Question about Sony PlayStation 2 Slimline Console
Ps2 my play station has a red light that works but the light will not turn green to power up. can i reset it somehow? Is there something i can do to fix it?
  • Anonymous Feb 22, 2009
    I have the same problem, cannot get the red light to turn to green and power up the ps2. tried the wd40 thing. Nothng
    Genius:
  • 1,175 Answers
HI...
This might sound "non-techy" but UNPLUG the power and shoot some WD40 into slot around the Power-on/reset switch. The press the switch several times.
Try with power connected.
There is a microswitch in there that doesnt know youre pushing the outside switch.
If it's broken , it can be replaced.
Also, is there a power light on the AC adapter/supply? and Is it ON?
I know places that have the parts.
Posted on Jan 22, 2009
  • 94 Answers
I think its your power coard is it dont turn on
Posted on Jan 17, 2009
I HAVE A SLIM PS2 RED LIGHT COMES ON SHOWING HAS POWER BUT RESET BUTTON WONT TURN GREEN when I push the power button.
well first of all your only supposed to press it. dont hold down. i dont really know why, but i suppose if anything something having to do with the power cord. proud to be part of your help
-brandon
Mar 30, 2009 | Sony PlayStation 2 (PS2) Console
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
PS2 No Green Light
Maybe it has something to do with your power supply, try replacing it with a different one.
Jun 09, 2008 | Sony PlayStation 2 (PS2) Console
Play station 2 won't turn on
Same problem...grr I've tried everything.
Mar 10, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 not spinning and light turning green then back to red
Hi
Your PS2 is probably experiencing a short circuit on the motherboard or the Emotion Engine is burned up. Sometimes the fan goes dead and the PS2 overheats and shuts down showing the red light. You can open the PS2 and clean up the motherboard and maybe it will recover.
Jan 30, 2008 | Sony PlayStation 2 (PS2) Console
My Ps2 light turns green then turns red
check to make sure your power cable is securely in, and check for any damage in the cable
Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
DVD-videos won't play, games do
If your PS2 is chipped for playing PS2 fake games then try the following steps: 1)Insert the DVD movie in your PS2 and hold the power button of PS2 until it light goes red. 2)Now again hold the power button until the light turns in green. and after that your DVD movie should work. ________________________________________________ If above solution does not works replace the lens with a new one.
Sep 01, 2007 | Sony PlayStation 2 (PS2) Console
PS2 turns on fine when disk tray is open but the reset button turns red from green and stops working
Here's a pretty good guess what happened... All of the Windex products are mostly water. You probably got some of the Windex onto the board of the PS2. Now this isn't a problem until it is energized. Once you turned it on, the windex which is mostly water probably shorted out your board instantly. There are a few things you can try though. Open up your console and try to dry the area with a hair dryer. After it appears dry, check to see it there is any corrosion anywhere you see metal. If there is, clean those areas with a q-tip and isoproply alcohol. Then you will want to let the parts air dry. Repeatedly hitting it with the hair dryer can shrink wires inside the system and can cause them not to function. See if that fixes the problem. If not, you may need to prepare your PS2 for a proper burial. And next time you need to clean the fan, use some sort of vacuum to suck the junk out from the back. Hope this helps. Good luck.
Jul 02, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
59 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
