is what you need and how to do it below:<br /><br /><span style="font-weight: bold;">Grease Tip of Bar</span><br /><br />Purchase a pre-filled grease gun manufactured specifically for the tips of chainsaw bars. Oftentimes, when purchasing a new saw, one will be included, if not they are inexpensive to buy. Use high temp grease when refilling. Place tip of grease gun in hole at tip of bar, and give a few pumps. When grease comes out the end of bar, enough has been used.
Keywords: Saw, Chain, Oil, Grease, Husqvarna<br /><br />
on Nov 15, 2010 | Garden
Oil not coming out on the bar
Check chain oil reservoir, assuming it is full and pathways are clear, your oil pump might be toast , or not set up properly. Usually, there is an adjusting screw. Don't run it dry.
Mar 12, 2014 | Homelite Gas, 16 In. Bar, 38 CC, Chain...
Leaks chain oil when not in use
two things come to mind. 1. The oil adjustment screw on the bottom of the saw is set too high for the type of cutting you're doing.
2.If the oil setting is too high, your saw will have an excess residue of oil on the , chain, sprocket, and oiler. When you set the saw down Oil runs out. Try setting the oil adjustment screw back a turn. Find the screw on the bottom of the saw., or check the owners manual. Good Luck! Alvin
Aug 31, 2011 | Echo CS310 14" Bar Length Fully Assembled...
I have a husqvarna 45 i bought in 1989...which runs great except the bar gets no oil....i cleaned everything up ...not sure about taking stuff apart...is this something i can fix myself?
On the bottom of the saw there is an adjusting screw that allows oil to come out onto the bar. There is three different settings. Adjust the screw to a certain setting. Then start the saw, put a board in front of you, rev the saw up and you should start seeing vertical line made by the oil. If no line is present, adjust the screw to a higher setting and try again. If this does not fix the problem, the oil line is clogged and will need to be cleaned out. Hope this helps.
Nov 14, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Where are the oiling ponts to the bar to the ryobi 16 inch petrol chainsaw?
Hi
It's Lisa?
On an electric chainsaw there usually aren't what you would call oiling points.Somewhere,probably on the rear or one side of the case will be a bulb.It's also the screw on cap for the oil reservoir.
You fill that up with chainsaw bar oil,and as you use the saw every few minutes push the bulb down 2-3 times and it applies oil to the chain and gear in the case.The chain transfers the oil to the bar.
If this helps,would you rate my post please?
Thanks Bob
By the way,if you give me your model number I can look for a manual somewhere.No promises though,Ryobi likes to sell their manuals rather than download them.
Aug 16, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Husqvarna 272 xp, setting for setting screw for oiler
To check for proper oiling, run the saw at speed with the tip of the bar near a piece of cardboard--it should throw off a thin line of oil after several moments of running. Adjust the oil adjust screw CCW for more oil. The screw is usually in the lower front or underneath the engine. Remove the bar and chain first before adjusting anything and check the oil passages located in the drive end of the bar for plugging--especially the two small passages that go from the large oil holes out to the chain groove on both sides. Start the engine without the bar and chain--look at the oil port where the bar mounts next to the engine. It should ooze out oil with the engine running fast. If nothing at all, the pump, oil lines, and oil filter in the tank should be checked. When everything seems to be working, then adjust oil flow for best operation. Hope this helps!
Apr 17, 2010 | Husqvarna Chain Saw 20" Bar
Chain smoking while cutting,hard cutting,and pull string hard to pull new saw.
too much oil in the fuel, or set screws are not mixing air fuel properly. have the set screws looked at, and listen for a bearing to be gone, there are two un related issues here.
Dec 15, 2009 | Poulan Garden
Chainsaw oiler issue
THE FIRST THING I WOULD CHECK IS THE BREATHER IT HAS TO LET AIR IN SOMEWHERE AS THE OIL FLOWS OUT IT MAY BE CLOGGED TRY RUNNING THE SAW WITH THE OIL CAP OF DONT DO ANY CUTTING JUST RUNSEE IF IT OILS THEN IF NOT MOST SAWS HAVE A OIL FLOW ADJUSTMENT SCREW TAKE THE BAR OFF AND LOOK AROUND WERE THE OIL COMES OUT THE ONLY OTHER THING IT MAY BE IS A CLOG IN THE LINE
Jun 25, 2009 | Garden
Chain oiler
Depends on the vintage, turn the saw upside down and you can see a screw to turn, 3 settings, right under the clutch and shaft. use a screw driver if it is adjustable. I like to keep mine set on high, oil is cheaper that new chains and bars. Use a bar oil, not old used motor oil.
Nov 01, 2008 | Husqvarna Chain Saw 20" Bar
Poulan PP4218AV 18" Chain Saw Logo
94 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
