Question about LG 24 in. LDS 5811 Built-in Dishwasher
Making a noise like something shorting or arching
I took it apart and checked the heating coil doesnt seem to be heating properly thought maybe the coil was going bad but it tested fine is there a relay or contacts that control the heating coil
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
Yes, the relays are on the main board. If the wash heater ohm tests okay (should measure around 12 ohms) then the problem is mot likely the main board.
Also, these units sometimes have an issue with the wiring in the door. If the serial number on the unit starts with 712 or lower, then this could be the cause. Black, tarry residue on the wiring harness inside the door would indicate that the unit is having these problems. If that is your case, call LG customer service at 800-243-0000 and have them refer to service bulletin # IDSW20070060.
Posted on Jan 18, 2009
I have a Maytag dryer model DG412 that recently stopped heating. I replaced the igniter and it worked for a few minutes then stopped again. When I removed the igniter it broke into pieces.
Usually if it heats for few minutes then doesn't relight one of the coils has gone bad. They come as a pair as you know somake sure you replace both. You have done everything right so far... You do have bad coils though.
Dec 09, 2016 | Maytag Dryers
2000 jeep wrangler with 35 inch tires making a rattling noise on front passenger side
make sure that the inside of the rim is tight on the hub and not sitting off it
loose/ incorrect wheel stud nuts will also cause the noise
Apr 12, 2017 | 2000 Jeep Wrangler
'03 convirtible beetle -locking noise
Maybe th ebattery was disconnected? You took it to a dealer? If so, I would have them check it.
Mar 12, 2010 | 2003 Volkswagen New Beetle Convertible
I just recently took apart my GE Dryer, model number DJSR473ET1WW to fix a loud noise. I put it back together and now I realize that the back of my dryer is extremely hot. Is there something I may have...
Sounds like you hava a venting problem. Disconnect the vent on the back and see if it still gets hot.
If it gets hot when the dryer is not on, then the heating element coil is shorting out on the element pan.
Hope that all helps.
Jan 15, 2010 | Washing Machines
I have a Kenmore 80 series dryer(118.72812101).
You may have something inside the workings of the dryer which has shorted out the heater coil. this could be the source of the noise as well. you need to remove the cabinet to access this, yet be careful as the drum will fall out on you in process. You can get a new coil from an appliance part store in your area. Take the dryer apart before buying this tho, so you don't waste your money on the off chance that this isn't the trouble. you will need make model and serial number from unit so they can match up the proper coil for you. Make note of how the belt is placed and routed for proper replacement when reassembling. Also make note of 'drum rollers' condition, as this could be some of the noise also.
Best to you, hope it works out
Joe
Aug 26, 2009 | Kenmore Dryers
Gibson electric dryer doesnt heat up
you may have shorted you thermal fuse. or the overload that is attached to the element housing. Good luck.
Apr 13, 2009 | LG DLE2532W Electric Dryer
TV making high pitch noise, stop working.
It must be the horizontal output transistor, it maybe short circuited. A short in flyback.
Apr 02, 2009 | Televison & Video
Asus fan problem
It sounds like the bearings have gone .. it should be possible to replace the fan ... they are almost all standard 12v
Mar 17, 2009 | ASUS Computers & Internet
GE Spacemaker XL 1800 - Noise while heating
Maybe you and the person from the post below could get together and help each other? http://www.fixya.com/ThreadView.aspx?prdid=489218&thid=130453
Mar 25, 2007 | GE JVM1660 Microwave Oven
LG 24 in. LDS 5811 Built-in Dishwasher Logo
144 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
