New pickup coil and ignition module and coil spark at coil but not at plugs i even ohmed the pickup coil
Check the carbon and the spring in side the distributor cup 2nd change the high tention lead from the coil to distributor 3th ignition on remuve the 2 wires from the coil check the curen 12 volts as + conect to the coil and 4th check the black wire is your - with test light then conect to the coil good luck.
Check the coil wire from coil to distributor cap.
rotor and cap look to be in good shap i wiped cap no carbon
when i take off the spark plug cap's and hold it from the motor alittle i get a good spark.But when i put on the cap's i get no spark
so this is an external coil ? you crank motor and spark comes out of coil , but when you put coil wire on to cap , no secondary spark thru the spark plug wire correct ? then bad coil wire , cap or rotor issue .
you didn't forget your rotor by chance , ,, or inspect the rotor for a hole burned into it .
